    [Plugin] CopyAlongCurve 1.0.4 (28 February 2017)
    16 Posts 14 Posters 29.7k Views 14 Watching
    • B
      Ben Ritter
      Anton,
      Thank you for being generous to share.
      • Bob JamesB
        Bob James
        Excellent extension. Very similar to sdmitch's "Component_String".
        • P
          Pherim
          This is great, thank you!
          • alvisA
            alvis
            Thank you very much. Very accurate.
            • P
              pxorduna
              Hello Anton,
              I got this error message after install the plug in and open Scketchup up
              (I have ScketchUp Version 8.0.164846, Windows 7 64bits.)
              ( I don't see the Extension Option at Menu )
              Error Loading File C:/Program Files (x86)/Google/Google SketchUp
              8/Plugins/ams_CopyAlongCurve/main.rb
              undefined method new' for Length:ClassError Loading File ams_CopyAlongCurve.rb undefined method new' for Length:Class
                Anton_S
                Hello, Alejandro,
                It is fixed now. Thank you for the report.
                Regards,
                Anton
                  mriedel
                  Great plugin. Works as advertised. Flexible. Most importantly, I was able to start using it productively -- without reading any documentation -- within seconds of installing it.
                  • sketchartist023S
                    sketchartist023
                    Trying to use this and it isn't working for this particular curve. The curve was a hand made line that I used TIG's weld tool to make it a curve. Weird thing is, it worked on the other curve just fine. Any thoughts? The object is a group, solid too btw, 0 errors with FixtIt. The line is shown as a curve as it has been welded. I have tried both closed and open curves. TY if you can help πŸ˜„
                    https://i.postimg.cc/V6s8Lt98/error1.png
                    [/url]
                      Share the .skp file so we can see what you have set up exactly. I just made up something that looks similar and it worked fine for me.
                      What version of SketchUp are you using? Please complete your profile.
                      • K
                        KropocLeckor
                        Marvelous. Just Marvelous and Easy to use.
                          Requisher
                          Its amazing plugin! THANK YOU. May I ask, it is possible to get plugin button to put in in toolbar? Or how I can do it myself?
                          Dave RD 1 Reply Last reply
                            Dave R @Requisher
                            @Requisher You could learn to do the Ruby coding and add a toolbar. Might be easier to just create a keyboard shortcut for it.
