    [Plugin] CopyAlongCurve 1.0.4 (28 February 2017)
    16 Posts 14 Posters 29.7k Views 14 Watching
    • jenujacobJ
      jenujacob
      Wow... thats on steroids!!!! Thanks!!!
      Sent from my SM-T815 using Tapatalk
        Hyper tricky! 😎
        Of course the more interesting is use Components! πŸ˜‰
        And if you group the result and re-apply the plug
        you will obtain a galaxy in no time! πŸ’š
        • B
          Ben Ritter
          Anton,
          Thank you for being generous to share.
          • Bob JamesB
            Bob James
            Excellent extension. Very similar to sdmitch's "Component_String".
            • P
              Pherim
              This is great, thank you!
              • alvisA
                alvis
                Thank you very much. Very accurate.
                • P
                  pxorduna
                  Hello Anton,
                  I got this error message after install the plug in and open Scketchup up
                  (I have ScketchUp Version 8.0.164846, Windows 7 64bits.)
                  ( I don't see the Extension Option at Menu )
                  Error Loading File C:/Program Files (x86)/Google/Google SketchUp
                  8/Plugins/ams_CopyAlongCurve/main.rb
                  undefined method new' for Length:ClassError Loading File ams_CopyAlongCurve.rb undefined method new' for Length:Class
                    Anton_S
                    Hello, Alejandro,
                    It is fixed now. Thank you for the report.
                    Regards,
                    Anton
                      mriedel
                      Great plugin. Works as advertised. Flexible. Most importantly, I was able to start using it productively -- without reading any documentation -- within seconds of installing it.
                      • sketchartist023S
                        sketchartist023
                        Trying to use this and it isn't working for this particular curve. The curve was a hand made line that I used TIG's weld tool to make it a curve. Weird thing is, it worked on the other curve just fine. Any thoughts? The object is a group, solid too btw, 0 errors with FixtIt. The line is shown as a curve as it has been welded. I have tried both closed and open curves. TY if you can help πŸ˜„
                        https://i.postimg.cc/V6s8Lt98/error1.png
                        [/url]
                          Share the .skp file so we can see what you have set up exactly. I just made up something that looks similar and it worked fine for me.
                          What version of SketchUp are you using? Please complete your profile.
                          • K
                            KropocLeckor
                            Marvelous. Just Marvelous and Easy to use.
                              Requisher
                              Its amazing plugin! THANK YOU. May I ask, it is possible to get plugin button to put in in toolbar? Or how I can do it myself?
                              Dave RD 1 Reply Last reply
                                Dave R @Requisher
                                @Requisher You could learn to do the Ruby coding and add a toolbar. Might be easier to just create a keyboard shortcut for it.
