    fredo6 licences
    31 Posts 4 Posters 987 Views 4 Watching
    • F Offline
      filoufil
      Hi, I'd like to reset my plugin licences because I'm having problems using them on 2 different computers.
      I think there are some old installations on an old PC... and this is blocking the number of licences. ?
      What should I do?
      Fredo6 Plugins Information on 2025-01-09 15:36:18 +0100
      • Sketchup: 24.0.594
      • LibFredo6: v15.0a
      • LibFredo6 Binary loaded
      • Sketchucation ExtensionStore: 4.4.1
      • SCFLicense: v6.4a - 74
      • Fredo6 Plugins
        Curviloft v2.0a - licensed FULL
        FredoScale v3.6a
        FredoTools v4.5c
        JointPushPull v4.8a - licensed FULL
        RoundCorner v3.4a - licensed FULL
        ToolsOnSurface v2.6a
        TopoShaper v2.7a
        Signature File: 2023-04-12 20:07:26 +0200
        Curviloft: 2023-09-25 08:39:17 +0200
        JointPushPull: 2024-09-18 11:24:27 +0200
        RoundCorner: 2023-09-25 08:40:05 +0200
      Merci
        Email support@sketchucation.com and we can walk you through it
        • F Offline
          fjsgruppe
          I am on a win 10 workstation with 2 Monitors.
          Hope I use the right place to ask for help:
          Every time I start Sketchup there is trouble with Fredos plugins:
          It starts with showing this message:
          Script Animator is loaded but menus will show up only at next startup of
          Sketchup
          SU continues showing the same message for :
          Curviloft, Curvizard, FredoGuides, FredoPortrait, FredoScale,
          FredoSketch, Fredo Spline, FredoTools, HoverSelect,
          JointPushPull, Layport, MatSim, MoveAlignMe, Mr.Hide,
          RoundCorner, ThruPaint, ToolsOnSurface, TopoShaper, VisuHole,
          Axyz (21 klicks).
          then, in the lower right corner it shows:
          Lord Of The Toolbars
          Some extensions are referenced in palettes but not loaded
          C:/Users/fjSchüssler/AppData/Roaming/Sketchllp/Sketchll
          p 2024/SketchUp/Plugins/Fredo6
          _Souvenir/IMAGES_Standard/SouvenirJcon_History_Last
          [1]
          c:/users/fjschüssler/appdata/roaming/sketchup/sketchup
          Kann mir jemand helfen?
          Y a t il personne qui peut m'aider?
          Beste Grüße nach Frankreich
          Regards
          fjs
          TIGT Rich O BrienR 2 Replies Last reply Reply Quote 0
            Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
            • TIGT Online
              TIG Moderator @fjsgruppe
              @fjsgruppe said in fredo6 licences:
              As well as doing what Rich asks, please confirm you have the latest versions of LibFredo6 [for vital helper files and our SketchUcation toolset installed [for the licensing].
              And your Windows user-name doesn't follow Windows guidance as it contains an umlaut...
              If all else fails try changing your user-name to fjSchussler or fjSchuessler ?
              • F Offline
                fjsgruppe
                I hope I could solve the biggest Problem.
                The mind.sight.studios plugin DoubleCut had some problems validating my license. I wrote Dale, and we solved the problem.
                Since then - i wonder why - there ist just one problem left with fredo6 left: LordOfTheToolbars.
                The rest is OK I tested it 3 times!
                This is the requested information:
                Fredo6 Plugins Information on 2025-01-14 15:36:34 +0100
                • LibFredo6: v15.0a
                • Fredo6 Plugins
                  LordOfTheToolbars v2.9c
                  Animator v4.1a
                  Curvizard v2.5a - licensed FULL
                  FredoGuides v2.7a
                  FredoPortrait v2.9a
                  FredoScale v3.6a - licensed FULL
                  FredoSketch v1.5a
                  FredoSpline v2.6a
                  FredoTools v4.5c
                  HoverSelect v1.5a
                  Layport v1.2a
                  MatSim v1.4a
                  MoveAlignMe v1.4a
                  MrHide v1.8a
                  ThruPaint v2.8b - licensed FULL
                  ToolsOnSurface v2.6a - licensed FULL
                  TopoShaper v2.7a - licensed FULL
                  VisuHole v1.5a - licensed FULL
                  Axyz v1.0a
                  Signature File: 2022-05-14 16:28:40 +0200
                  Curviloft: 2023-08-20 17:08:32 +0200
                  Curvizard: 2023-08-20 17:06:54 +0200
                  FredoScale: 2023-08-20 17:08:06 +0200
                  JointPushPull: 2023-08-20 17:09:24 +0200
                  PieBeta: 2022-05-15 12:45:17 +0200
                  RoundCorner: 2023-08-20 17:10:03 +0200
                  ThruPaint: 2024-06-05 13:36:52 +0200
                  ToolsOnSurface: 2023-08-20 17:01:15 +0200
                  TopoShaper: 2023-08-20 17:07:32 +0200
                  VisuHole: 2023-08-20 17:06:03 +0200
                  re
                  fjs
                • TIGT Online
                  Try the user-name solution I mentioned...
                  PS: does the computer's name contain any non ASCII characters ?
                    Rich O Brien Moderator @fjsgruppe
                    Can you rename your device to not use special characters?
                    • F Offline
                      fjsgruppe
                      Hi TIG,
                      Hi Rich,
                      my computer is on the company network and I'm afraid of doing something wrong - I have no idea about networks and I'll better ask our network specialist.
                      I will probably be able to change the name of the local PC.
                      Schöne Grüße aus Deutschland
                      Franz-Josef
                      TIGT 1 Reply Last reply Reply Quote 0
                      • TIGT Online
                        @fjsgruppe
                        There are two possible places that might be tripping things up.
                        One is user Windows user-name - as I explained:
                        It doesn't follow Windows guidance as it contains an umlaut...
                        Try changing your user-name to fjSchussler or fjSchuessler ?
                        It needs just ASCII characters and some limited punctuation are required
                        Two is your computer-name [IT might need to address that].
                        Again, the name's characters requirement is much as stated above...
                        • F Offline
                          fjsgruppe
                          I see!
                          Thanks, I do that as soon as possible and will you the results!
                          re
                          fjs
                          • F Offline
                            fjsgruppe
                            Unfortunately ‘fjSchüssler’ is the name of the initial registration.
                            So it’s a risk and a lot of work to change that.
                            And windows seems to tolerate the ‘ü’.
                            What I found out:
                            There may be some problems with the ‘plugin manager’ and ‘Lord Of the Toolbars’[LOT].
                            Plugins activated or not activated, even deleted plugins or plugins I am sure of never integrated in LOT show up in the error message.
                            Thanks for your advise.
                            I managed to come around by storing/using some new templates.
                            re
                            fjs
                            • F Offline
                              fjsgruppe
                              Strange:
                              As a test I deleted an extension (medeek…), ended he program, started it again and SU showed an error belonging to the deleted extension!?
                              2024/sketchup/plugins/medeek_project_ext/images/layout
                              Jcon [1]
                              • F Offline
                                fjsgruppe
                                I changed the user-name but Sketchup wont let me change the path to the templates
                                • F Offline
                                  fjsgruppe
                                  Because the path is no longer correct, Ican no longer save templates.
                                  • TIGT Online
                                    Try repairing, or reinstalling SketchUp whilst in the other named user-account, that should use the correct path without the umlaut.
                                    How did you change the user-name ?
                                    What does Windows think your username is ?
                                    • F Offline
                                      fjsgruppe
                                      Hi TiG,
                                      reinstalling/repairing gives an error and installation has to be stoped.
                                      See picture.
                                      Program is looking for the 'Schüssler'-path.
                                      re
                                      • F Offline
                                        fjsgruppe
                                        And I can't store templates anymore, because SU is trying to store them under the 'Schüssler'-path too.
                                        • F Offline
                                          fjsgruppe
                                          And this is shown by windows- User:
                                          • TIGT Online
                                            How did you rename the user-account ?
                                            Can you revert it back and make a new account 'FJS' and transfer all of your settings over to the new account ?
                                            There's lots on line about that...
                                            e.g.
                                            https://learn.microsoft.com/en-us/answers/questions/914152/link-the-new-user-profile-to-existing-user-profile
