    [Plugin] TextureRandomizer
    52 Posts 16 Posters 56.5k Views 16 Watching
    • N
      noldo
      Hi TIG, thanks for the plug-in. It would be handy to have an option to fix the offset for textures evenly within groups.
      When you have groups with two or more internal faces often the texture is continuous and due to the way the plug-in is structured now this continuity is interrupted, because the faces are treated separately.
      Would it be feasible?
        You can copy the UV mapped texture you've set, using the eyedropper tool that's part of the native Material tool, to select it, then paint the adjacent surfaces with the texture so the UV mapping matches across the facets...
        • N
          noldo
          I have not explained myself well, I try to upload a video to explain myself better.
          After randomizing, the alignments become misaligned.
          An option would be needed to fix one (and only one) random offset for each group / component.
          2022-07-23 17-03-52.mov
            Then the various faces' textures' randomization is no longer random !
            They'd all be the same using your rules...
            So if that's what you want, edit one face's texture and transfer its UV mapping to other faces using the eyedropper tool...
            Then they match, but have a random 'seed' to start with...
            • I
              ionutzor
              Hello,
              Just donate to you and don t see button to download
              Please help
                The Download button is the red one in the PluginStore listing.
                If you are using the ExtensionStore³ then it's a similar button saying Install, as no RBZ is needed as it's done automatically...
                • TutorialsUpT
                  TutorialsUp
                  Hi, TIG Thanks for the extension
                  Can you please answer this question please, somebody, asks on my recent video? https://youtu.be/OCmKV7Rb7bQ
                  "Any idea how this works for attached maps? Like for Enscape? Does the bump map align with the texture?
                    I think there's no connection between the two, but why not try it and report back...
                      sada1078
                      Thanks very much 👍 ! Really was looking for a tool like this for easy floor customization...
                      • B
                        bsfranza
                        hi there, its normal that in su 2024 it does not work with nested geometry? groupds and instances only are supported with one depth step 😕
                          After a hiatus of 14 years, here's v1.4
                          Please re-read the edited usage in the first post in this thread:
                          https://community.sketchucation.com/topic/133971/plugin-texturerandomizer
                          Download it from the PluginStore page or ExtensionStore dialog within SketchUp.
                          https://sketchucation.com/pluginstore?pln=TextureRandomizer
                          NOTE how the code and interface was revisited by myself and raumstaerke.de , who added a single dialog for settings using AI.
                          C 1 Reply Last reply
                          • C
                            carteblanche @TIG
                            @TIG I would like to thank you ! It's a really simple & powerful plugin to quickly handle texture. So glad you've just made an update.
                            Great job and thanks again !
                            • 3 / 3
