    Component Axis
    14 Posts 3 Posters 606 Views 3 Watching
      danna
      Trying to create vertical faces and save as components on 45 deg angle.
      Draw guidelines and create vertical face.
      Create component and first thing I do is "Set Component Axis"
      Adjust the axis to my guidelines.
      Bring it into new drawing and it does not come in on the 45 deg angle.
      Help !
      • BoxB Offline
        Realistically we can only guess at your workflow, attaching a model would allow someone to point you in the right direction.
          danna
          Thanks for the reply .... basically what you see in above image.
          I created the vertical face on the default axis
          Added 45 deg guidelines
          Rotated vertical face to 45 deg
          Created component and set its axis to the 45 deg guidelines
          Saved component in drawing and also saved component to folder to use in another drawing.
          When bringing component into new drawing ... I expected it to be on the 45 deg angle, but it is not.
          It is on the default axis.
          • BoxB Offline
            I've tried a bunch of ways to get this and it still 'works'.
            As I mentioned we need to see your model or we just waste time guessing.
            D 1 Reply Last reply Reply Quote 0
              danna @Box
              @Box said in Component Axis:
              I try to attach SU file.
              Component does not come in at 45 deg angle in which it was created or what I assumed to be created.
              Component_Angle_Test.skp
              • BoxB Offline
                Classic case of not understanding what a component is.
                Import your saved component and see how it is aligned.
                A bit too tired just now to explain.
                But your model is a closed version of your saved component and if you open it it will align with the world axis, but if you import or insert it into another model it will be at 45 deg.
                  danna
                  I agree 100% ... not understanding.
                  When I open in another drawing ... it does not come in at the 45 deg angle.
                  Thanks ( get some rest, ( smile )
                    danna @Box
                    The image below is from new drawing / model.
                    The components were saved to an external folder when created.
                    BoxB 1 Reply Last reply Reply Quote 0
                    • BoxB Offline
                      Box @danna
                      @danna
                      You can see here the difference between Opening your file and Importing your file.
                      Understanding components is a fundamental.
                        danna
                        Thanks for your time BOX.
                        But know where closer to understanding why mine does not work.
                        Hoping someone will come along and explain why mine does not work and how to fix it or help me understand.
                        • BoxB Offline
                          Box @danna
                          @danna said in Component Axis:
                          Obviously wasted.
                          Good luck moving forward and finding someone you can understand.
                            danna @Box
                            Obviously wasted.
                            Surely not my intent ... just asking for someone to explain what I was doing wrong, to stop it from working for me.
                            • TIGT Online
                              If you set the component's axes to match its face then it's no longer rotated at 45° when it's saved out of the model.
                              Just leave its axes as the default [45° off the face], and then it'll import into another model rotated as you hope, because then the component's geometry is not exported as axial.
                                danna @TIG
                                @TIG said in Component Axis:
                                Thanks very much for explaining my error.
