    Fredo6 or SketchUcation Extension Issue
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    6 Posts 3 Posters 330 Views 3 Watching
      SilentFart
      Hello, Can you help?
      I run Sketchup Pro 2024.
      I have SketchUcation latest version.
      I have LibFredo6 latest version.
      Upgraded to licenced version Fredo6 ThruPaint 2.8a.
      ThruPaint shows in my Sketchup extension manager, shows in SketchUcation extension manager, shows that it is licenced, but I can not find or use the extension in Sketchup Tools or Extensions.
      Where is it hiding?
      Any help would be much appreciated.
      Many Thanks
      Sean P.
      TIGT 1 Reply Last reply Reply Quote 1
        SilentFart @TIG
        @TIG
        hey Tig, The issue was with LibFredo6, I had to download & install version 14.8, I assumed that the version of Libfredo6 that was installed was upto date & correct.
        Thanks for your responses.
        Dave RD 1 Reply Last reply Reply Quote 1
        • TIGT Online
          TIG Moderator @SilentFart
          @SilentFart
          You need to restart SketchUp after it's installed to sync everything.
          After that it's listed under the menu 'Tool's > 'Fredo6 Collection' submenu, as 'ThruPaint'....
          S 1 Reply Last reply Reply Quote 0
            SilentFart @TIG
            @TIG
            Thanks Tig, Ye I had restarted to no avail.
            • TIGT Online
              @SilentFart
              But you haven't mentioned the next step where I gave you the exact menu-path to it...
              Tools > Fredo6 Collection submenu, as 'ThruPaint'....
                SilentFart @TIG
                @TIG
                • Rich O BrienR Rich O Brien marked this topic as a question on
                  Dave R @SilentFart
                  @SilentFart If you use the Sketchucation ExtensionStore to install Fredo6's extensions, including LibFredo6, you can use it to help you keep track ofupdates when they come and update them. You have to have the ExtensionStore installed for management of the extension licenses so you might as well use it to install the extensions.
                  In addition to helping you track and update extensions, you'll create a bundle of extensions from Sketchucation that you can install automatically if you switch computers or when you update to the next version of SketchUp.
                  Edit to add:
                  Fredo6 just released an update to LibFredo6. The Sketchucation ExtensionStore shows the update is available.
                  The red bell indicates there's an updated extension.
                  Clicking on it reveals the extension needing to be updated.
                  Clicking on the red download button updates the extension.
