    How can I model this?
    8 Posts 5 Posters 367 Views 5 Watching
      Does anyone Know how to model these stair ends? Screenshot 2024-11-28 145007.png.jpg
      N 1 Reply Last reply Reply Quote 0
      • N Offline
        nlipovac @L i am
        @L-i-am I would try this way:
        1. Draw curves flat and weld them together.
        2. Copy it vertically, use Vertex tools with Soft selection radius, and adjust the heights of that curve.
        3. Use Curviloft - Loft by Spline to make a surface.
        4. Use Joint Push Pull to add thickness.
        5. Add a cylinder to match the bottom curve, (in my case I use a circle for the last part of that curve).
        6. Join them with Solid Tools.
        stair_end_v1.skp
          L i am @nlipovac
          @nlipovac Thanks so much, I dont have many plugins and not the ones you mentioned. I used your model thanks againπŸ‘ πŸ‘
            @L-i-am You can also try Smoove that is under the native Sandbox menu
              • BoxB Offline
                You could also try Chris Fullmers Shape Bender. Note how tapping the up and down arrow changes the preview, and then Enter to complete. I through the ellipses in to show how it reshapes things.
                • Gus RG Offline
                  Gus R
                  I used CurviShear on the plan view for the curves here then extruded with Eneroth Upright Extrude for the wall. I think your curves might be more helical.
                  www.instagram.com/gusrobatto/
                  www.facebook.com/gusrobatto
                  • Gus RG Offline
                    Gus R
                    I think what you want is like a variable pitch helix. The curve of the helix begins from a horizontal plane then begins the helix and at the top the pitch transitions to another horizontal plane. In Sketchup you'd have to mess with the line segments. I tried finding something in Blender and haven't found anything. I'm still a novice with that. It looks like Solidworks and Rhino can do something like that.
