    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 346.6k Views 17 Watching
    • mark_in_seattleM
      mark_in_seattle
      @halroach said:
      Hi Mark,
      1. Regarding the units not displaying correctly, does this happen with all the Flex components from the toolbar? Or with other dynamic components?
      2. In order for wall cutting to work correctly when placing a window from the toolbar, it will automatically glue to the surface plane it is FIRST placed on.
      a. It is easiest to place the window anywhere on the wall you need it to be on, and then scale and move it to it's exact location.
      b. If you need to copy the window around, try with copy and paste. When it is pasted it will again try to glue to the surface that is under your mouse (repeat a. above).
      Very much appreciate your quick reply to help me use this very powerful extension tool correctly. My system is an iMac with macOS Catalina, running SU-2021-Pro (v21.1.331)
      1. After more testing, measurement units are correct (for me in inches) except when I first tried to place a "fixed window" that was oriented along the X-red and Y-blue axis, onto a non-coplaner wall surface that was rotated 45-degs away from the X (red) axis. I had hoped the FlexTools component would automatically orient itself to the 45-deg wall surface under the cursor, but it didn't. The new "fixed window" dynamic component didn't really stick because the wall and window were not in the same plane. I rotated the "fixed window" 45-degs to match the wall surface (also a component). At that point when I inspected the "fixed window" DC attributes(?) the dimensions were metric. Since then the few FlexTools DC's I've inspected did correctly show imperial units in inches, same as my model's units.
      2. As an inexperienced user, cutting a clearance hole in my test wall using FlexTools "fixed window" is still a hit or miss task. My test wall: a component, is only 3/8" thick composed of two surfaces, however when I dragged the "Fixed Window" FlexTools icon from the toolbar and placed it onto a test wall that was co-planer it did stick to the wall surface, however no hole was cut. Enabling the "Wall Cutter Tool" --> [Convert to Wall Cutter] did not show any immediate results. A hole for the new window only appeared in the wall when I moved the window and then unexpectedly a second new hole also appeared in the 45-deg rotated wall in the spot where I had attempted to add the window after rotating it 45-degs to match the wall rotation. In the "Wall Cutter Tool" window when I clicked --> [Convert Back to Normal] the new window disappeared entirely, .... then clicking --> [Convert to Wall Cutter] the new window component re-appeared but oriented flat on the ground plane .... very odd behavior. What I am most concerned about: in using the FlexTools "Wall Cutter Tool" will random component holes become inserted in various surfaces, perhaps those not currently in view and I will only discover them after saving my model, when getting back to previous model versions without the unintended "window holes" is more difficult ?
      a) OK, but what is the correct procedure for placing FlexTools DCs onto non-global-axis planer surfaces which I need to do in my model since some important surfaces need windows and are rotated 45-degs ?
      I have attached a screenshot that shows my two test wall surfaces and the results of experiments with the beveled top fixed window DC. At one point FlexTools created (4) cutout holes when only one was expected. The window on the ground plane was the result as described above trying to using the "Wall Cutter Tool" --> [convert to Wall Cutter] followed by --> [Convert back to normal].
      Thank-you again for your reply.
      Only one cutout hole was expected but (4) appeared
      ![Use of "Wall Cutter Tool" --> [Convert] button gives unexpected results](/uploads/imported_attachments/qO3r_ScreenShot2022-02-21at11.26.59PM.png "Use of "Wall Cutter Tool" --> [Convert] button gives unexpected results")
      • halroachH
        halroach
        1. It's hard to tell what happened with the units being in metric. If it happens again, let me know and send me the model.
        2. The reason you were getting multiple openings is because the walls were identical components. You have to Right Click > Make Unique on one of the walls and then each one is independent.
        Yes, walls should be components (and not groups) but you have to make sure they are unique if placing a wall cutter onto them.
        1. I recorded a quick video showing how to place the windows correctly.
        FlexTools - Super Quick Windows, Doors, Slats...
        • halroachH
          halroach
          A new update was recently released!
          • New flip tools
          • L-shaped stairs
          • Improved wallcutter workflow - it now works with groups!
          • Improved fence
          • New features…
          • Important fixes
          See the highlights in the blog.
          Read the full release notes
          Your feedback is always welcome! What you liked, what you didn't, what you want next...
          • halroachH
            halroach
            Black Friday - Cyber Monday season is here.
            Get FlexPack Pro with 30% OFF!
            https://flextools.cc/black-friday/
            Sale ends on Dec 5th.
            • JClementsJ
              JClements
              Did the trim request mentioned above ever get resolved? If so, where in the UI?
              I noticed in the Tag Panel (SU2012) that a "Layer 0_skin" had been created.
              When does that get generated and what purpose does it serve?
              • halroachH
                halroach
                @jclements said:
                1/14/2023
                There was trim request mentioned in one threads a long time ago which I believe was to add trim out onto a walls surface. Was it ever implemented. If so, where in the UI can it be specified.
                Unfortunately we haven't released anything for trim yet...
                @jclements said:
                1/14/2023
                That tag is not from FlexTools. It must be from some other extension you have installed.
                • halroachH
                  halroach
                  We haven’t done any promotions all year, buy hey! It is Black Friday today! 😎
                  Get 30% OFF the first year - https://flextools.cc/black-friday/
                  • halroachH
                    halroach
                    Update your FlexTools!
                    • Up to 3X faster performance of Flex components 😄
                    • Updated Spanish translations - (Special thanks to Rafael Teresa for the hard work!)
                    • Updated door component (See the release notes).
                    (FlexTools Extension v2.13.0)
                    (FlexPack Pro v1.37.3)
                    See here how to update.
                    • Gus RG
                      Gus R
                      Finally re-upped my Flex Tools subscription with the Black Friday discount. My rendering work input is slow.
                      Any chance we can get exterior window trim options for the windows? That would be really handy.
                      www.instagram.com/gusrobatto/
                      www.facebook.com/gusrobatto
                      • halroachH
                        halroach
                        Black Friday - Cyber Monday season is here!
                        Get FlexPack Pro with 30% OFF! for the first year.
                        (For new customers and additional licenses).
                        Sale ends on Monday Dec 9th 2024.
                        https://flextools.cc/black-friday/ 👈
                        • 9 / 9
