    Fredo6 Curviloft not working
    13 Posts 4 Posters 372 Views 4 Watching
      Midnyte Newcomers
      I am having trouble using Curviloft. Nothing is happening after clicking the lines and trying to generate the geometry.
      Hopefully someone can help me figure out what's wrong.
      I performed clean install of everything.
      • Rich O BrienR Online
        Rich O Brien Moderator @Midnyte
        @Midnyte Can you share the skp file?
        In your 1st example the picking order is rather odd...5-2-1-3-4
        In your 2nd its hard to decipher what it is you are trying to surface
          Midnyte Newcomers
          Sure here is the file.Spline for Curviloft.skp
          I am trying to do Loft by spline on the first image and Skin contour on the second image.
          Rich O BrienR 2 Replies Last reply Reply Quote 1
            @Midnyte
            #2 works for me
              @Midnyte
              #1 works for me too
                Midnyte Newcomers
                The plugin is not generating anything after the clicks on my side.
                  @Midnyte
                  Did you restart SketchUp after installing?
                  Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                    Midnyte Newcomers
                    Yes I restarted and clean install everything. I provided videos for clearer understanding.ScreenRecorderProject2.mp4 ScreenRecorderProject3.mp4
                      @Midnyte
                      Your 1st video shows that there's a missing #1 spline
                      Your 2nd shows there's a helper alert as to why it won't surface.
                      But there's still the missing info for Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support that fills in more blanks for me.
                      I did the same steps as you on SketchUp 2023 and it works
                      K 1 Reply Last reply Reply Quote 0
                        khelll Newcomers @Rich O Brien
                        @Rich-O-Brien same issue here, can't get my curviloft to work
                          Dave R @khelll
                          @khelll what exactly happens when you try to use it? What version of SketchUp are you using? What operating system? Do you have the most recent version of LibFredo6 installed? Do you have the most recent version of Curviloft? Do you have the latest version of theSketchucation ExtensionStore installed? Have you purchased and activated the license for Curviloft?
                            khelll Newcomers @Dave R
                            @Dave-R My aketchup cersion is skp pro 2023 and yes I have the most recent version of libfredo6, curviloft and sketchucation extension store. but i did not purchased any license
                              Dave R @khelll
                              @khelll said in Fredo6 Curviloft not working:
                              This is perhaps a problem for you since a license is required to use the extension.
