    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 222.6k Views 57 Watching
    • jed clampitJ
      jed clampit
      i scaled it up by 2000 but still didn't work
        it's that i suspected! 😄
        You must make UV (or similar) on your target object!
        Fredo Corner or similar don't make it!
        Here a complex one surface with recesses like your that works perfectly! 😄
        (but without "concentric" facetts)
        • E
          eue
          why can not see tool bar and error flowify plugin in sketchup
            What toolbar? There isn't one for this extension. It is accessed from the Extensions menu.
            What error exactly?
            What version of SketchUp are you using?
            • C
              camilamichalouski
              Hello Caul,
              The plugin doesn´t work to SU 22. It´s possible to update?
              Thank you in advance,
              Cami
                Flowify dpes work in SketchUp 2022. Looks like your model isn't set up correctly. Share the file so we can see what you've got going on.
                • panixiaP
                  panixia
                  Not necessary to upload the file, the screenshot clearly reveals that problem was between chair and keyboard.
                  Flowify requires you to select BOTH the component and the flowify rig at the same time before you run the command.
                  The guy has only the rig selected and not the stair component, so that the plugin doesn't work and of course ask for additional "input" (the beloved component).
                    R0bBot
                    This seems awesome and exactly what I would need...if I could have it working for my situation. Trying to add like a slime around a pot so I cut the pot in half, the geometry looks clean. I followed the instructions but when I tried to impose grid nothing happens. And when I try to flowify it, I get an error "error while parsing the projection grid". not sure what im doing wrong
                    • robertWanR
                      robertWan
                      There is no chance for the plugin to work in SU8?
                      Robert
                        Rey2024 Newcomers
                        Hello everyone, how can i use this plugin in sketchup 2022 because this plugin isn't work, it seems like i download the plugin but doesn't appears when i trying to activate
                        • E
                          erikcoleman1992
                          i cant find the license to flowify plz help
                          panixiaP 1 Reply Last reply
                          • panixiaP
                            panixia @erikcoleman1992
                            @erikcoleman1992 it's a free plugin.
                            • G
                              gibblersnort
                              Hi. I can't seem to get this plugin to work in su 2017. I draw a grid, then pick the smooth tool but nothing happens. Nothing is highlighted on the grid plane when I hover the cursor over it.
                              • panixiaP
                                panixia @gibblersnort
                                @gibblersnort sorry for the late reply, can you share a screenshot of your problem?
                                The plugin is not supposed to highlight anything.
                                You have just to select a grop than you want to deform and a PROPER "flowify rig" and then run the command.
                                • 7 / 7
