    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 726.0k Views 99 Watching
    • fredo6F
      fredo6 @Mike Backman
      @Mike-Backman
      Just in case could you open the Default Parameters dialog and uncheck or check this option
      M M Mike AmosM 3 Replies Last reply
      • G
        GiordanoBernard92
        Hello Fredo, thank you for another great extension!
        Just a question, the quick command search does not work anymore, is anybody else having the issue?
        fredo6F 1 Reply Last reply
        • fredo6F
          fredo6 @GiordanoBernard92
          @GiordanoBernard92
          Could you explain what exactly does not work.. Thanks
          G 1 Reply Last reply
            mlubel
            There is a bug in SU 23 and SU 24 extensions when creating New Personal Command (MENU) The list of available comments is missing...
            • fredo6F
              fredo6 @mlubel
              @mlubel
              Actually, access to menu commands has been removed from LOTT as of SU2023.
              This is because of a change of UI framework of Sketchup.
              D 1 Reply Last reply
                mlubel
                Ah, ok. Thanks for the info. It was nice to have that before.
                • fredo6F
                  NEW RELEASE: LordOfTheToolbars v2.7c - 20 Apr 24
                  Requirements
                  • LibFredo6: v14.3b or above
                  LordOfTheToolbars 2.7c is a maintenance release for:
                  • SU2024
                  • Fix for context menu in the palettes
                  Home Page of LordOfTheToolbars for information and Download.
                  Main post of this LordOfTheToolbars thread.
                    Ramzix @ltchest
                    @ltchest Hi, I know it's been 3 years but could you expand on that "Exclude" vray option?. I'm having the same issue here.
                    R 1 Reply Last reply
                      Ramzix @Ramzix
                      @Ramzix nwm, got it 😅
                      • G
                        GiordanoBernard92 @fredo6
                        @fredo6 I'm sorry it take me so much to reply, life got busy.
                        Basically nothing happens when I try to open the quick command finder, it does not matter if by the vignette stripe, the tools menu or the icon. Nothing happens
                        • fredo6F
                          @GiordanoBernard92
                          Can you confirm you installed the latest version of LibFredo6 and LOTT.
                          Also, can you open the Ruby Console before clicking on the Fnd icon, in case there are error displayed
                            DanyLecocq @fredo6
                            @fredo6 "En fait, l'accès aux commandes de menu a été supprimé de LOTT à partir de SU2023.Cela est dû à un changement du cadre de l'interface utilisateur de Sketchup."
                            Bonjour Fredo, en claire cela veut dire quoi, que dans une prochaine version tu pourras résoudre le problème, ou on peut oublier. Merci d'avance pour la réponse et félicitation pour la somme de tous tes travaux. 😉
                            • fredo6F
                              En trois mots : on peut oublier, sauf si Sketchup évolue son API.
                              • G
                                @fredo6
                                again, sorry for the late reply, I don't get email notifications for the forum.
                                Yes. both LibFredo6 and LOTT are updated.
                                Here is the ruby console dialog:
                                Error: #<RangeError: invalid codepoint 0xD83D in UTF-8>
                                c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:6125:in all_menus' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:6125:in menu_mapping'
                                c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:6203:in menu_structured_list' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsfinddialog.rbe:219:in prepare_data'
                                c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsfinddialog.rbe:136:in dialog_invoke' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmanager.rbe:5379:in minifind_invoke'
                                c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsvignettedialog.rbe:888:in minifind_invoke' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsvignettedialog.rbe:619:in dialog_callback_exec'
                                c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsvignettedialog.rbe:588:in dialog_callback' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2456:in call'
                                c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2456:in master_callback' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2221:in j_action'
                                c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2180:in j_callback' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2166:in block in j_dispatch'
                                c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2158:in each' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2158:in j_dispatch'
                                c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1436:in `block in create_dialog'
                                • C
                                  celovito
                                  Hi!
                                  I am having issue with Master Toolbar manager. It does not display my custom toolbars anymore... When I opened it for the first time it appeared and then when i tried to resize the window it disappeared and I cannot get it back to show again.
                                  • K
                                    Kmylpenter Newcomers
                                    I've created a custom toolbar with two personal commands as well as custom icons for them. When doing export/import from one PC to another, on the other PC custom commands loaded with missing icons. That would not be the problem but they're missing from the "Menu" list as well so Im unable to change the icons.
                                    Tried simply adding the personal commands once again but it resulted in duplicated command.
                                    Any tips on how to fix it?
                                    The extension is amazing, will pay! :))
                                      Mr0985960190 @fredo6
                                      @fredo6
                                      Hello Fredo6, Plugin LordOfTheToolbar 12.7C does not work on Sketchup 2024.0.553, right?
                                      Reply Quote -2
                                      • B
                                        bmcooper79 Newcomers
                                        LOTT is free for the time being. It has an expiration of 31-12-2024. Will this have a perpetual license going forward? It looks good but I want to make sure that this is going to be around.
                                          Mike Backman @fredo6
                                          @fredo6
                                          I tried the sticky button like you suggested I still need to go into my display settings and may my monitor my " main Monitor" other wise the vignette will remain stuck on my laptops screen
                                          • N
                                            NF_TM
                                            It was my very favourite feature and I used it all the time,
                                            Today, after downloading the latest version, the extension is no longer available.
                                            No matter how many times I download it, it does not appear in the tools.
                                            I would like to revert to one of the previous versions, from where can I download it?
                                            Thank you very much in advance.
