    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 689.7k Views 99 Watching
      RLGL @fredo6
      @fredo6 If I right-click on an icon there are no commands shown. This is using Win 10 (if that makes a difference).
      • fredo6F
        fredo6 @TECHDAVE02
        @TECHDAVE02
        It seems that the problem might be related to the Text Scaling factor in Windows, as per this post on the Sketchup Forum.
          rv1974
          @fredo6 My latest LOTT (win11, SU24) lost right click (on icons) menu shown by
          17628046164 6 posts above. Might it be fixed please?
            Mike Backman
            Does any on else have a major problem with Fredo lord of the toolbars and duel monitors? I came to terms with the fact that many SU plugins get lost when using multiple monitors. But i switched to a single monitor and my lap top. and lord of the tool bars is the only one that still is a pain. I need to make my external monitor the "main screen" in display setting just to have the vignette drag up to my big monitor off of my lap top I'm am still constantly losing the LOTB tools can any one help with this? any help with this I would appreciated.
            M 1 Reply Last reply
              Mike Backman @Mike Backman
              @Mike-Backman
              I replying to my own post. I discovered if you go into the "tool's Tab then "Fredo 6 Collection" then " Reset Vignette Stipe Position" the tools show up top dead center of the Screen. I wish more plugins had this feature. I am constantly losing dialog windows because i bounce between different monitors .
              Sill unresolved is the need to make the main screen option. I still can not get the vignette to show up on my big monitor un less i go into display settings and "make this main display"
              fredo6F 1 Reply Last reply
              • fredo6F
                fredo6 @Mike Backman
                @Mike-Backman
                Just in case could you open the Default Parameters dialog and uncheck or check this option
                M M Mike AmosM 3 Replies Last reply
                • G
                  GiordanoBernard92
                  Hello Fredo, thank you for another great extension!
                  Just a question, the quick command search does not work anymore, is anybody else having the issue?
                  • fredo6F
                    fredo6 @GiordanoBernard92
                    @GiordanoBernard92
                    Could you explain what exactly does not work.. Thanks
                    G 1 Reply Last reply
                      mlubel
                      There is a bug in SU 23 and SU 24 extensions when creating New Personal Command (MENU) The list of available comments is missing...
                      • fredo6F
                        fredo6 @mlubel
                        @mlubel
                        Actually, access to menu commands has been removed from LOTT as of SU2023.
                        This is because of a change of UI framework of Sketchup.
                        D 1 Reply Last reply
                          mlubel
                          Ah, ok. Thanks for the info. It was nice to have that before.
                          • fredo6F
                            NEW RELEASE: LordOfTheToolbars v2.7c - 20 Apr 24
                            Requirements
                            • LibFredo6: v14.3b or above
                            LordOfTheToolbars 2.7c is a maintenance release for:
                            • SU2024
                            • Fix for context menu in the palettes
                            Home Page of LordOfTheToolbars for information and Download.
                            Main post of this LordOfTheToolbars thread.
                              Ramzix @ltchest
                              @ltchest Hi, I know it's been 3 years but could you expand on that "Exclude" vray option?. I'm having the same issue here.
                              R 1 Reply Last reply
                                Ramzix @Ramzix
                                @Ramzix nwm, got it 😅
                                • G
                                  GiordanoBernard92 @fredo6
                                  @fredo6 I'm sorry it take me so much to reply, life got busy.
                                  Basically nothing happens when I try to open the quick command finder, it does not matter if by the vignette stripe, the tools menu or the icon. Nothing happens
                                  • fredo6F
                                    @GiordanoBernard92
                                    Can you confirm you installed the latest version of LibFredo6 and LOTT.
                                    Also, can you open the Ruby Console before clicking on the Fnd icon, in case there are error displayed
                                      DanyLecocq @fredo6
                                      @fredo6 "En fait, l'accès aux commandes de menu a été supprimé de LOTT à partir de SU2023.Cela est dû à un changement du cadre de l'interface utilisateur de Sketchup."
                                      Bonjour Fredo, en claire cela veut dire quoi, que dans une prochaine version tu pourras résoudre le problème, ou on peut oublier. Merci d'avance pour la réponse et félicitation pour la somme de tous tes travaux. 😉
                                      • fredo6F
                                        En trois mots : on peut oublier, sauf si Sketchup évolue son API.
                                        • G
                                          @fredo6
                                          again, sorry for the late reply, I don't get email notifications for the forum.
                                          Yes. both LibFredo6 and LOTT are updated.
                                          Here is the ruby console dialog:
                                          Error: #<RangeError: invalid codepoint 0xD83D in UTF-8>
                                          c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:6125:in all_menus' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:6125:in menu_mapping'
                                          c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:6203:in menu_structured_list' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsfinddialog.rbe:219:in prepare_data'
                                          c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsfinddialog.rbe:136:in dialog_invoke' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmanager.rbe:5379:in minifind_invoke'
                                          c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsvignettedialog.rbe:888:in minifind_invoke' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsvignettedialog.rbe:619:in dialog_callback_exec'
                                          c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsvignettedialog.rbe:588:in dialog_callback' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2456:in call'
                                          c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2456:in master_callback' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2221:in j_action'
                                          c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2180:in j_callback' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2166:in block in j_dispatch'
                                          c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2158:in each' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2158:in j_dispatch'
                                          c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1436:in `block in create_dialog'
                                          • C
                                            celovito
                                            Hi!
                                            I am having issue with Master Toolbar manager. It does not display my custom toolbars anymore... When I opened it for the first time it appeared and then when i tried to resize the window it disappeared and I cannot get it back to show again.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 27
                                            • 28
                                            • 19 / 28
