    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    699 Posts 161 Posters 643.9k Views 161 Watching
      Anton_S
      Hi all, the ClothWorks is now updated for SU2024. Thank you for your patience!
      F X 2 Replies Last reply Reply Quote 5
      • F Offline
        FlawinneF
        I receive an error message when importing a license.
        18-Apr-24 19:13:56 validate_response_error Error in the License Validation--Response from Sketchucation: License seats exceeded.
        18-Apr-24 19:00:51 validate_response_error Error in the License Validation--Response from Sketchucation: License seats exceeded.
        18-Apr-24 18:59:02 validate_response_error Error in the License Validation--Response from Sketchucation: License seats exceeded.
        18-Apr-24 18:58:45 validate_response_error Error in the License Validation--Response from Sketchucation: License seats exceeded.
        TIGT 1 Reply Last reply Reply Quote 0
          TIG Moderator @FlawinneF
          @FlawinneF
          Have you got the newest version of the SketchUcation Tools installed ?
          It handles the licensing system.
          You can also login to you own licenses on this site using the link in the Extensions > SketchUcation submenu... My Licenses at SketchUcation...
          https://sketchucation.com/webshop/my-licences.php
          There you can manage all of your licenses...
          F 1 Reply Last reply Reply Quote 0
          • F Offline
            FlawinneF @TIG
            @TIG thank you, it's activated
            • F Offline
              FlawinneF @Anton_S
              @Anton_S Why not fix the problem of the bar remaining active on Mac !!!
              if tb.get_last_state == TB_NEVER_SHOWN
                tb.show
              else
                tb.restore
              A 1 Reply Last reply Reply Quote 0
                Anton_S @FlawinneF
                @FlawinneF Thanks for that tip. I never knew about the get_last_state or restore. Will utilize in next release
                  TIG Moderator @Anton_S
                  @Anton_S
                  I use this usually
                  tb.show if tb.get_last_state.abs == 1 # TB_VISIBLE/NEVER
                  Has the same result...
                  A 1 Reply Last reply Reply Quote 1
                    Anton_S @TIG
                    Version 1.8.0 released.
                    • Fix adaptive grid not working properly for some models on Mac OS X
                    • Show toolbar properly on Mac OS X. Thanks @FlawinneF and @TIG
                    F 1 Reply Last reply Reply Quote 1
                    • F Offline
                      FlawinneF @Anton_S
                      @Anton_S
                      Sorry I didn't, say thank you sooner, thank you for everything ๐Ÿ™‚
                      • X Offline
                        xinige @Anton_S
                        @Anton_S Hello, Mr. Anton. I don't know when you will initiate the redevelopment of MSPhysics. As far as I know, countless people are looking forward to this project. Alternatively, you can develop a plugin that can partially implement certain functions.
                        For example, a simulation tool that can implement simulation functions similar to fusion360 and SolidWorks may not require embedding a physics engine (I'm not sure), but only adding axes and motors, as well as collision detection. Used for designing machinery, mechanical gif diagrams, and checking the rationality of mechanical design in sketchup. I hope to receive your reply.
                          rick149
                          Anton
                          ClothWorks is amazing
                          I still use MSPhysics because nothing else is as good at what it does
                          Can you supply me with code to
                          1. turn layers on and off
                          2. hide/unhide objects
                            for me to use with my variables, keydown,, ontouch and ontick events in my MSPhysics scripts
                            old msphysics video example here...
                            https://www.youtube.com/watch?v=MTfpvgY1HBk
                          • N Offline
                            Nicole_M_W Newcomers
                            Hello
                            i am a huge fan of the plug-in, however i ran into troubel. Recently when i try to use it, the UI Window its not visible - not sure if its opening, but the app runs and i can play the cloths. I allready try to reinstallations and restarts. Any idea whre can i find back my UI Window?
                            I am using multiple screens - also unpluging and classical Windows 11 windows search didnt help.
                              Rich O Brien Moderator @Nicole_M_W
                              @Nicole_M_W If click the toolbar icon fails to display the dialog then open the ruby console and click the icon and see it there are errors.
                              But since we don't know what version of SketchUp or Clothworks you are running its hard to say more really.
                              The also an extension by Dan Rathbun that resets dialog positions if they are off screen. Its call Dialog Cascader. Search for cascade and you'll find it in our Sketchucation Tools in SketchUp
                              N 1 Reply Last reply Reply Quote 1
                              • N Offline
                                Nicole_M_W Newcomers @Rich O Brien
                                @Rich-O-Brien
                                thank you! Excellent the Dialog Cascader solved my Problem right away. UI is back.
                                I am on
                                Clothworks 1.8.0a
                                Skechup Pro เปฟSketchUp Model๏ปฟเซฟ{24.0.553
                                just downloaded and installed the 24.0.0594 but i already applied your cascade solution so i can't tell if it was because of the missing update.
                                thank you for your fast help!
                                  @Nicole_M_W no probs. Dialogs playing hide and seek is common. Danโ€™s tool is a lifesaver
                                    Anton_S @xinige
                                    @xinige said in [Plugin] ClothWorks v1.8.0 - 28 Apr 2024:
                                    Thank you for this inspirational message! I got to get mpshysics back to life!
                                    • F Offline
                                      faust07 @Anton_S
                                      @Anton_S
                                      Did I read that correctly? - "I got to get mpshysics back to life!"
                                      Yes! Yes! Yes!
                                      That would be fantastic. When will the time come?
                                        rkdtlwo
                                        ์ปดํ“จํ„ฐ ํฌ๋ฉง์„ ํ•˜๊ณ ๋‚œํ›„๋กœ ๋ผ์ด์„ผ์Šค ์ธ์ฆ์ด ๋˜์งˆ์•ˆ๋„ค์š”
                                        ํ•ด๊ฒฐ๋ฐฉ๋ฒ•์„ ์•Œ์ˆ˜ ์žˆ์„๊นŒ์š”?
                                          TIG Moderator @rkdtlwo
                                          @rkdtlwo
                                          All of the 3 seats are allocated, presumably using your old computer[s] details.
                                          You need to free up the seats so that you can reactivate them for your new computer[s].
                                          If you have the latest versions of the extension and the SketchUcation toolset [for the licensing] installed, and SketchUp restarted to sync, you should be able to do this using the submenu items for the extension under the Tools menu.
                                          You can also manage each of your licenses by logging in to SketchUcation.com and using the menu item PluginStore > My Licenses... page...
                                          3๊ฐœ์˜ ์ž๋ฆฌ๋Š” ๋ชจ๋‘ ํ• ๋‹น๋˜์—ˆ์œผ๋ฉฐ, ์•„๋งˆ๋„ ์ด์ „ ์ปดํ“จํ„ฐ์˜ ์„ธ๋ถ€ ์ •๋ณด๋ฅผ ์‚ฌ์šฉํ•˜๊ณ  ์žˆ์„ ๊ฒƒ์ž…๋‹ˆ๋‹ค.
                                          ์ƒˆ ์ปดํ“จํ„ฐ์—์„œ ๋‹ค์‹œ ํ™œ์„ฑํ™”ํ•  ์ˆ˜ ์žˆ๋„๋ก ์ž๋ฆฌ๋ฅผ ๋น„์›Œ์•ผ ํ•ฉ๋‹ˆ๋‹ค.
                                          ์ตœ์‹  ๋ฒ„์ „์˜ ํ™•์žฅ ํ”„๋กœ๊ทธ๋žจ๊ณผ SketchUcation ๋„๊ตฌ ์„ธํŠธ[๋ผ์ด์„ ์Šค์šฉ]๊ฐ€ ์„ค์น˜๋˜์–ด ์žˆ๊ณ  SketchUp์„ ๋‹ค์‹œ ์‹œ์ž‘ํ•˜์—ฌ ๋™๊ธฐํ™”ํ•œ ๊ฒฝ์šฐ ๋„๊ตฌ ๋ฉ”๋‰ด ์•„๋ž˜์— ์žˆ๋Š” ํ™•์žฅ ํ”„๋กœ๊ทธ๋žจ์˜ ํ•˜์œ„ ๋ฉ”๋‰ด ํ•ญ๋ชฉ์„ ์‚ฌ์šฉํ•˜์—ฌ ์ด ์ž‘์—…์„ ์ˆ˜ํ–‰ํ•  ์ˆ˜ ์žˆ์Šต๋‹ˆ๋‹ค.
                                          SketchUcation.com์— ๋กœ๊ทธ์ธํ•˜์—ฌ ๋ฉ”๋‰ด ํ•ญ๋ชฉ PluginStore > ๋‚ด ๋ผ์ด์„ ์Šค... ํŽ˜์ด์ง€๋ฅผ ์‚ฌ์šฉํ•˜์—ฌ ๊ฐ ๋ผ์ด์„ ์Šค๋ฅผ ๊ด€๋ฆฌํ•  ์ˆ˜๋„ ์žˆ์Šต๋‹ˆ๋‹ค.
                                            Sara37 Newcomers
                                            Amazing plugin, great job๐Ÿ‘ I wanted to purchase a 1 seat license, since I wont be using Sketchup that often, but it is not currently available on the list, would it be available maybe in future?
                                            many thanks
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 34
                                            • 35
                                            • 23 / 35
