    CATENA PURSUE
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    14 Posts 2 Posters 293 Views 2 Watching
      CBrown Newcomers
      Hello. What does Catena Pursue mean? Please help!!!!!! This happened when I was using the Fredo6 FredoCorner extension in SketchUp. Now my laptop have frozen in this view. How can I fix this???
        CBrown Newcomers @Rich O Brien
        @Rich-O-Brien I've restarted SketchUp. Thank you Rich!
          CBrown Newcomers
          I'm sorry for posting again so soon, but I'm beginning to panick. Could someone help please!!
          • Rich O BrienR Online
            Rich O Brien Moderator @CBrown
            @CBrown Did you click ok?
            C 2 Replies Last reply Reply Quote 0
            • Rich O BrienR Rich O Brien marked this topic as a question on
              @Rich-O-Brien Hi Rich. No I have not been able to make any changes like turning off SketchUp. It is completely frozen in the above viewm
                @Rich-O-Brien sorry, yes I tried to click OK as well.
                  @CBrown Can you force quit SketchUp using Task Manager?
                  Sometime SketchUp will go into a 'thought loop' when you ask it to generate wild amount of geometry.
                  I can't see what it is you asked SketchUp to do other than 100mm wide bevel with 6 segments per bevel. You could just be hitting the upper limit of geometry generation?
                  Try forcing SketchUp to close. When you restart SketchUp use File > Open to open the file again and if there's an .skb file it will open that and ask you to save.
                  C 3 Replies Last reply Reply Quote 0
                    CBrown Newcomers
                    Hi Rich, I can't seem to download the book. A message says some fields are missing.
                      @Rich-O-Brien ok I'll try. I feel silly.....didn't realize the download the D'oh Book message is an advert lol...
                        @Rich-O-Brien oh, and yes. I was only asking the extension to do a simple task, so don't know what could have caused this.
                          @CBrown said in CATENA PURSUE:
                          Its not an advert. Its a free little book containing useful nuggets of info.
                          Just put in your name and email and we send you a download link.
                          It won't fix your FredoCorner issue though.
                            @Rich-O-Brien I managed to close SketchUp as you said. Sorry I took so long. I have to google how to do this. I'll wait a few minutes before turning on SketchUp again. Thank you so much your help!!
                              @Rich-O-Brien Ok, I will. Thank you Rich!
                                  No probs. Bevelling is not as simple to execute as it is to imagine. There are many factors to consider. If a bevel's width is such that it overlaps you'll run into issues.
                                  At least you're sorted now. So you can now take smaller steps before giant leaps!
