    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    452 Posts 111 Posters 577.2k Views 112 Watching
    • samuel_tS Offline
      samuel_t
      1.2.4 version:
      • Tries to preserve the original materials names. You should see less materials named <auto>1, <auto>2, etc.
      • Enhances compatibility for (non textured) 3MF files and IRR files, thanks to Assimp's contributors! 😊
      • Supports an unlimited number of embedded textures (previously the maximum number was 1000).
      • Includes an Assimp CLI tool compiled for the Intel Mac and Apple Silicon processors: M1, M2, etc. πŸš€
      Download latest Universal Importer plugin from SketchUcation PluginStore.
        AxiomNick Newcomers
        This post is deleted!
          AxiomNick Newcomers
            AxiomNick Newcomers
              AxiomNick Newcomers
                AxiomNick Newcomers
                Hi there, I'm having an error importing OBJ and FBX files with the same error. Screenshot 2024-05-09 164640.jpg
                The file was exported from 3ds max 2024 and imported into sketchup 2022.
                  giogrim
                  I'm trying to import the file highlighted in the following photo,File da importare.png but I get the following message.Errore Universal Importer.png
                  what should I do?
                  Thank you.
                    Gunner77
                    Hey There...just a quick question on compatibility with SketchUp 2024...is it?
                    ...the text states only 2023...I'm going to give it a try anyway, but just wondered...
                    samuel_tS 1 Reply Last reply Reply Quote 0
                    • samuel_tS Offline
                      samuel_t @Gunner77
                      Hey @Gunner77,
                      It should works on SketchUp 2024. Let me know if not.
                      • samuel_tS Offline
                        samuel_t
                        1.2.5 version:
                        • Provides finally a good support of STEP (AP203, AP214, AP242) files, thanks to the included Mayo command-line converter.
                        • Supports two new file formats: IGES (v5.3) and BREP, thanks again to the Mayo software and the Open CASCADE Technology.
                        Note 1: For the moment, reducing polygons when importing a STEP/IGES/BREP file is not possible. While waiting for a future version which will fill this gap, you can always reduce the polygons by clicking on the swan icon in the plugin toolbar.
                        Note 2: Although I can't confirm it, the import of STEP/IGES/BREP files should work on macOS as well.
                          RLGL
                          I tried the Universal Importer using a 3D step file from McMaster Carr of a bolt and nut. The bolt was 3/4" long. The import brought it in over 100" long.. Am I asking too much to have it come in at the correct scale?
                          • samuel_tS Offline
                            samuel_t @RLGL
                            @RLGL No but can I ask you for a coffee in exchange? I need more blood in my veins to fix the wrong scale problem πŸ˜…
                            MikeG73M 1 Reply Last reply Reply Quote 0
                            • MikeG73M Offline
                              MikeG73 @samuel_t
                              @samuel_t Hello Sam, this is a great extension, thank you. But it does not seem to support .blend files, very well. Is there a fix?
                              Cheers!
                              • samuel_tS Offline
                                samuel_t
                                Hello everyone πŸ™‚
                                The 1.2.6 version:
                                • Allows you to specify the source model units (millimeters, centimeters, etc). Most probable units, for the model you are importing, are preselected to accelerate the workflow. However, be still attentive with unitless formats such as OBJ, real scale depends on specifications.
                                • Automatically fixes, on SketchUp 2018 and newer versions, bad texture coordinates of some glTF models and "unexpected face count after polygon reduction" issue. If you are a SketchUp 2017 user, you will find a manual solution in the Troubleshooting FAQ of the plugin.
                                • Handles polygon reduction of STEP/IGES/BREP models during the import.
                                • Automatically fixes orientation of STEP/IGES/BREP models for last time? πŸ˜…
                                • samuel_tS Offline
                                  samuel_t
                                  @RLGL
                                  I think it's fine now. I imported with the Universal Importer v1.2.6 many STEP and IGES files from McMaster Carr and their scale is everytime correct in SketchUp. Be sure to let millimiters as "Source model units" when importing...
                                  • samuel_tS Offline
                                    samuel_t @MikeG73
                                    Hello @MikeG73
                                    Thanks πŸ˜‰
                                    Indeed, BLEND format support in this extension is limited to older .blend files and one must claim then map the textures manually...
                                    I hope to improve that in the future πŸ˜‡
                                    Cheers!
                                      RLGL
                                      I have the latest DL. Thank you for the update. The scale is now correctly imported.
                                      Dave
                                        sashapepperspray
                                        I have just updated the plugin and tried using it, and I get the following error:
                                        Universal Importer Error: Command failed: cd /d "C:/Users/tenen/AppData/Local/Temp/Universal Importer" && "C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/universal_importer/Applications/Assimp/Win/assimp.exe" export "export.dae" "export.obj" -tri
                                        I tried going to a previous version of sketchup, where I have an older version of the plugin, and I have the same error
                                        Do you know what this error is, and how I could fix it?
                                          sashapepperspray @sashapepperspray
                                          This is the complete error:
                                          C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/universal_importer/assimp.rb:106:in `convert_model'
                                          Universal Importer Version: 1.2.6
                                          I have tried uninstalling and reinstalling microsoft visual runtime, and I still have the problem.
                                          @samuel_t do you have any ideas about this? thank you
                                          • samuel_tS Offline
                                            samuel_t @sashapepperspray
                                            @sashapepperspray This error message indicates that the bug occurs when a polygon reduction is requested, in the SU viewport, with the plugin toolbar... but I don't know why.
                                            Have you succeeded in this operation with other 3D models? Or this operation fails everytime, whatever the 3D model?
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
