    [Plugin] PipeAlongPath
    122 Posts 58 Posters 168.0k Views 57 Watching
      @tampapowers said:
      Just installed in 2018, causes a crash.
      I just tried using it in v2018... and it worked just fine.
      What settings are you using ?
      What's the preselected path like ?
      A simple example SKP might help...
      • TampaPowersT
        TampaPowers
        This is the path: https://i.imgur.com/HOQ8AC1.png
        Settings are: https://i.imgur.com/6EdzK9f.png
        Sketchup Community Discord
          You can attach images and SKPs to your post.
          Without a SKP I can't be 100% sure, but I suspect you are falling foul of the tiny geometry issues that SketchUp has, that is if two points are within SketchUp's built-in tolerance of 1/1000".
          Then it cannot make that edge and any related face[s] can't then be made either !
          Your outer diameter of 3mm and internal diameter of 1mm will most likely try to produce some tiny facets - especially when you give it 12 sides, and it is following that very wavy path, which itself I guess has several small segments per wave ?
          The way to make something this small is as follows...
          • Create the path.
          • Make a component of it.
          • Make a copy to one side.
          • Scale the copy up by say x1000.
          • Re-zoom extents so that you see the giant copy.
          • Edit the copy and select the path.
          • Use the PipeAlongPath tool, adjusting the settings by the scale-factor - e.g. 3mm >>> 3m
          • When the pipe is successfully made, exit the edit and delete the giant copy.
          • Re-zoom to look at the normal sized instance and the very tiny geometry will be OK.
            Tiny geometry can exist, but you cannot create it at the tiny dimensions.
          Note that this tiny-geometry tolerance issue can affect many operations in SketchUp and its Extensions - the above fix works for all such cases...
          Any operation that might make tiny edges - like an intersect-with etc - benefits from this workaround...
          • TampaPowersT
            TampaPowers
            Scaled up by a factor of 100 it no longer crashes. Maybe build in an error if things get too small so it does not immediately crash?
              It already has some traps.
              For example if you do a right-angle bend with a very segmented pipe below a diameter of about 200mm the tiny inner facets will fail.
              It warns you.
              However the permutations of paths and diameters make it awkward to trap all situations - letting the user use their brains is good idea [IMHO]...
              The scaling up temporarily is a well known workaround for such potential problems, applicable in many situations...
              • C
                ct103stu0
                Thanks for this Plugin, it has made a huge difference in time to create piping schematics. I am trying to create elbows. I first tried creating arcs, and that works but difficult to create consistent configurations. I am now trying Fredo Corner and not having any luck. Can you suggest a method that would produce consistent elbow configurations. Thanks.
                  Can you share an example .skp file that shows what you are trying to do?
                  What version of SketchUp are you using? Is it still SU8 Free/Make as your profile indicates?
                    rehman1212
                    plugin not working in 2019 version
                      It does work in SketchUp 2019. Share your model so we can see what you are working with.
                        rv1974
                        @TIG PipeAlongPath and ExtrudeAlongPath are not working in 2024. They only create profile but fail extrude it aling the path.
                        Any chance to fix it please?
                        TIGT 1 Reply Last reply
                          TIG Moderator @rv1974
                          @rv1974
                          I just tested PipeAlongPath and it works fine in 2024 - what's your issue...
                          Do you have the newest v2.2 - but it is 10 years old !
                          ExtrudeAlongPath - what is that ? It's not part of the current Extrude Toolset and it's not in the PluginStore...
                            rv1974
                            @TIG thanks for reply!
                            I attach 2 old rubies of yours
                            ExtrudeAlongPath and TubeAlongPath:
                            [https://drive.google.com/file/d/1svirdxDbhq3Md3liCyr-Ne0LWeqY99yE/view?usp=sharing](link url)
                            I found that pipe along the path can (kinda) substitute the tube if inner radius is set to zero. My only complain is both Pipe and TubeAlongPath doesn't process multiple paths at once (I recall I humbly requested to improve it years ago )
                            There is still problem with ExtrudeAlongPath - I described it above, it doesn't extrudes. Could you please make it work in 2024?
                            P.S\Offtopic: Is the option to attach files in the NEW forum gone 😡 ?
                            Rich O BrienR TIGT 2 Replies Last reply
                              Rich O Brien Moderator @rv1974
                              @rv1974 said in [Plugin] PipeAlongPath:
                              P.S. Is the option to attach files in the "new" forum is gone ?
                              "no" try drag drop
                              R 1 Reply Last reply
                                rv1974 @Rich O Brien
                                @Rich-O-Brien good to know, thank you
                                  @rv1974 you're "welcome"
                                  R 2 Replies Last reply
                                    @Rich-O-Brien by "" I meant the new forum's design (skin) remaining in the same location. sorry if they hurt your feelings.
                                      lol, thanks for letting me know my feelings are hurt. i didn't realise
                                        @rv1974
                                        TubeAlongPath has been deprecated forever - PipeAlongPath replaces it.
                                        It is 16 years old and expecting a free plugin to be updated is unrealistic.
                                        I can't access any of them in your linked RAR file, but I see that ExtrudeAlongPath is 14 years old, and isn't even one of my plugins anymore, having been absorbed into my Extrude Toolset using some other name[s]...
                                        These tools never worked on multiple paths and this late request is unlikely to be fruitful - 😞
                                          This post is deleted!
                                            rv1974 @TIG
                                            @TIG
                                            [https://drive.google.com/file/d/1zs9zfTfJxDOgdMk7D--sGzRh40WTl2Sn/view?usp=sharing](link url)
                                            Sorry for rar file, I updated the link
                                            Author : TIG (c) - this is what I see in this rb file, how it could get stopped to be yours?
                                            Unfortunately Extrude Toolset is waay too less elegant and user friendly
                                            • 6 / 7
