    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      Version 3.5.2 - 03.02.2024
      • Added the following door types: 3/4 glass, double 3/4 glass.
      • Added a separate threshold material option for all man doors.
      • Added additional grille (grid) options for glass doors.
      http://design.medeek.com/resources/wallplugin/images6/wall_su741_800.jpg
      http://design.medeek.com/resources/wallplugin/images6/wall_su742_800.jpg
      http://design.medeek.com/resources/wallplugin/images6/wall_su743_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 3.5.3 - 03.06.2024
        • Added a "Panel" corner treatment for "End" and "Terminal" wall corners (rectangular walls only).
        • Fixed a javascript bug for window and door presets.
        • Fixed a bug with the door casing (custom casing options) and end cripple studs for pocket doors.
        • Rearranged the door casing section of the door Draw and Edit menus.
        • Fixed a bug with the advanced options for all wall types when using metric templates.
        http://design.medeek.com/resources/wallplugin/images6/wall_su744_800.jpg
        With this release I've fixed a number of substantial bugs that were discovered by users and also one by myself. I highly recommend upgrading to this latest release of the plugin.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 3.5.4 - 03.08.2024
          • Enabled an end grain material for top and bottom plates of rectangular walls.
          • Fixed a javascript bug for garage door presets.
          • Fixed a bug with door presets when using metric templates.
          http://design.medeek.com/resources/wallplugin/images6/wall_su745_800.jpg
          design.medeek.com
          • medeekM Offline
            medeek
            Version 3.5.4b - 03.09.2024
            • Enabled a pressure treated end grain material for bottom plates of all walls.
            • Enabled end grain materials for in-wall columns.
            • Enabled end grain materials for beams.
            • Enabled end grain materials for blocks.
            • Enabled end grain materials for posts.
            http://design.medeek.com/resources/wallplugin/images6/wall_su749_800.jpg
            http://design.medeek.com/resources/wallplugin/images6/wall_su746_800.jpg
            http://design.medeek.com/resources/wallplugin/images6/wall_su747_800.jpg
            http://design.medeek.com/resources/wallplugin/images6/wall_su748_800.jpg
            design.medeek.com
            • medeekM Offline
              medeek
              Version 3.5.5 - 03.11.2024
              • Added a "Custom Glass" garage door type/option with fully customizable glass panels.
              • Further refined the end grain material positioning for top plates (rectangular walls) and in-wall columns.
              http://design.medeek.com/resources/wallplugin/images6/wall_su750_800.jpg
              I will need to create a tutorial video explaining the proper syntax for the "Glass List".
              design.medeek.com
              • medeekM Offline
                medeek
                Medeek Wall Plugin Tutorial 47 - Custom Glass Garage Doors (w/ Webcam)
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 3.5.6 - 03.21.2024
                  • Added built-in "Taped" and "Green Taped" gypsum materials for all wall types.
                  • Updated and added additional tool tips within the Global Settings.
                  design.medeek.com
                  gullfoG 1 Reply Last reply Reply Quote 0
                  • gullfoG Offline
                    gullfo @medeek
                    is that a level 4 or level 5 finish? πŸ˜‰
                    Glenn
                    http://www.runnel.com
                    • medeekM Offline
                      medeek
                      Version 3.5.7 - 04.17.2024
                      • Fixed a compatibility bug with SketchUp 2024 while maintaining compatibility with previous versions of SketchUp.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 3.5.8 - 04.25.2024
                        • Fixed a bug with cripple studs over windows and doors.
                        • Fixed a bug with the copy wall tool.
                        alt text
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          [b]Version 3.5.9[/b] - 05.01.2024
                          • Added a rainscreen option for gable walls (vertical, horizontal, 45 and 135 degree).
                          • Added a rainscreen option for shed walls (vertical, horizontal, 45 and 135 degree).
                          • Added a rainscreen option for hip walls (vertical, horizontal, 45 and 135 degree).
                          • Updated the license verification system with a more secure and improved algorithm.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            [b]Version 3.6.0[/b] - 05.04.2024
                            • Added the ability to create custom "Vertical Shiplap" wall cladding materials within the Material Library.
                            • Enabled "3D" Vertical Shiplap wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
                            • Added the ability to create custom Dutchlap" wall cladding materials within the Material Library.
                            • Enabled "3D" Dutchlap wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
                            alt text
                            alt text
                            This update per customer request.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              alt text
                              alt text
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                The original 3D cladding tutorial showed the following four materials:
                                • Board and Batten
                                • Shiplap
                                • Log
                                • Lap
                                The three additional ones added since this video are:
                                • Metal
                                • Shiplap (Vertical)
                                • Dutchlap
                                There are now seven different types of 3D cladding materials one can configure within the Custom Material Library.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 3.6.1 - 05.13.2024
                                  Added Symbol 2 Layer specfically for 2D door swing symbols (Layer tab of the global settings).
                                  http://design.medeek.com/resources/wallplugin/images7/wall_su763_800.jpg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    I will be running a Memorial Day promotion beginning May 22th until Jun. 5th with 35% off of the regular mdkBIM bundle price (permanent license) using the coupon code MEMORIAL24.
                                    This will reduce the bundle price from $280.00 USD to $182.00 USD. This promo code does not apply to any of the extensions purchased separately. As part of this promotion a permanent license for the electrical plugin will be included upon request at no additional cost. The offer ends on Jun. 5th and no rain checks will issued thereafter.
                                    alt text
                                    design.medeek.com
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Double sliders are kind of interesting windows.
                                      [img]https://global.discourse-cdn.com/sketchup/original/3X/6/4/64053bedf882932aab501290cdb0080fb93e8c0e.gif[/img]
                                      Sometimes I forget how cool it is to be able to create something like this in SketchUp and have it animate like it does. Can I say I love my job?
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 3.6.3 - 06.06.2024
                                        • Enabled elevation swing/opening lines for doors and windows.
                                        • Added elevation swing line annotation settings to the Door tab of the Global Settings.
                                        • Added elevation swing line annotation settings to the Window tab of the Global Settings.
                                        • Enabled opening and closing for all double hung type windows.
                                        http://design.medeek.com/resources/wallplugin/images7/wall_su771_800.jpg
                                        http://design.medeek.com/resources/wallplugin/images7/wall_su772_800.jpg
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Tutorial 48 - Elevation Swing Lines (8:31 min.)
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 3.6.4 - 06.08.2024
                                            • Added the following additional Wide Flange (W) beams to the beam module: W10X49, W10X54, W10X60, W10X68, W10X77, W10X88, W10X100, W10X112, W12X45, W12X50, W12X53, W12X58, W12X65, W12X72, W12X79, W12X87, W12X96, W12X106, W12X120, W12X136, W12X152, W12X170, W12X190, W30X90, W30X99, W30X108.
                                            • Added the following Simpson Strong-Tie heavy girder hangers to the beam hanger library: HGUS2.75/10, HGUS2.75/12, HGUS2.75/14, HGUS3.25/10, HGUS3.25/12, HGUS412, HGUS5.25/10, HGUS5.25/12, HGUS5.5/8, HGUS5.5/10, HGUS5.5/12, HGUS5.5/14, HGUS7.25/8, HGUS7.25/10, HGUS7.25/12, HGUS7.25/14.
                                            • Allowed the use of a period "." in custom beam hanger library names.
                                            http://design.medeek.com/resources/wallplugin/images7/wall_su776_800.jpg
                                            design.medeek.com
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 75
                                            • 76
                                            • 32 / 76
