    Transfer my plugins from SU23 to S24
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    6 Posts 4 Posters 379 Views 5 Watching
    • E Offline
      errror404
      Silly question, but is there an easy way to transfer all my plugins from one version to the next?
      TIGT 1 Reply Last reply Reply Quote 0
      • Rich O BrienR Rich O Brien marked this topic as a question on
        Dave R @errror404
        @errror404 You really ought to use the Extension Store tool to find and install extensions. It's easier than downloading the extensions and installing them with Extension Manager. It also means that when extensions get updated you can get an alert and update them quickly, and of course build your bundle to make migrating to a new version of to a new computer easier.
        • Rich O BrienR Online
          If you use Sketchucation Tools then there's our Bundles feature. In 2024 click Settings...
          Click Bundles...
          Find your 2023 installs and install them into 2024.
            TIG Moderator @errror404
            @errror404
            Probably No.
            If you have SketchUcation tool's ExtensionStoreÂł you can make a Bundle of the extensions you have in the previous version.
            The in the newer version use that Bundle to add/update all of your extensions in that version - using the newest version available.
            Unfortunately it only works for extensions you have installed from SketchUcation.
            Any extensions you got direct from a developer's site need re-downloading and installing individually.
            Any extension you got from the Extension Warehouse must be re-downloaded / installed.
            Their bulk update is no longer available.
            SketchUcation ExtensionStoreÂł also notifies you when updates of your current extensions are available, and lets you install them, individually or in bulk.
            You can copy the contents of your Plugins folder from the current to the newer version - however, many developers update their code to suit newer versions, so errors might arise with this method, especially if you haven't update extensions fastidiously.
            Don't copy over the su_xxx extensions and folders as these are shipped with each version and you might overwrite a newer version...
            E 1 Reply Last reply Reply Quote 1
            • E Offline
              errror404 @TIG
              @TIG
              It seems that I have ExtensionStore version 3.0 installed, but I usually download the plugins straight from sketchucation.
              Under bundles, I see three Bundles.... but I believe they are old or they don't show all the plugins that I currently have installed from sketchucation.
              Rich O BrienR Dave RD 2 Replies Last reply Reply Quote 0
                Rich O Brien Moderator @errror404
                @errror404 Sketchucation Tools v3 is unsupported. Please update
                https://sketchucation.com/plugin/696-sketchucationtools
                  Dave R @errror404
