    Fredo6 Curviloft - missing tool bar [SKP 2023 / 2024]
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    7 Posts 3 Posters 1.0k Views 3 Watching
      agatof
      Hi!
      I'm having problem with louching installed plug-in - Fredo6 Curviloft.
      It is installed, but there is no tool bar.
      I've tried it in few versions of Sketchup:
      • SketchUp 2022 - everything works just fine
      • SketchUp 2023 and 2024 - no tool bar, though the plug-in is installed
      Other plug-ins are showing up and working, but not the one I need right now ๐Ÿ˜•
      Can anybody help me with that?
      fredo6F 1 Reply Last reply
      • Rich O BrienR Rich O Brien marked this topic as a question on
        Rich O Brien Moderator @agatof
        @agatof
        Your Libfredo is outdated please upgrade to 14.3d
        https://sketchucation.com/pluginstore?pln=LibFredo6
        Your FredoScale is outdated please upgrade to 3.6a
        https://sketchucation.com/pluginstore?pln=FredoScale
        You can update directly within SketchUp using our ExtensionStore or manually
        Restart SketchUp after installation to complete process fully and activate per the guide
        https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
        A 1 Reply Last reply
          Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
          • fredo6F
            fredo6 @agatof
            @agatof
            Do you see the menu entries for Curviloft?
            Also, did you install SketchUp 2023 and 2024 with โ€˜run as administratorโ€™ ?
              agatof @Rich O Brien
              @Rich-O-Brien
              here is the content:
              Fredo6 Plugins Information on 2024-04-24 12:48:49 +0200
              • Sketchup: 24.0.484
              • LibFredo6: v14.2a
              • LibFredo6 Binary NOT loaded
              • Sketchucation ExtensionStore: 4.4.0
              • SCFLicense: v6.4a - 74
              • Fredo6 Plugins
                FredoScale v3.5a
                Signature File: 2023-04-27 13:38:37 +0200
                agatof @fredo6
                @fredo6
                I'm not sure what menu entries specifically means.. Could you tell me more?
                I installed SketchUp by entering from the program and just install it, but I don't know in what mode. But I'm set as an administrator, so I think (but not sure) that I've installed it that way
                  @agatof
                    @Rich-O-Brien thank you! The update helped! ๐Ÿ™‚
