    Fredo Lord of Toolbars Search issue
    19 Posts 4 Posters 1.2k Views 4 Watching
      Salient @fredo6
      @fredo6 When I click the hourglass no search box appears. I have looked to see if it may be hiding somewhere but I cannot see it if it is. I have also uninstalled the plugin and reinstalled. Everything else is working properly.
      Thank you
      fredo6F 1 Reply Last reply Reply Quote 1
      • fredo6F Offline
        fredo6 @Salient
        @Salient
        Can you leave the Ruby console open to check for errors.
        K S 2 Replies Last reply Reply Quote 1
          kylekin Newcomers @fredo6
          @fredo6 Having the same issues. Search doesn't work. And tools are not registering. When I have the ruby console open -- nothing happens when I click on a tool within LOTT
          S 1 Reply Last reply Reply Quote 0
            Salient @fredo6
            @fredo6
            Thanks for responding. I opened the ruby console by selecting Extensions>Developer>Ruby Console. The console appears however nothing shows in the console when I click the search button on the toolbar. Did I do what you asked me to do correctly?
              Salient @kylekin
              @kylekin
              it doesn't appear as though it can be fixed.
              • fredo6F Offline
                I would need a little bit more information.
                • Mac or Windows?
                • What is the 'hourglass'. The Search icon has a magnifier?
                • did you upgrade t the latest version of LibFredo6 (14.2a)?
                K S 2 Replies Last reply Reply Quote 0
                  @fredo6 I upgraded to latest version of libfredo. On a Mac. None of the tool buttons are working from the main menu, search doesn't work, no longer able to add to my favorites with more tools.
                  • fredo6F Offline
                    Difficult to tell what is the problem.
                    Do you get the Master Toolbar Manager dialog (first icon)?
                      Salient @fredo6
                      @fredo6
                      Windows
                      and yes, I apologize, I meant the magnifier
                      I did have 14.2a but I just upgraded to your newest.
                      fredo6F 1 Reply Last reply Reply Quote 0
                      • fredo6F Offline
                        fredo6 @Salient
                        @Salient
                        Do you have several monitors?
                        If so, it might be that the dialog is out of screen.
                        The best is to open the Ruby Console and copy/ paste the following command and type Enter.
                        Traductor::ChromiumWdlg.dialog_info_reset "LOTT_MiniFindDialog"
                        Then, launch the Serach again. The dialog should be on the main Sketchup screen.
                        S 3 Replies Last reply Reply Quote 0
                          Salient @fredo6
                          @fredo6
                          Yes, I have 4.
                          I disconnected three of them to see if the menu was hiding, but if it is, I still cannot see anything when I click the magnifier.
                          I can see this, but nothing at all when I click the magnifier.
                            Salient @fredo6
                            @fredo6 said in Fredo Lord of Toolbars Search issue:
                            Okay, I will try that and report back.
                              Salient @fredo6
                              @fredo6
                              No luck. That didn't work either.
                              I am happy to try anything you suggest.
                              • fredo6F Offline
                                fredo6 @Salient
                                @Salient
                                Can you indicate
                                • which version of Sketchup?
                                • whether you see the other dialogs?
                                  Salient @fredo6
                                  @fredo6
                                  22.0.354
                                  I see all of the other dialogs.
                                  The magnifier was working for me perfectly. I do not know what I did to cause it to stop.
                                  I have licenses for several of your other plugins and they seem to work perfectly.
                                  K 1 Reply Last reply Reply Quote 0
                                    kylekin Newcomers @Salient
                                    @Salient All appears fixed with the new Sketchup update.
