    Fredo Lord of Toolbars Search issue
    19 Posts 4 Posters 1.2k Views 4 Watching
    • fredo6F Offline
      fredo6 @Salient
      @Salient said in Fredo Lord of Toolbars Search issue:
      The search button on Lord of Toolbars is no longer working for me. Can anyone advise on how to reset or fix it? .
      What is not working exactly?
      S 1 Reply Last reply Reply Quote 0
        Salient @fredo6
        @fredo6 When I click the hourglass no search box appears. I have looked to see if it may be hiding somewhere but I cannot see it if it is. I have also uninstalled the plugin and reinstalled. Everything else is working properly.
        Thank you
        fredo6F 1 Reply Last reply Reply Quote 1
        • fredo6F Offline
          fredo6 @Salient
          @Salient
          Can you leave the Ruby console open to check for errors.
          K S 2 Replies Last reply Reply Quote 1
            kylekin Newcomers @fredo6
            @fredo6 Having the same issues. Search doesn't work. And tools are not registering. When I have the ruby console open -- nothing happens when I click on a tool within LOTT
              Salient @fredo6
              @fredo6
              Thanks for responding. I opened the ruby console by selecting Extensions>Developer>Ruby Console. The console appears however nothing shows in the console when I click the search button on the toolbar. Did I do what you asked me to do correctly?
                Salient @kylekin
                @kylekin
                it doesn't appear as though it can be fixed.
                • fredo6F Offline
                  I would need a little bit more information.
                  • Mac or Windows?
                  • What is the 'hourglass'. The Search icon has a magnifier?
                  • did you upgrade t the latest version of LibFredo6 (14.2a)?
                  K S 2 Replies Last reply Reply Quote 0
                    @fredo6 I upgraded to latest version of libfredo. On a Mac. None of the tool buttons are working from the main menu, search doesn't work, no longer able to add to my favorites with more tools.
                    • fredo6F Offline
                      Difficult to tell what is the problem.
                      Do you get the Master Toolbar Manager dialog (first icon)?
                        Salient @fredo6
                        @fredo6
                        Windows
                        and yes, I apologize, I meant the magnifier
                        I did have 14.2a but I just upgraded to your newest.
                        fredo6F 1 Reply Last reply Reply Quote 0
                        • fredo6F Offline
                          fredo6 @Salient
                          @Salient
                          Do you have several monitors?
                          If so, it might be that the dialog is out of screen.
                          The best is to open the Ruby Console and copy/ paste the following command and type Enter.
                          Traductor::ChromiumWdlg.dialog_info_reset "LOTT_MiniFindDialog"
                          Then, launch the Serach again. The dialog should be on the main Sketchup screen.
                          S 3 Replies Last reply Reply Quote 0
                            Salient @fredo6
                            @fredo6
                            Yes, I have 4.
                            I disconnected three of them to see if the menu was hiding, but if it is, I still cannot see anything when I click the magnifier.
                            I can see this, but nothing at all when I click the magnifier.
                              Salient @fredo6
                              @fredo6 said in Fredo Lord of Toolbars Search issue:
                              Okay, I will try that and report back.
                                Salient @fredo6
                                @fredo6
                                No luck. That didn't work either.
                                I am happy to try anything you suggest.
                                • fredo6F Offline
                                  fredo6 @Salient
                                  @Salient
                                  Can you indicate
                                  • which version of Sketchup?
                                  • whether you see the other dialogs?
                                    Salient @fredo6
                                    @fredo6
                                    22.0.354
                                    I see all of the other dialogs.
                                    The magnifier was working for me perfectly. I do not know what I did to cause it to stop.
                                    I have licenses for several of your other plugins and they seem to work perfectly.
                                    K 1 Reply Last reply Reply Quote 0
                                      kylekin Newcomers @Salient
                                      @Salient All appears fixed with the new Sketchup update.
