    Fredo Lord of Toolbars Search issue
    19 Posts 4 Posters 954 Views 4 Watching
      Salient
      The search button on Lord of Toolbars is no longer working for me. Can anyone advise on how to reset or fix it?
      Thank you.
      fredo6F 1 Reply Last reply Reply Quote 1
        rv1974
        This post is deleted!
        • fredo6F Offline
          fredo6 @Salient
          @Salient said in Fredo Lord of Toolbars Search issue:
          The search button on Lord of Toolbars is no longer working for me. Can anyone advise on how to reset or fix it? .
          What is not working exactly?
          S 1 Reply Last reply Reply Quote 0
            Salient @fredo6
            @fredo6 When I click the hourglass no search box appears. I have looked to see if it may be hiding somewhere but I cannot see it if it is. I have also uninstalled the plugin and reinstalled. Everything else is working properly.
            Thank you
            • fredo6F Offline
              fredo6 @Salient
              @Salient
              Can you leave the Ruby console open to check for errors.
              K S 2 Replies Last reply Reply Quote 1
                kylekin Newcomers @fredo6
                @fredo6 Having the same issues. Search doesn't work. And tools are not registering. When I have the ruby console open -- nothing happens when I click on a tool within LOTT
                  Salient @fredo6
                  @fredo6
                  Thanks for responding. I opened the ruby console by selecting Extensions>Developer>Ruby Console. The console appears however nothing shows in the console when I click the search button on the toolbar. Did I do what you asked me to do correctly?
                    Salient @kylekin
                    @kylekin
                    it doesn't appear as though it can be fixed.
                    • fredo6F Offline
                      I would need a little bit more information.
                      • Mac or Windows?
                      • What is the 'hourglass'. The Search icon has a magnifier?
                      • did you upgrade t the latest version of LibFredo6 (14.2a)?
                      K S 2 Replies Last reply Reply Quote 0
                        @fredo6 I upgraded to latest version of libfredo. On a Mac. None of the tool buttons are working from the main menu, search doesn't work, no longer able to add to my favorites with more tools.
                        • fredo6F Offline
                          Difficult to tell what is the problem.
                          Do you get the Master Toolbar Manager dialog (first icon)?
                            Salient @fredo6
                            @fredo6
                            Windows
                            and yes, I apologize, I meant the magnifier
                            I did have 14.2a but I just upgraded to your newest.
                            fredo6F 1 Reply Last reply Reply Quote 0
                            • fredo6F Offline
                              fredo6 @Salient
                              @Salient
                              Do you have several monitors?
                              If so, it might be that the dialog is out of screen.
                              The best is to open the Ruby Console and copy/ paste the following command and type Enter.
                              Traductor::ChromiumWdlg.dialog_info_reset "LOTT_MiniFindDialog"
                              Then, launch the Serach again. The dialog should be on the main Sketchup screen.
                              S 3 Replies Last reply Reply Quote 0
                                Salient @fredo6
                                @fredo6
                                Yes, I have 4.
                                I disconnected three of them to see if the menu was hiding, but if it is, I still cannot see anything when I click the magnifier.
                                I can see this, but nothing at all when I click the magnifier.
                                  Salient @fredo6
                                  @fredo6 said in Fredo Lord of Toolbars Search issue:
                                  Okay, I will try that and report back.
                                    Salient @fredo6
                                    @fredo6
                                    No luck. That didn't work either.
                                    I am happy to try anything you suggest.
                                    • fredo6F Offline
                                      fredo6 @Salient
                                      @Salient
                                      Can you indicate
                                      • which version of Sketchup?
                                      • whether you see the other dialogs?
                                        Salient @fredo6
                                        @fredo6
                                        22.0.354
                                        I see all of the other dialogs.
                                        The magnifier was working for me perfectly. I do not know what I did to cause it to stop.
                                        I have licenses for several of your other plugins and they seem to work perfectly.
                                        K 1 Reply Last reply Reply Quote 0
                                          kylekin Newcomers @Salient
                                          @Salient All appears fixed with the new Sketchup update.
