    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      Version 3.4.5b - 01.28.2024
      • Fixed a bug with holdowns for in-wall columns.
      • Fixed a bug with the bottom plate cutting algorithm for in-wall columns.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 3.4.6 - 01.30.2024
        • Added a "Dimension to Centerline" option for framing dimensions in the General tab of the Global Settings.
        • Enabled centerline dimensioning for openings, columns and SSW for rectangular walls.
        • Added a "Style 5" (Pull Plate) to the built-in door hardware options.
        • Added more options for grid style window grilles: 3X4, 4X5, 5X6.
        http://design.medeek.com/resources/wallplugin/images6/wall_su730_800.jpg
        http://design.medeek.com/resources/wallplugin/images6/wall_su729_800.jpg
        http://design.medeek.com/resources/wallplugin/images6/wall_su731_800.jpg
        All updates per customer requests.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 3.4.7 - 02.01.2024
          • Updated the Columns tab of the Global Settings with new parameters.
          • Added glazing color and opacity parameters to the Sheathing tab of the Global Settings.
          http://design.medeek.com/resources/wallplugin/images6/wall_su732_800.jpg
          http://design.medeek.com/resources/wallplugin/images6/wall_su733_800.jpg
          The Columns tab now includes Custom and Blank under Column Type.
          Up until now the glass color and opacity has been hard coded in to the plugin, now the user can adjust these values if desired.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 3.4.8 - 02.04.2024
            • Added a Sheathing Reset button in the Sheathing tab of the Global Settings.
            • Added Dimension Layer 5 specfically for framing/elevation auto-dimensions (Layer tab of the global settings).
            • Enabled editing of dimensions for framing/elevation dimensions (rectangular walls only).
            http://design.medeek.com/resources/wallplugin/images6/wall_su734_800.jpg
            http://design.medeek.com/resources/wallplugin/images6/wall_su735_800.jpg
            Tutorial 46 - Editing Framing Dimensions (7:34 min.)
            design.medeek.com
            • medeekM Offline
              medeek
              Version 3.4.9 - 02.16.2024
              • Added an RGB color code input into the Add, Update and Import menus for custom materials.
              • Added an RGB color code input for each color in the Materials tab of the Global Settings.
              • Added a "Toggle RGB Input" button to the Materials tab of the Global Settings.
              http://design.medeek.com/resources/wallplugin/images6/wall_su736_800.jpg
              http://design.medeek.com/resources/wallplugin/images6/wall_su737_800.jpg
              Updates per customer request.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 3.5.0 - 02.23.2024
                • Separated the tee blocking option for exterior and interior walls.
                • Fixed a bug with geometry guides for metric templates.
                http://design.medeek.com/resources/wallplugin/images6/wall_su738_800.jpg
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 3.5.1 - 02.24.2024
                  • Added a 45 and 135 degree rainscreen option for rectangular walls.
                  http://design.medeek.com/resources/wallplugin/images6/wall_su739_800.jpg
                  This update per customer request.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 3.5.2 - 03.02.2024
                    • Added the following door types: 3/4 glass, double 3/4 glass.
                    • Added a separate threshold material option for all man doors.
                    • Added additional grille (grid) options for glass doors.
                    http://design.medeek.com/resources/wallplugin/images6/wall_su741_800.jpg
                    http://design.medeek.com/resources/wallplugin/images6/wall_su742_800.jpg
                    http://design.medeek.com/resources/wallplugin/images6/wall_su743_800.jpg
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 3.5.3 - 03.06.2024
                      • Added a "Panel" corner treatment for "End" and "Terminal" wall corners (rectangular walls only).
                      • Fixed a javascript bug for window and door presets.
                      • Fixed a bug with the door casing (custom casing options) and end cripple studs for pocket doors.
                      • Rearranged the door casing section of the door Draw and Edit menus.
                      • Fixed a bug with the advanced options for all wall types when using metric templates.
                      http://design.medeek.com/resources/wallplugin/images6/wall_su744_800.jpg
                      With this release I've fixed a number of substantial bugs that were discovered by users and also one by myself. I highly recommend upgrading to this latest release of the plugin.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 3.5.4 - 03.08.2024
                        • Enabled an end grain material for top and bottom plates of rectangular walls.
                        • Fixed a javascript bug for garage door presets.
                        • Fixed a bug with door presets when using metric templates.
                        http://design.medeek.com/resources/wallplugin/images6/wall_su745_800.jpg
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 3.5.4b - 03.09.2024
                          • Enabled a pressure treated end grain material for bottom plates of all walls.
                          • Enabled end grain materials for in-wall columns.
                          • Enabled end grain materials for beams.
                          • Enabled end grain materials for blocks.
                          • Enabled end grain materials for posts.
                          http://design.medeek.com/resources/wallplugin/images6/wall_su749_800.jpg
                          http://design.medeek.com/resources/wallplugin/images6/wall_su746_800.jpg
                          http://design.medeek.com/resources/wallplugin/images6/wall_su747_800.jpg
                          http://design.medeek.com/resources/wallplugin/images6/wall_su748_800.jpg
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 3.5.5 - 03.11.2024
                            • Added a "Custom Glass" garage door type/option with fully customizable glass panels.
                            • Further refined the end grain material positioning for top plates (rectangular walls) and in-wall columns.
                            http://design.medeek.com/resources/wallplugin/images6/wall_su750_800.jpg
                            I will need to create a tutorial video explaining the proper syntax for the "Glass List".
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Medeek Wall Plugin Tutorial 47 - Custom Glass Garage Doors (w/ Webcam)
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 3.5.6 - 03.21.2024
                                • Added built-in "Taped" and "Green Taped" gypsum materials for all wall types.
                                • Updated and added additional tool tips within the Global Settings.
                                design.medeek.com
                                gullfoG 1 Reply Last reply Reply Quote 0
                                • gullfoG Offline
                                  gullfo @medeek
                                  is that a level 4 or level 5 finish? πŸ˜‰
                                  Glenn
                                  http://www.runnel.com
                                  • medeekM Offline
                                    medeek
                                    Version 3.5.7 - 04.17.2024
                                    • Fixed a compatibility bug with SketchUp 2024 while maintaining compatibility with previous versions of SketchUp.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 3.5.8 - 04.25.2024
                                      • Fixed a bug with cripple studs over windows and doors.
                                      • Fixed a bug with the copy wall tool.
                                      alt text
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        [b]Version 3.5.9[/b] - 05.01.2024
                                        • Added a rainscreen option for gable walls (vertical, horizontal, 45 and 135 degree).
                                        • Added a rainscreen option for shed walls (vertical, horizontal, 45 and 135 degree).
                                        • Added a rainscreen option for hip walls (vertical, horizontal, 45 and 135 degree).
                                        • Updated the license verification system with a more secure and improved algorithm.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          [b]Version 3.6.0[/b] - 05.04.2024
                                          • Added the ability to create custom "Vertical Shiplap" wall cladding materials within the Material Library.
                                          • Enabled "3D" Vertical Shiplap wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
                                          • Added the ability to create custom Dutchlap" wall cladding materials within the Material Library.
                                          • Enabled "3D" Dutchlap wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
                                          alt text
                                          alt text
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            alt text
                                            alt text
                                            design.medeek.com
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 74
                                            • 75
                                            • 24 / 75
