    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      @bob james said:
      To take advantage of this offer, once you have purchased the wall plugin, simply email me with your client ID or username and that you would like to take advantage of the June 2018 Promo.
      I've just purchased the Wall plugin, but cannot find your email address
      Thank-you for your purchase and you support of this endeavor.
      My email is nathan@medeek.com
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • Bob JamesB Offline
        Bob James
        Thank you.
        Done
          Bob James
          Version 0.7.5
          Made some test walls with inside corners so the walls would be drawn on the outside of the path and had two problems:
          I expected the gypsum to be on the inside and the sheathing to be on the outside. This is what I got with the gypsum not only not on the inside, but buried in the 2x4:
          And the corners are offset so they did not meet.
          Note also that the wood has no texture even though the Auto Assign Materials was set to "Yes".
          With the blizzard of inputs, I've probably set more than one thing wrong, but have no idea what.
            Bob James
            Since nearly all the homes in the California South Coast have stucco walls, can you add a flat plane cladding to which I could add the appropriate stucco material?
            • medeekM Offline
              medeek
              @ Bob James:
              You have hit on two very important and interesting topics/issues with the plugin, I will do my best to address them both here:
              1.) The wall justification (front, middle, back) is something I have been treating as a basic property or parameter of the wall. This morning as I really put on my thinking cap I came to the realization that this is not so. The justification is only really needed during the wall creation process and once the wall is created there is no justification, the wall just is.
              With that being said I need to rework the wall creation tool slightly, it shouldn't be too big of an issue but will require some serious and careful thought. For now please only use the "FRONT" justification, the other two options are flawed by their very nature.
              This may take me a couple days to fully think this through and come up with the correct solution. Please have patience with me while I work this one out, I need to do it slowly and carefully and get it right.
              2.) I am not satisfied with the current system of applying materials to the wall assembly via the plugin. Since the plugin completely rebuilds the entire wall panel on any edit or addition of windows or doors it must somehow save the material being used for each element (group) within the attribute library. It is already setup to do this and works quite well.
              One can also use the edit menu to select from a static list of materials.
              I think a few things could help to make this better:
              A.) The plugin can look at the currently defined materials in the model and give the user the ability to select from any of these materials as well as the hard coded materials within the wall edit menu.
              B.) Perhaps and observer or something should be setup so that if the user manually opens up the wall assembly group and assigns a material to the cladding, sheathing or gypsum for a given wall panel this information is then updated within the attribute library.
              C.) Provide an interface within the global settings where additional hard coded materials can be added to the existing ones. The user would upload an image, assign a name and specify the X and Y scaling.
              In the meantime if you could send me over at least one stucco material that you commonly use, I would love to add it to the plugin as a permanent material option
              design.medeek.com
                Bob James
                Here is the stucco color for my house:
                Of course, it needs a normal map or a bunp map when I render it in Thea.
                Stucco
                • medeekM Offline
                  medeek
                  [attachment=0:2ixeuzqv]<!-- ia0 -->texture4.jpg<!-- ia0 -->[/attachment:2ixeuzqv]
                  Do you have a name or color you would like me to assign to this stucco.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    My intent is to add in the portal framing option into the garage door module.
                    Yes, it will comply with the IRC standard but also give the user a few more options to further customize it. Portal framing is actually much more complex than just the prescriptive examples given in the IRC or IBC, one can engineer these things to be quite a bit more substantial, as I have done in the past.
                    Take a look at this example below:
                    http://design.medeek.com/resources/PFH/PFH_CALCULATOR.pdf
                    Here is a rather stout wall engineered with two portal frames and a shearwall (this was in a high wind and seismic location):
                    http://design.medeek.com/images/misc/PFH_EXAMPLE2.jpg
                    The plugin should not only be able to draw this but also perform the engineering checks as well.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      [attachment=0:3jwkvlpz]<!-- ia0 -->texture4.jpg<!-- ia0 -->[/attachment:3jwkvlpz]
                      It should be noted that once a material is defined by the plugin in SketchUp there is nothing stopping the user from editing that material and changing it up.
                      Once a material is assigned and created the plugin does not try to recreate or change the material so technically you could assign your cladding to red brick for example and then simple change it to whatever you like. The important thing is that the plugin is looking for the name of the material when it regens the model, it doesn't care about all of the other properties of the material in question.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Just to prove my previous point about customizing materials I've edited the medeek_lumber material name that I use for all of the framing and applied a CMU image to it.
                        I then set the wall framing at 8 inches thick and switched to the no framing mode so that the walls are represented only by solid groups.
                        Voila, CMU walls:
                        http://design.medeek.com/resources/images/wall_su89_800.jpg
                        If there is an external brick facade with an air gap, the cladding can be turned on and air gap adjusted accordingly.
                        Even though I have not specifically set this plugin up for CMU or block walls theoretically one could use it in this manner to model this type of construction. The "NO FRAMING" mode may be quite a bit more useful than I originally thought.
                        design.medeek.com
                          Bob James
                          Ideal for initial concept modeling. All-in-all, I'd probably use this mode more often than the complete set of details.
                            MtnArch
                            Nathan ... just wondering about the bundle deal. What about those of us that are current (paid) Truss and Foundation users who also contributed to your KickStarter campaign? Is there a way to align all of our licenses to one renewal date? I'd rather have one renewal (like Vali's Instant Architecture) than multiple individual ones. Also looking forward to when you add in the shear engineering element to the wall plugin!
                            Highest Regards,
                            Alan T. Hendry, RA
                            Architect
                            • medeekM Offline
                              medeek
                              The Kickstarter Campaign supporters are also considered purchasers of the Wall Plugin, perhaps I was not clear enough in the promo newsletter, I apologize if that was not clear.
                              The promotion applies to all supporters of the Kickstarter Campaign. In fact, it should apply even more so because of your willingness to take that serious leap of faith with me. As such I am willing to extend the same expiration date to all of the plugins to match the expiration date you currently have for the Wall Plugin.
                              This only applies to Kickstarter Campaign supporters and to those who purchased the plugin prior to its initial beta release date.
                              design.medeek.com
                                Bob James
                                Cladding_Stucco_Light_Tan
                                • medeekM Offline
                                  medeek
                                  Grabbed some code from the Truss Plugin this morning and now Glulam Beams are available for window or door headers:
                                  http://design.medeek.com/resources/images/wall_su90_800.jpg
                                  The species or types of Glulam beams available are: Western Species, Southern Pine, and UK, Australian and South African varieties.
                                  Its nice to be able to recycle some code, allows one to implement something very quickly.
                                  I'm currently working on the corner cladding issue and adding in the option for a LAP or MITER corner treatment.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    As a follow up to a previous post about a day ago I've enabled the wall cladding menus (draw tool and edit menu) so that option (A) as previously discussed above is now a reality:
                                    http://design.medeek.com/resources/images/wall_su91_800.jpg
                                    I find this solution a potentially a bit messy since all materials are available within the drop down so there is a possibility of duplicate listings but overall it seems fairly robust and offers the flexibility needed so that the user can define their own materials within SU rather than having to rely on the plugin for a static list of pre-defined materials.
                                    design.medeek.com
                                      Bob James
                                      Is there a new version that includes this? Version 0.7.6?
                                      • medeekM Offline
                                        medeek
                                        Version 0.7.6 is not yet released, so far it will encompass the following fixes and possibly some more:
                                        • Addition of glulam headers for windows and doors
                                        • Fixed a bug with the exterior corner trim (end corner)
                                        • Dynamic material list for cladding
                                        • LAP and MITER options for corner treatment of the cladding (still a few more hours of coding and testing to go, but progress is solid).
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          4" brick facade (Corner Config: LAP) with a 1" air gap and 7/16" sheathing:
                                          http://design.medeek.com/resources/images/wall_su92_800.jpg
                                          The mitered corner configuration for cladding is also now working.
                                          I will address a few other small issues tomorrow morning and then release 0.7.6.
                                          I've been told that I need to add a lapped option for the sheathing as well since leaving the corners open like we do in the western US doesn't work out so well in the southeastern states.
                                          I think the next big item on the list I'll tackle is the garage doors so that at least we have one or two options for that available.
                                          I also have the pseudo code put together for exterior wainscoting (dual exterior cladding). The code behind that wall configuration will get a bit more complicated but hopefully it won't bog down the model too much.
                                          I currently have 18 major items on the todo list:
                                          • Interior Trim
                                          • Garage Doors
                                          • Door casing for interior walls
                                          • Gypsum wrap for interior openings
                                          • Ext. Sheathing LAP option
                                          • Wall Split Tool
                                          • Wall Join Tool
                                          • Gable Wall Tool
                                          • Wall Grouping
                                          • SSW Module
                                          • Columns Module
                                          • Bug with outside corners less than 90 deg. (framing)
                                          • Exterior Wainscoting
                                          • Some additional debugging or checking with the draw wall tool as it relates to auto-corner configuration and defaults for inputs.
                                          • Global settings parameter allowing user to toggle between standard stud sizes and custom sizes
                                          • Beam Tool (add to the columns module, one additional icon for toolbar).
                                          • Wall justification issue (currently the FRONT option is functional)
                                          • SHIFT key snapping to X or Y axis during wall creation.
                                          If there are other items you would like to see added to this list please feel free to send them in. Also this list is in no particular order, the squeaky wheel is getting the grease, so if you want something pushed to the top please let me know.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Currently pre-configured doors and windows are saved by the user and accessed by the plugin from the "library" sub-folder of the plugin. The problem I see with this is that if you want to upgrade the plugin and have to remove the "medeek_wall_ext" plugin folder then you must take the added step to copy the contents of the library folder and then put it back after the updated plugin has been installed.
                                            Perhaps there is a better location for the user library or I suppose I could make its very location user definable?
                                            design.medeek.com
                                            • 11
                                            • 12
                                            • 13
                                            • 74
                                            • 75
                                            • 11 / 75
