    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.2m Views 28 Watching
    • Bob JamesB
      Bob James
      Since nearly all the homes in the California South Coast have stucco walls, can you add a flat plane cladding to which I could add the appropriate stucco material?
      • medeekM
        medeek
        @ Bob James:
        You have hit on two very important and interesting topics/issues with the plugin, I will do my best to address them both here:
        1.) The wall justification (front, middle, back) is something I have been treating as a basic property or parameter of the wall. This morning as I really put on my thinking cap I came to the realization that this is not so. The justification is only really needed during the wall creation process and once the wall is created there is no justification, the wall just is.
        With that being said I need to rework the wall creation tool slightly, it shouldn't be too big of an issue but will require some serious and careful thought. For now please only use the "FRONT" justification, the other two options are flawed by their very nature.
        This may take me a couple days to fully think this through and come up with the correct solution. Please have patience with me while I work this one out, I need to do it slowly and carefully and get it right.
        2.) I am not satisfied with the current system of applying materials to the wall assembly via the plugin. Since the plugin completely rebuilds the entire wall panel on any edit or addition of windows or doors it must somehow save the material being used for each element (group) within the attribute library. It is already setup to do this and works quite well.
        One can also use the edit menu to select from a static list of materials.
        I think a few things could help to make this better:
        A.) The plugin can look at the currently defined materials in the model and give the user the ability to select from any of these materials as well as the hard coded materials within the wall edit menu.
        B.) Perhaps and observer or something should be setup so that if the user manually opens up the wall assembly group and assigns a material to the cladding, sheathing or gypsum for a given wall panel this information is then updated within the attribute library.
        C.) Provide an interface within the global settings where additional hard coded materials can be added to the existing ones. The user would upload an image, assign a name and specify the X and Y scaling.
        In the meantime if you could send me over at least one stucco material that you commonly use, I would love to add it to the plugin as a permanent material option
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • Bob JamesB
          Bob James
          Here is the stucco color for my house:
          Of course, it needs a normal map or a bunp map when I render it in Thea.
          Stucco
          • medeekM
            medeek
            [attachment=0:2ixeuzqv]<!-- ia0 -->texture4.jpg<!-- ia0 -->[/attachment:2ixeuzqv]
            Do you have a name or color you would like me to assign to this stucco.
            design.medeek.com
            • medeekM
              medeek
              My intent is to add in the portal framing option into the garage door module.
              Yes, it will comply with the IRC standard but also give the user a few more options to further customize it. Portal framing is actually much more complex than just the prescriptive examples given in the IRC or IBC, one can engineer these things to be quite a bit more substantial, as I have done in the past.
              Take a look at this example below:
              404 - File or directory not found.
              (design.medeek.com)
              Here is a rather stout wall engineered with two portal frames and a shearwall (this was in a high wind and seismic location):
              http://design.medeek.com/images/misc/PFH_EXAMPLE2.jpg
              The plugin should not only be able to draw this but also perform the engineering checks as well.
              design.medeek.com
              • medeekM
                medeek
                [attachment=0:3jwkvlpz]<!-- ia0 -->texture4.jpg<!-- ia0 -->[/attachment:3jwkvlpz]
                It should be noted that once a material is defined by the plugin in SketchUp there is nothing stopping the user from editing that material and changing it up.
                Once a material is assigned and created the plugin does not try to recreate or change the material so technically you could assign your cladding to red brick for example and then simple change it to whatever you like. The important thing is that the plugin is looking for the name of the material when it regens the model, it doesn't care about all of the other properties of the material in question.
                design.medeek.com
                • medeekM
                  medeek
                  Just to prove my previous point about customizing materials I've edited the medeek_lumber material name that I use for all of the framing and applied a CMU image to it.
                  I then set the wall framing at 8 inches thick and switched to the no framing mode so that the walls are represented only by solid groups.
                  Voila, CMU walls:
                  http://design.medeek.com/resources/images/wall_su89_800.jpg
                  If there is an external brick facade with an air gap, the cladding can be turned on and air gap adjusted accordingly.
                  Even though I have not specifically set this plugin up for CMU or block walls theoretically one could use it in this manner to model this type of construction. The "NO FRAMING" mode may be quite a bit more useful than I originally thought.
                  design.medeek.com
                  • Bob JamesB
                    Bob James
                    Ideal for initial concept modeling. All-in-all, I'd probably use this mode more often than the complete set of details.
                      MtnArch
                      Nathan ... just wondering about the bundle deal. What about those of us that are current (paid) Truss and Foundation users who also contributed to your KickStarter campaign? Is there a way to align all of our licenses to one renewal date? I'd rather have one renewal (like Vali's Instant Architecture) than multiple individual ones. Also looking forward to when you add in the shear engineering element to the wall plugin!
                      Highest Regards,
                      Alan T. Hendry, RA
                      Architect
                      • medeekM
                        medeek
                        The Kickstarter Campaign supporters are also considered purchasers of the Wall Plugin, perhaps I was not clear enough in the promo newsletter, I apologize if that was not clear.
                        The promotion applies to all supporters of the Kickstarter Campaign. In fact, it should apply even more so because of your willingness to take that serious leap of faith with me. As such I am willing to extend the same expiration date to all of the plugins to match the expiration date you currently have for the Wall Plugin.
                        This only applies to Kickstarter Campaign supporters and to those who purchased the plugin prior to its initial beta release date.
                        design.medeek.com
                        • Bob JamesB
                          Bob James
                          Cladding_Stucco_Light_Tan
                          • medeekM
                            medeek
                            Grabbed some code from the Truss Plugin this morning and now Glulam Beams are available for window or door headers:
                            http://design.medeek.com/resources/images/wall_su90_800.jpg
                            The species or types of Glulam beams available are: Western Species, Southern Pine, and UK, Australian and South African varieties.
                            Its nice to be able to recycle some code, allows one to implement something very quickly.
                            I'm currently working on the corner cladding issue and adding in the option for a LAP or MITER corner treatment.
                            design.medeek.com
                            • medeekM
                              medeek
                              As a follow up to a previous post about a day ago I've enabled the wall cladding menus (draw tool and edit menu) so that option (A) as previously discussed above is now a reality:
                              http://design.medeek.com/resources/images/wall_su91_800.jpg
                              I find this solution a potentially a bit messy since all materials are available within the drop down so there is a possibility of duplicate listings but overall it seems fairly robust and offers the flexibility needed so that the user can define their own materials within SU rather than having to rely on the plugin for a static list of pre-defined materials.
                              design.medeek.com
                              • Bob JamesB
                                Bob James
                                Is there a new version that includes this? Version 0.7.6?
                                • medeekM
                                  medeek
                                  Version 0.7.6 is not yet released, so far it will encompass the following fixes and possibly some more:
                                  • Addition of glulam headers for windows and doors
                                  • Fixed a bug with the exterior corner trim (end corner)
                                  • Dynamic material list for cladding
                                  • LAP and MITER options for corner treatment of the cladding (still a few more hours of coding and testing to go, but progress is solid).
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    4" brick facade (Corner Config: LAP) with a 1" air gap and 7/16" sheathing:
                                    http://design.medeek.com/resources/images/wall_su92_800.jpg
                                    The mitered corner configuration for cladding is also now working.
                                    I will address a few other small issues tomorrow morning and then release 0.7.6.
                                    I've been told that I need to add a lapped option for the sheathing as well since leaving the corners open like we do in the western US doesn't work out so well in the southeastern states.
                                    I think the next big item on the list I'll tackle is the garage doors so that at least we have one or two options for that available.
                                    I also have the pseudo code put together for exterior wainscoting (dual exterior cladding). The code behind that wall configuration will get a bit more complicated but hopefully it won't bog down the model too much.
                                    I currently have 18 major items on the todo list:
                                    • Interior Trim
                                    • Garage Doors
                                    • Door casing for interior walls
                                    • Gypsum wrap for interior openings
                                    • Ext. Sheathing LAP option
                                    • Wall Split Tool
                                    • Wall Join Tool
                                    • Gable Wall Tool
                                    • Wall Grouping
                                    • SSW Module
                                    • Columns Module
                                    • Bug with outside corners less than 90 deg. (framing)
                                    • Exterior Wainscoting
                                    • Some additional debugging or checking with the draw wall tool as it relates to auto-corner configuration and defaults for inputs.
                                    • Global settings parameter allowing user to toggle between standard stud sizes and custom sizes
                                    • Beam Tool (add to the columns module, one additional icon for toolbar).
                                    • Wall justification issue (currently the FRONT option is functional)
                                    • SHIFT key snapping to X or Y axis during wall creation.
                                    If there are other items you would like to see added to this list please feel free to send them in. Also this list is in no particular order, the squeaky wheel is getting the grease, so if you want something pushed to the top please let me know.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Currently pre-configured doors and windows are saved by the user and accessed by the plugin from the "library" sub-folder of the plugin. The problem I see with this is that if you want to upgrade the plugin and have to remove the "medeek_wall_ext" plugin folder then you must take the added step to copy the contents of the library folder and then put it back after the updated plugin has been installed.
                                      Perhaps there is a better location for the user library or I suppose I could make its very location user definable?
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        I've switched to CSS tooltips which allows me to utilize not only text but also graphics:
                                        http://design.medeek.com/resources/images/wall_su93_800.jpg
                                        I recognize the need for a detailed manual however I find that tooltips like these can be much more useful and instantly accessible.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Looking at the Sheathing Tab above you will also notice I am adding in the option to lap the sheathing at the corners. I figured I might as well knock this one out while the corner lapping code is still fresh in my head. If I wait too long I will have to recalculate and rethink all of the trigonometry (relearn my algorithm), I try not to work too hard, better to work smart
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Sheathing with the corner option set to "LAP":
                                            http://design.medeek.com/resources/images/wall_su94_800.jpg
                                            design.medeek.com
                                            • 11
                                            • 12
                                            • 13
                                            • 80
                                            • 81
                                            • 11 / 81
