    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.0m Views 28 Watching
    • medeekM
      medeek
      Looking at garage doors this morning and I have my ideas on how one should trim these out but I am wondering if the rest of community is inline with my thinking.
      Feel free to email me or post on the board a garage door jamb detail/section on how you would like these put together.
      I'm also going to add in an advanced framing menu for the garage door option wherein the user can specify the parameters for portal framing the opening, however I may not attack this one until later since there are much bigger fires to put out at the moment.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • Bob JamesB
        Bob James
        To take advantage of this offer, once you have purchased the wall plugin, simply email me with your client ID or username and that you would like to take advantage of the June 2018 Promo.
        I've just purchased the Wall plugin, but cannot find your email address
        • medeekM
          medeek
          Thank-you for your purchase and you support of this endeavor.
          My email is nathan@medeek.com
          design.medeek.com
          • Bob JamesB
            Bob James
            Thank you.
            Done
            • Bob JamesB
              Bob James
              Version 0.7.5
              Made some test walls with inside corners so the walls would be drawn on the outside of the path and had two problems:
              I expected the gypsum to be on the inside and the sheathing to be on the outside. This is what I got with the gypsum not only not on the inside, but buried in the 2x4:
              And the corners are offset so they did not meet.
              Note also that the wood has no texture even though the Auto Assign Materials was set to "Yes".
              With the blizzard of inputs, I've probably set more than one thing wrong, but have no idea what.
              • Bob JamesB
                Bob James
                Since nearly all the homes in the California South Coast have stucco walls, can you add a flat plane cladding to which I could add the appropriate stucco material?
                • medeekM
                  medeek
                  @ Bob James:
                  You have hit on two very important and interesting topics/issues with the plugin, I will do my best to address them both here:
                  1.) The wall justification (front, middle, back) is something I have been treating as a basic property or parameter of the wall. This morning as I really put on my thinking cap I came to the realization that this is not so. The justification is only really needed during the wall creation process and once the wall is created there is no justification, the wall just is.
                  With that being said I need to rework the wall creation tool slightly, it shouldn't be too big of an issue but will require some serious and careful thought. For now please only use the "FRONT" justification, the other two options are flawed by their very nature.
                  This may take me a couple days to fully think this through and come up with the correct solution. Please have patience with me while I work this one out, I need to do it slowly and carefully and get it right.
                  2.) I am not satisfied with the current system of applying materials to the wall assembly via the plugin. Since the plugin completely rebuilds the entire wall panel on any edit or addition of windows or doors it must somehow save the material being used for each element (group) within the attribute library. It is already setup to do this and works quite well.
                  One can also use the edit menu to select from a static list of materials.
                  I think a few things could help to make this better:
                  A.) The plugin can look at the currently defined materials in the model and give the user the ability to select from any of these materials as well as the hard coded materials within the wall edit menu.
                  B.) Perhaps and observer or something should be setup so that if the user manually opens up the wall assembly group and assigns a material to the cladding, sheathing or gypsum for a given wall panel this information is then updated within the attribute library.
                  C.) Provide an interface within the global settings where additional hard coded materials can be added to the existing ones. The user would upload an image, assign a name and specify the X and Y scaling.
                  In the meantime if you could send me over at least one stucco material that you commonly use, I would love to add it to the plugin as a permanent material option
                  design.medeek.com
                  • Bob JamesB
                    Bob James
                    Here is the stucco color for my house:
                    Of course, it needs a normal map or a bunp map when I render it in Thea.
                    Stucco
                    • medeekM
                      medeek
                      [attachment=0:2ixeuzqv]<!-- ia0 -->texture4.jpg<!-- ia0 -->[/attachment:2ixeuzqv]
                      Do you have a name or color you would like me to assign to this stucco.
                      design.medeek.com
                      • medeekM
                        medeek
                        My intent is to add in the portal framing option into the garage door module.
                        Yes, it will comply with the IRC standard but also give the user a few more options to further customize it. Portal framing is actually much more complex than just the prescriptive examples given in the IRC or IBC, one can engineer these things to be quite a bit more substantial, as I have done in the past.
                        Take a look at this example below:
                        404 - File or directory not found.
                        (design.medeek.com)
                        Here is a rather stout wall engineered with two portal frames and a shearwall (this was in a high wind and seismic location):
                        http://design.medeek.com/images/misc/PFH_EXAMPLE2.jpg
                        The plugin should not only be able to draw this but also perform the engineering checks as well.
                        design.medeek.com
                        • medeekM
                          medeek
                          [attachment=0:3jwkvlpz]<!-- ia0 -->texture4.jpg<!-- ia0 -->[/attachment:3jwkvlpz]
                          It should be noted that once a material is defined by the plugin in SketchUp there is nothing stopping the user from editing that material and changing it up.
                          Once a material is assigned and created the plugin does not try to recreate or change the material so technically you could assign your cladding to red brick for example and then simple change it to whatever you like. The important thing is that the plugin is looking for the name of the material when it regens the model, it doesn't care about all of the other properties of the material in question.
                          design.medeek.com
                          • medeekM
                            medeek
                            Just to prove my previous point about customizing materials I've edited the medeek_lumber material name that I use for all of the framing and applied a CMU image to it.
                            I then set the wall framing at 8 inches thick and switched to the no framing mode so that the walls are represented only by solid groups.
                            Voila, CMU walls:
                            http://design.medeek.com/resources/images/wall_su89_800.jpg
                            If there is an external brick facade with an air gap, the cladding can be turned on and air gap adjusted accordingly.
                            Even though I have not specifically set this plugin up for CMU or block walls theoretically one could use it in this manner to model this type of construction. The "NO FRAMING" mode may be quite a bit more useful than I originally thought.
                            design.medeek.com
                            • Bob JamesB
                              Bob James
                              Ideal for initial concept modeling. All-in-all, I'd probably use this mode more often than the complete set of details.
                                MtnArch
                                Nathan ... just wondering about the bundle deal. What about those of us that are current (paid) Truss and Foundation users who also contributed to your KickStarter campaign? Is there a way to align all of our licenses to one renewal date? I'd rather have one renewal (like Vali's Instant Architecture) than multiple individual ones. Also looking forward to when you add in the shear engineering element to the wall plugin!
                                Highest Regards,
                                Alan T. Hendry, RA
                                Architect
                                • medeekM
                                  medeek
                                  The Kickstarter Campaign supporters are also considered purchasers of the Wall Plugin, perhaps I was not clear enough in the promo newsletter, I apologize if that was not clear.
                                  The promotion applies to all supporters of the Kickstarter Campaign. In fact, it should apply even more so because of your willingness to take that serious leap of faith with me. As such I am willing to extend the same expiration date to all of the plugins to match the expiration date you currently have for the Wall Plugin.
                                  This only applies to Kickstarter Campaign supporters and to those who purchased the plugin prior to its initial beta release date.
                                  design.medeek.com
                                  • Bob JamesB
                                    Bob James
                                    Cladding_Stucco_Light_Tan
                                    • medeekM
                                      medeek
                                      Grabbed some code from the Truss Plugin this morning and now Glulam Beams are available for window or door headers:
                                      http://design.medeek.com/resources/images/wall_su90_800.jpg
                                      The species or types of Glulam beams available are: Western Species, Southern Pine, and UK, Australian and South African varieties.
                                      Its nice to be able to recycle some code, allows one to implement something very quickly.
                                      I'm currently working on the corner cladding issue and adding in the option for a LAP or MITER corner treatment.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        As a follow up to a previous post about a day ago I've enabled the wall cladding menus (draw tool and edit menu) so that option (A) as previously discussed above is now a reality:
                                        http://design.medeek.com/resources/images/wall_su91_800.jpg
                                        I find this solution a potentially a bit messy since all materials are available within the drop down so there is a possibility of duplicate listings but overall it seems fairly robust and offers the flexibility needed so that the user can define their own materials within SU rather than having to rely on the plugin for a static list of pre-defined materials.
                                        design.medeek.com
                                        • Bob JamesB
                                          Bob James
                                          Is there a new version that includes this? Version 0.7.6?
                                          • medeekM
                                            medeek
                                            Version 0.7.6 is not yet released, so far it will encompass the following fixes and possibly some more:
                                            • Addition of glulam headers for windows and doors
                                            • Fixed a bug with the exterior corner trim (end corner)
                                            • Dynamic material list for cladding
                                            • LAP and MITER options for corner treatment of the cladding (still a few more hours of coding and testing to go, but progress is solid).
                                            design.medeek.com
                                            • 11
                                            • 12
                                            • 13
                                            • 80
                                            • 81
                                            • 11 / 81
