    Electrical cord modelling help please
    4 Posts 2 Posters 64 Views 2 Watching
      I am doing a lamp model. Electrical cords are my nemesis. Could somebody please suggest a method to do model Lampcord.pnga believable lamp cord?
        I tend to use Clothworks to run a sim on a divided line...
        https://i.imgur.com/acV1U9w.png
        ...some proxies to act as colliders and a few pins where I need them.
        You can use HelixAlongCurve to generate coiled wires if that's your thing...
        https://i.imgur.com/Ii73Ftq.png
          Then you position your camera inside the helix with a nice DOF and click render with Rayscaper
          https://i.imgur.com/pzXJFxN.png
          File attached to see clothworks setup if you need it
          liam-wire.skp
            Thanks heaps Rich πŸ‘ I do not know why I have an aversion to plugins, to my detriment I expect. Though I will download clothworks but the wait time to receive the plugin did not work with my workflow.
            Did you do the cable with the follow me tool?
            I did not see your post in time, but thank you very much for it. I ended up figuring out my own way which turned out OK. I have attached an image of my methodology which basically was to do a 2d follow me and the slice it and rotate the segment and then join them. Sounds fiddly but in fact was quite easy.
