    Modern patio
    11 Posts 3 Posters 283 Views 3 Watching
    • Bryan KB Offline
      Roughly based on a picture I saw.
      • Bryan KB Offline
        Anyone have suggestions for where I can get the best trees? I usually can't afford to buy assets, but I have some spare in the budget for a change (get it? spare change?) and this upcoming render is going to need it.
        • L Online
          I like that courtyard image a lot. I thought the couch should align for with the table though. I would suggest globe trees. What format do you require? And what render engine will you be using?
          • Bryan KB Offline
            The original pciture shows them not aligned. Weird, but that's the way it was. I will probably refine the furniture.
            I'll be using Raylectron to render, so I need tree for SU proper. Thanks.
            • L Online
              Hi Bryan, you can get trees in Globe plants in SKP format. I would suggest low poly or the use of skimp. At that istance the low poly Globe trees are very good πŸ˜‰
              • Bryan KB Offline
                Just took a look. Wow. Yeah, those are high quality. πŸ‘ And prices are decent!
                • Bryan KB Offline
                  Update.
                    Nice, has a great 'vibe' to it. πŸ‘ I think the tree's are more apropriate too.
                    • Bryan KB Offline
                      Thanks Mike!
                      This is from a picture by Akima Studios. Once again I may have bit off more than I can chew. For example, the center tree needs to be a whole lot wider. A LOT wider and more gnarly.
                      Second, the background is fog as in the original, but I cannot get it to render exactly right. The test renders look pretty good, but they pale compared to the original picture. I'm still working on the lighting. But the test renders do look good enough to present as is.
                      • L Online
                        @bryan k said:
                        Thanks Mike!
                        "this picture" is not attached. Trying to emulate an existing image is a very good way to improve skills. Nowhere to hide when you have a reference to try to live up to. πŸ‘ πŸ‘
                        Bryan KB 1 Reply Last reply Reply Quote 0
                        • Bryan KB Offline
                          Bryan K @L i am
                          Arghh, got busy and forgot. You may see why I like it.
                          Here's the pic.
