    Soap Skin & Bubble
    19 Posts 9 Posters 38.7k Views 9 Watching
    • soloS Offline
      @dave r said:
      @solo said:
      Soap skin expired, how does one renew it?
      Reinstall it from https://extensions.sketchup.com/en/content/soap-skin-bubble
      Current expiration is April 10, 2020.
      I have no idea why the author makes it expire except it forces users to keep it up to date.
      Thanks, unlike many plugins, once you install it one needs to restart for it to work again.
        Simply to be sure that user uses the last version for track bugs more efficiently! πŸ€“
        It's a little coder's trick! πŸ˜‰
        • jujuJ Offline
          juju
          I sure hope he (or she) stays healthy!
            French Lady Jeanne Calment has lived to 122 years! πŸ˜‰
              What extensions has she written?
                The extension of one's own life! πŸ˜‰
                  Dront
                  The same problem.
                  OK with every loop except circular.
                  Running the latest version from Extension Warehouse.
                    Soap Skin & Bubble with a circle after adding some pressure using the Generate Soap Bubble tool. Seems to work for me.
                      You have an another free true gem like Soap Skin Bubble πŸ‘
                      It has best results following different Start forms! πŸ˜‰
                      Ferrari 😎
                      http://sketchucation.com/forums/download/file.php?id=58250
                      Else Soap works fine with a circle! πŸ˜‰
                        JUHIL123456 Newcomers
                        Sketchup extension soap bubbles skin not proper work really disappointed this plugin.
                          What do you mean by that? Be specific. Share your SketchUp file so we can see what you are working with. The extension works fine if it is used the way it is designed to work.
                          What version of SketchUp are you actually using? You put Free/Make 2022 in your forum profile but there is no such version.
