    Soap Skin & Bubble
    19 Posts 9 Posters 39.1k Views 9 Watching
    • boofredlayB
      boofredlay
      Can you post a model that is not working for you?
        Post your SKP file! πŸ€“
        (save as V6 for a more large audience! πŸ˜‰
        • BoxB
          By the way, the resources forum isn't locked, the padlock is just a rather unfortunate symbol for the parent folder which contains the sub forums, The Plugin and Post pro titles are the relevant subforums of Resources.
          And as everyone has said, post a model as we aren't having any issues doing round shapes.
          • soloS
            Soap skin expired, how does one renew it?
              Reinstall it from https://extensions.sketchup.com/en/content/soap-skin-bubble
              Current expiration is April 10, 2020.
              I have no idea why the author makes it expire except it forces users to keep it up to date.
              • soloS
                Thanks, unlike many plugins, once you install it one needs to restart for it to work again.
                  Simply to be sure that user uses the last version for track bugs more efficiently! πŸ€“
                  It's a little coder's trick! πŸ˜‰
                  • jujuJ
                    juju
                    I sure hope he (or she) stays healthy!
                      French Lady Jeanne Calment has lived to 122 years! πŸ˜‰
                        What extensions has she written?
                          The extension of one's own life! πŸ˜‰
                            Dront
                            The same problem.
                            OK with every loop except circular.
                            Running the latest version from Extension Warehouse.
                              Soap Skin & Bubble with a circle after adding some pressure using the Generate Soap Bubble tool. Seems to work for me.
                                You have an another free true gem like Soap Skin Bubble πŸ‘
                                It has best results following different Start forms! πŸ˜‰
                                Ferrari 😎
                                http://sketchucation.com/forums/download/file.php?id=58250
                                Else Soap works fine with a circle! πŸ˜‰
                                  JUHIL123456 Newcomers
                                  Sketchup extension soap bubbles skin not proper work really disappointed this plugin.
                                    What do you mean by that? Be specific. Share your SketchUp file so we can see what you are working with. The extension works fine if it is used the way it is designed to work.
                                    What version of SketchUp are you actually using? You put Free/Make 2022 in your forum profile but there is no such version.
