    [Plugin] FredoTools::SolidVolume - v1.4a - 10 Feb 20
    25 Posts 8 Posters 19.3k Views 8 Watching
    • fredo6F
      @alex37550 said:
      Hi Fredo
      I was so happy to find this plug in volumes, but it seems there is a problem with the volumes. i had a complex solid an found a volume that seemed very big. So i try with a small cube with an hole (20 cm for each side) and there is definitively a bug.
      You are right. There is definitely a bug and this is annoying.
      I fixed it, and will re-release (as soon as the certification on EWH works again).
        Alex37550
        thanks for your reactivity !
        will you publish a reply when it will be downloadable?
        Alex
        • fredo6F
          Alex
          Just republish, now that EWH certification seems to work again.
          Please advise if this fixes your problems.
            Alex37550
            Alex
            I have not seen your post.
            Thank you Fredo.
            I downloaded all new versions of you plug in and solid volumes works now.
            Alex
              DGR
              Hi Fredo6
              It seems that the bug in solid volume is back
              Regards
              Dirk
              Component_1.skp
              • fredo6F
                Thanks for signaling. A major bug actually.
                Fixed in FredoTools 3.2c.
                • fredo6F
                  NEW RELEASE: FredoTools::SolidVolume v1.4a - 10 Feb 20
                  SolidVolume 1.4a is a major release fixing issues in some situations where faces where not properly oriented.
                  See main post of this thread for more information.
                    jure
                    Hi!
                    Calculation of volume is wrong in certain cases. See attached file.
                    solid_volume_wrong_volume.skp
                    • fredo6F
                      Got it and fixed it. Need some repackaging and will publish soon.
                      By the way, the main interest of SolidVolume is that it is supposed to work on pseudo solids too, as shown in the video.
                      • fredo6F
                        NEW RELEASE: FredoTools::SolidVolume v1.5a - 13 Nov 23
                        SolidVolume 1.5a is a major release fixing issues in the calculation of volumes in some situations where the solid is scaled. It also adds the capability to compute the volumes of pseudo-solids: objects with multiple solids inside, objects with holes in faces or some mssing faces.
                        Reply Quote -1
                        • O
                          oheimala
                          Thanks for your excellent tool. I use it for calculating weights of the components. Would it be possible to add there an input field for the density and then show the weight? I have not found such tool made already
                          Dave RD fredo6F 2 Replies Last reply
                            Dave R @oheimala
                            @oheimala that sounds like a nice option for this tool. FWIW, TIG's Center of Gravity extension will calculate the weight/nass of objects based on the density you enter into the UI. And you get the CoG located, too.
                            • fredo6F
                              fredo6 @oheimala
                              @oheimala
                              This sounds possible, but a little bit of work for the GUI (density field and choice of units for weight).
                              I would do as suggested by Dave R. There are specialized plugins, who can handle much better the real caes where the density varies by object.
                                jure
                                Hi Fredo... I noticed that SolidVolume still displays volume sometimes differently than other tools:
                                https://drive.google.com/file/d/16MUlyC0d4lm0HtqrOzJ6Hpf43_rMrboO/view?usp=sharing
                                fredo6F 1 Reply Last reply
                                • fredo6F
                                  fredo6 @jure
                                  @jure
                                  Thanks for signaling the problem. I actually forgot to update the plugin.
                                  It's now done with FredoTools v4.5c, just published.
