    [Plugin] FredoTools::SolidVolume - v1.4a - 10 Feb 20
    25 Posts 8 Posters 19.8k Views 8 Watching
    • fredo6F
      NEW RELEASE: FredoTools::SolidVolume v1.1c - 28 Apr 15
      SolidVolume 1.1a is a release with a few enhancements:
      • It now computes the faces area of solids in the selection.
      • The volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner.
      • You can choose your preferred unit and number of decimals for display of values
      See main post of this thread for more information.
      • fredo6F
        NEW RELEASE: FredoTools::SolidVolume v1.1d - 29 Apr 15
        SolidVolume 1.1d is a release fixing a problem of display of the main dialog box.
        • fredo6F
          NEW RELEASE: FredoTools::SolidVolume v1.2a - 09 Jul 15
          SolidVolume 1.2a is a minor release allowing holes for a shape to be considered as a solid. The Volume is computed as if there was no hole, but the area of faces takes the holes into account.
            Alex37550
            Hi Fredo
            I was so happy to find this plug in volumes, but it seems there is a problem with the volumes. i had a complex solid an found a volume that seemed very big. So i try with a small cube with an hole (20 cm for each side) and there is definitively a bug. see image
            I downloaded the latest versions of LibFredo, FredoTools (09 Jul 17) and that is the same
            anyway, thanks a lot Fredo for all your super plugins !
            have a good week !
            Alexandre
            bug solid volumes
            • fredo6F
              @alex37550 said:
              Hi Fredo
              You are right. There is definitely a bug and this is annoying.
              I fixed it, and will re-release (as soon as the certification on EWH works again).
                Alex37550
                thanks for your reactivity !
                will you publish a reply when it will be downloadable?
                Alex
                • fredo6F
                  Alex
                  Just republish, now that EWH certification seems to work again.
                  Please advise if this fixes your problems.
                    Alex37550
                    Alex
                    I have not seen your post.
                    Thank you Fredo.
                    I downloaded all new versions of you plug in and solid volumes works now.
                    Alex
                      DGR
                      Hi Fredo6
                      It seems that the bug in solid volume is back
                      Regards
                      Dirk
                      Component_1.skp
                      • fredo6F
                        Thanks for signaling. A major bug actually.
                        Fixed in FredoTools 3.2c.
                        • fredo6F
                          NEW RELEASE: FredoTools::SolidVolume v1.4a - 10 Feb 20
                          SolidVolume 1.4a is a major release fixing issues in some situations where faces where not properly oriented.
                            jure
                            Hi!
                            Calculation of volume is wrong in certain cases. See attached file.
                            solid_volume_wrong_volume.skp
                            • fredo6F
                              Got it and fixed it. Need some repackaging and will publish soon.
                              By the way, the main interest of SolidVolume is that it is supposed to work on pseudo solids too, as shown in the video.
                              • fredo6F
                                NEW RELEASE: FredoTools::SolidVolume v1.5a - 13 Nov 23
                                SolidVolume 1.5a is a major release fixing issues in the calculation of volumes in some situations where the solid is scaled. It also adds the capability to compute the volumes of pseudo-solids: objects with multiple solids inside, objects with holes in faces or some mssing faces.
                                Reply Quote -1
                                • O
                                  oheimala
                                  Thanks for your excellent tool. I use it for calculating weights of the components. Would it be possible to add there an input field for the density and then show the weight? I have not found such tool made already
                                  Dave RD fredo6F 2 Replies Last reply
                                    Dave R @oheimala
                                    @oheimala that sounds like a nice option for this tool. FWIW, TIG's Center of Gravity extension will calculate the weight/nass of objects based on the density you enter into the UI. And you get the CoG located, too.
                                    • fredo6F
                                      fredo6 @oheimala
                                      @oheimala
                                      This sounds possible, but a little bit of work for the GUI (density field and choice of units for weight).
                                      I would do as suggested by Dave R. There are specialized plugins, who can handle much better the real caes where the density varies by object.
                                        jure
                                        Hi Fredo... I noticed that SolidVolume still displays volume sometimes differently than other tools:
                                        solid_volume_wrong_volume 4.5a.skp
                                        Google Docs (drive.google.com)
                                        fredo6F 1 Reply Last reply
                                        • fredo6F
                                          fredo6 @jure
                                          @jure
                                          Thanks for signaling the problem. I actually forgot to update the plugin.
                                          It's now done with FredoTools v4.5c, just published.
