    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    SUClock not working with new update
    5 Posts 3 Posters 84 Views 3 Watching
    • E Offline
      Ehay
      Has anyone else experienced issues with SU not opening?
      I found the issue being with an .suclock being attached to the .skp file. Once I deleted the .suclock file my .skp file would open just fine. Now I don't have a time tracker for my projects.
      Does anyone know of a fix or a compatible time clock?
        Let him know in his feedback thread.
        https://sketchucation.com/forums/viewtopic.php?f=323&t=36699
        Your profile says SketchUp 2017
        • fredo6F Offline
          Difficult to say what has happened.
          Can you use SUClock again on the skp files and on other skp files?
          • E Offline
            Ehay
            Can you use SUClock again on the .skp files and on other skp files?
            If I open a new project (.skp) file, then add a .suclock file to that project it works fine. I save and close the file without issue.
            Reopening the file is where the issue is. Clicking the SU file opens a window, all white, then the SUClock window opens for a split second then both of the programs close.
            The fix I have found is to delete the .suclock file associated with the .skp file. Then the .skp file will open and be usable, but now I lose the time tracking ability.
            • E Offline
              Ehay
              I just did another troubleshoot. Sketchup v2022 will load my .skp file and SUClock with no issues upon closing or reopening of the file.
