    EMD SD45 - Union Pacific
    47 Posts 10 Posters 4.4k Views 10 Watching
    • Gus RG Offline
      Gus R
      Started a Union Pacific EMD SD45 locomotive based on a Broadway Limited HO model and various other (growing references). They have some really high quality profile images there. It's possible I can do other railroads but that would require some tweaking since there's no real standard for the SD45 and railroads had them built with different specific requirements.
      Nothing really difficult except for I have tendency to get bogged down in minute details which is a hindrance to progress. Perfectionism is an obstacle to art. I still have to finish the neck for the Fender Telecaster.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      • axeonaliasA Offline
        axeonalias
        Great start! are you modeling it to render / animate ?
        https://sketchfab.com/Axeonalias
        • Gus RG Offline
          Gus R
          Thanks axeonalias. Just some renderings for now. I'm not really skilled in animation yet. Maybe I'll try it in D5 Render.
          • Gus RG Offline
            Gus R
            Update.
            Added dynamic brake fans/exhausts, bolts, panels, panel latches, and panel hinges and misc.
            Starting the trucks which is a little complicated. There's also a lot of cables and hoses, brake parts, etc.
            • Gus RG Offline
              Gus R
              Update! Breaking the rules here with the final lights and such since it bogs down rendering times. This is done in Thea Render. Found a lot of good reference photos for the headlamp at Worth Point.
              • Gus RG Offline
                Gus R
                What it looks like in raw SU and another rendered view.
                  Just fantastic detail Gus, radius on the door and rivets. lovely work πŸ‘
                  • ntxdaveN Offline
                    ntxdave
                    Absolutely agree! πŸ‘
                    Press F1...thank me later
                    • boofredlayB Offline
                      boofredlay
                      So good.
                      • Gus RG Offline
                        Gus R
                        Thanks guys!
                        Can't run a railroad without a Type E couple. I was going to use someone else's 3D but decided to give it a shot in Sketchup. The majority of rounded edges is varying degrees of beveling applied in Thea Render. Some of the other larger fillets were impossible to model at this time.
                        What looks like machine boring isn't really necessary although it does keep me motivated on the craftsmanship. It's not 100 percent accurate.
                        • Mike AmosM Online
                          A 'proper' job done, very nice indeed. πŸ‘ πŸ‘
                          • Gus RG Offline
                            Gus R
                            More parts! Started the trucks and ordered a plan of the trucks from Norfolk & Western Historical Society. This shows the Hyatt journal box, brake cylinder and a part of the truck frame which is really cast steel and was usually painted silver for Union Pacific SD45's. I like the color yellow but it probably looks like Caterpillar equipment here.
                            • ntxdaveN Offline
                              ntxdave
                              The details and render results are excellent. Looks more like photos than renders. πŸ‘ πŸ‘
                              • Gus RG Offline
                                Gus R
                                Thanks Dave.
                                Here's the latest. Working on the trucks. Got the plans from Norfolk & Western Historical Society for $30. Hard to find this level of detail anywhere.
                                This is an earlier version of the EMD truck but it's easily modified to the correct version. Short of my obsession with details.
                                P 2 Replies Last reply Reply Quote 0
                                  Brilliant, nothing less πŸ‘ πŸ‘ πŸ‘
                                  • ntxdaveN Offline
                                    ntxdave
                                    Agree 100% πŸ‘ πŸ‘ πŸ‘
                                    • tuna1957T Offline
                                      tuna1957
                                      Bravo πŸ‘
                                      • Mike AmosM Online
                                        Superb, makes for a better day seeing this. πŸ‘ πŸ‘
                                        • Gus RG Offline
                                          Gus R
                                          Thanks everyone!
                                          We've got wheels. OK, they're not precise but it's a start. Also added a bunch of brake system cranks and a sand dispenser system. I'm probably getting carried away with the level of detail but I need the practice. It's forcing me to model a bunch of intricate parts I'm not familiar with.
                                          • Gus RG Offline
                                            Gus R
                                            Found more details thanks to a video from ccrx6700 on Youtube. Need to add the traction motor and brake system and modify it for a later version of the Flexicoil trucks. Looking like a restomod truck for now but that's part of the fun. Rendered with Thea Render.
                                            On a side note. Grainger has 3D models for fasteners, bolts, etc. The lock bolt for example was downloaded as an stl file and converted to an obj file and imported into Sketchup. Needs some cleanup if you're going to use them a lot of times.
                                            The blue is using metal flakes (car paint) from Thea. I won't use that for the final renderings of the SD45. Usually the railroad companies just spray everything with a single color and in the case of this example it's a silver paint. I just do this to keep me awake. πŸ’š
                                            • 1 / 3
