    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 227.1k Views 57 Watching
    • jed clampitJ
      jed clampit
      i just cannot get my head round this, watched video after video and i don't know what i am doing wrong. i cannot even get it to impose a grid let alone wrap the object any ideas where i am going wrong ?
      bonet cushion v2.skp
        I can help you only if you save your fil SKP in 2017 version or earlier!
        Your profile said 2013 but seems that is not updated! πŸ˜‰
        • jed clampitJ
          jed clampit
          thank you pilou and i have update the profile
          i get the error message ''The extension skb is not allowed'' when i try to upload the 2017 file
          copy bonet cushion v2.skp
          • jed clampitJ
            jed clampit
            oops it worked that time once approved πŸ‘
              The .skb file is a backup file which is not an allowed file type to upload. The upload worked the next time because you uploaed the actual SketchUp file which has the .skp extension.
              • jed clampitJ
                jed clampit
                i just got a little confused David πŸ˜•
                  I believe that your object to project must be only one Group of elements and not a group of "groups"!
                  So explode all and make only one simple group! πŸ˜‰
                  1 Reply Last reply πŸ‘
                    And for the entiere target grid you must make a "quadrangular UV" and not a "concentric" pattern!
                    • jed clampitJ
                      jed clampit
                      so effectively it isn't going to work on that shape 😞
                      ok thank you i will need to find another way of doing it
                        maybe something like this...not an easy thing! πŸ˜‰
                          Maybe you need to scale it up. If I was going to model something with small detail like your model will have, I would scale it up by a factor of 1000 at least.
                          • jed clampitJ
                            jed clampit
                            i scaled it up by 2000 but still didn't work
                              it's that i suspected! πŸ˜„
                              You must make UV (or similar) on your target object!
                              Fredo Corner or similar don't make it!
                              Here a complex one surface with recesses like your that works perfectly! πŸ˜„
                              (but without "concentric" facetts)
                              • E
                                eue
                                why can not see tool bar and error flowify plugin in sketchup
                                  What toolbar? There isn't one for this extension. It is accessed from the Extensions menu.
                                  What error exactly?
                                  What version of SketchUp are you using?
                                  • C
                                    camilamichalouski
                                    Hello Caul,
                                    The plugin doesnΒ΄t work to SU 22. ItΒ΄s possible to update?
                                    Thank you in advance,
                                    Cami
                                      Flowify dpes work in SketchUp 2022. Looks like your model isn't set up correctly. Share the file so we can see what you've got going on.
                                      • panixiaP
                                        panixia
                                        Not necessary to upload the file, the screenshot clearly reveals that problem was between chair and keyboard.
                                        Flowify requires you to select BOTH the component and the flowify rig at the same time before you run the command.
                                        The guy has only the rig selected and not the stair component, so that the plugin doesn't work and of course ask for additional "input" (the beloved component).
                                          R0bBot
                                          This seems awesome and exactly what I would need...if I could have it working for my situation. Trying to add like a slime around a pot so I cut the pot in half, the geometry looks clean. I followed the instructions but when I tried to impose grid nothing happens. And when I try to flowify it, I get an error "error while parsing the projection grid". not sure what im doing wrong
                                          • robertWanR
                                            robertWan
                                            There is no chance for the plugin to work in SU8?
                                            Robert
                                            • 6 / 7
