    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 227.1k Views 57 Watching
    • locoL
      loco
      What is the most recent update for Flowify? Has it been updated yet for SketchUp 2021 or 2022?
      Windows 10, gpu rtx 3060 12gb ram, cpu AMD Ryzen 5 5600X 64gb ram, SketchUp 2022, Twinmotion 2022. My Little Tutorial
        Take somewhere a version of the free 2017 Make for use the Flowify! 😉
        • locoL
          loco
          I see, thanks Pilou. So it hasn't been updated for these versions?
          • jed clampitJ
            jed clampit
            i just cannot get my head round this, watched video after video and i don't know what i am doing wrong. i cannot even get it to impose a grid let alone wrap the object any ideas where i am going wrong ?
            bonet cushion v2.skp
              I can help you only if you save your fil SKP in 2017 version or earlier!
              Your profile said 2013 but seems that is not updated! 😉
              • jed clampitJ
                jed clampit
                thank you pilou and i have update the profile
                i get the error message ''The extension skb is not allowed'' when i try to upload the 2017 file
                copy bonet cushion v2.skp
                • jed clampitJ
                  jed clampit
                  oops it worked that time once approved 👍
                    The .skb file is a backup file which is not an allowed file type to upload. The upload worked the next time because you uploaed the actual SketchUp file which has the .skp extension.
                    • jed clampitJ
                      jed clampit
                      i just got a little confused David 😕
                        I believe that your object to project must be only one Group of elements and not a group of "groups"!
                        So explode all and make only one simple group! 😉
                        1 Reply Last reply 👍
                          And for the entiere target grid you must make a "quadrangular UV" and not a "concentric" pattern!
                          • jed clampitJ
                            jed clampit
                            so effectively it isn't going to work on that shape 😞
                            ok thank you i will need to find another way of doing it
                              maybe something like this...not an easy thing! 😉
                                Maybe you need to scale it up. If I was going to model something with small detail like your model will have, I would scale it up by a factor of 1000 at least.
                                • jed clampitJ
                                  jed clampit
                                  i scaled it up by 2000 but still didn't work
                                    it's that i suspected! 😄
                                    You must make UV (or similar) on your target object!
                                    Fredo Corner or similar don't make it!
                                    Here a complex one surface with recesses like your that works perfectly! 😄
                                    (but without "concentric" facetts)
                                    • E
                                      eue
                                      why can not see tool bar and error flowify plugin in sketchup
                                        What toolbar? There isn't one for this extension. It is accessed from the Extensions menu.
                                        What error exactly?
                                        What version of SketchUp are you using?
                                        • C
                                          camilamichalouski
                                          Hello Caul,
                                          The plugin doesn´t work to SU 22. It´s possible to update?
                                          Thank you in advance,
                                          Cami
                                            Flowify dpes work in SketchUp 2022. Looks like your model isn't set up correctly. Share the file so we can see what you've got going on.
                                            • 6 / 7
