    Optionally manned drone.
    43 Posts 5 Posters 3.5k Views 5 Watching
      First decals, also geometry rather than graphics.
      • Bryan KB
        Oh yeah! πŸ‘
          Ta mate, the other (Port) side has had me pulling hair, really quite a bit.......
          • Bryan KB
            I run into this a lot. πŸ˜†
            My trick is to make the opposite side component Unique and then apply the lettering right way reading.
              Agreed but, the geometry does not always 'like' this which drive me a little potty time.
              Well, Mr Bentine thought so.
                Port side decals.
                • Bryan KB
                  Wow! Looking really good!
                    Tickling the edges now, not too much change at one given time because it is finer changes being made. Moving to Gallery now as I think I am getting there now.
                      Looking at alternate HDRI and static rotor options.
                      • axeonaliasA
                        axeonalias
                        Shot looks great, but the scale is off with the HDRI there, Looks tiny now, like a 1:5 scale RC Heli?
                        https://sketchfab.com/Axeonalias
                          I know, waiting for someone to spot that. Laughed my head of when I did. 🀣
                          • Bryan KB
                            Render looks great!
                            Yeah HDRI scaling can be a bugger. Still looks good. πŸ‘
                              Fleuch has suggested some tree's, OK, more a grass field but shows how it pays to be careful when choosing colours/textures in different light setting. The codes have almost completely vanished. The straight lines in the ground plane are the shadow catcher which I must address.
                              • ntxdaveN
                                ntxdave
                                I like the background image and the ground and the way you got them to blend together. I have not been able to get things to blend that good. Where did you get the background image? What texture/material did you use for the ground? My problem might also be my camera angle.
                                I like the render. πŸ‘ Fletch always seems to come up with good suggestions. πŸ˜„
                                Press F1...thank me later
                                  That image has a simple flat plane and a jpg version of the hdri, rotated to match the hdri so 0 degrees here.
                                  I have used an infinite plane (Extensions - Twilight render - Objects - Infinite plane) with the next render painted with a simple colour, Alice blue in this case. Colour is then linked to the texture via the texture/finish dialogue box in Twilight. Not perfect as there is still a straight line visible in the hdri/infinite plane but meh.
                                  • ntxdaveN
                                    ntxdave
                                    Thanks for sharing this info. I don’t think I have that background. I have used the infinite plain before. Lately I have been enjoying using the Skatter plugin for adding/placing foliage in the model. That will not work correctly (I don’t think) with the infinite plain. Can/would you share the background image?
                                      I certainly will mate, thought I already had but essentially I am an old git so forgetful at times.
                                      Too big or file type not allowed. Working on a dropbox attachment, give me a minute or so.
                                      • Bryan KB
                                        That turned out nice! πŸ‘
                                        I have that same HDRI and used it many times.
                                        • 2 / 3
