    [Plugin] LordOfTheToolbars - v2.9c - 20 Dec 24
    481 Posts 92 Posters 355.5k Views 91 Watching
    • panixiaP Offline
      panixia
      @laurent002 said:
      Hello,
      I have installed LordOfTheToolBars on sketchup 2023, but there is no access to any menus tools. Only icons. It means that i can't creat icons, anything.
      The most interresting thing about your plugin.
      What can I do to fixe or modify to fixe that link problem.
      Thanks for your help.
      Not exactly the same, but you can achieve similar result with this workaround.
      http://sketchucation.com/forums/viewtopic.php?f=323&t=73776&view=unread#p687744
        Julien 2
        Thanks for the suggestion, I will give a try πŸ˜‰
        • H Offline
          HouseOfBOP
          I seem to have lost the Quick Command finder. I'm using Sketchup 2021 pro, and have the latest LibFredo and LOTT. I've tried reinstalling LOTT and have Sketchup installed as admin.
          Is there any way to reset the position of where the quick command finder dialog pops up - or have I broken something?
          Thanks v much
          T
          • H Offline
            HouseOfBOP
            I seem to have lost my Quick Command Finder pop up. I'm all up to date, Sketchup installed as admin, and have reinstalled LOTT.
            Is there a way to reset where the popup pops up - or have I missed or broken something? I'm on 2021 Pro.
            • fredo6F Offline
              Do you have several monitors?
              • H Offline
                HouseOfBOP
                I'm on a laptop with an extra screen. I disconnected the second screen when I was trying to retrieve the popup. No luck though.
                • fredo6F Offline
                  Could you do the following
                  1. Open the Ruby Console
                  2. Launch the LOTT Find dialog
                  3. Copy paste the following command in the Ruby console and press Enter
                    Traductor::ChromiumWdlg.check_instance_displayed("LOTT_MiniFindDialog", true).set_position(0, 0)
                  The Find dialog should go to the position top left corner of your screen.
                  • H Offline
                    HouseOfBOP
                    That solved it. Thanks so much.
                    Take care
                    T
                      AISmebel
                      Hi Fredo. Please tell me, is the operation of "menu" in SketchUp 2023 expected to be restored in the future? Is there any news?
                      • fredo6F Offline
                        It fully depends on the Sketchup developers. I filed the requests some time ago.
                        But, frankly, no idea....
                          AISmebel
                          Your plugin is amazing, I can't imagine further use of SU without it. Ot perfectly optimizes the workspace, "menu" is an integral part of it. Maybe we can help? I suggest, just like you, to make a request to the developers of SU.
                          • N Offline
                            NF_TM
                            Thanks again for all your great plugins!
                            I have a question on LordOfTheToolbars.γ€€2.4a
                            I am using Mac (mac OS Montrey).
                            1. I would like to use skp2023 but the icon hover does not work.
                              I was able to use skp2022 with no problem.
                            2. I am using V-ray, but I cannot customize the icons.
                              V-ray does not appear in the master toolbar manager...
                            I would like to ask if this can be improved in the settings.
                            Thank you in advance for your confirmation.
                              Avex
                              Hey, I'm having an issue installing in SU2021. It says "Could not unzip archive".
                              Don't know why nor what to do.
                                How are you trying to install it?
                                What operating system? Please complete your forum profile.
                                  Avex
                                  Thanks for the reply.
                                  1. Downloaded from here https://sketchucation.com/plugin/2430-lordofthetoolbars
                                  2. Installing from:
                                  a. DropZone, no apparent error.
                                  https://lh3.google.com/u/0/d/1O4V9S5sLYZuN2-0gOcZ77teuZrGlbtu9=w2560-h968-iv1
                                  b. Install Menu, "Could not unzip archive".
                                  https://lh3.google.com/u/0/d/1m7TkaC1mDK_UmfhMFXN9Q4jnJBeKuFLg=w2560-h588-iv1
                                  https://lh3.google.com/u/0/d/1om44w9zYNvJ_C5Q8yJmdjNNqTHIxOiWa=w2560-h968-iv1
                                  c.Extension Manager, just "Failed"
                                  https://lh3.google.com/u/0/d/1Rppfci0WAJja9VuUJ7mDxDDpnCYebiDx=w2560-h968-iv1
                                  OS, Win10
                                    Download and install the Sketchucation ExtensionStore tool. Then use it to install the extension.
                                    Which version of SketchUp? Did you install SketchUp correctly? That requires right clicking on the downloaded installer and selecting Run as administrator.
                                      carlosmgilp
                                      Hello how are you.
                                      I wanted to report that when I open sketchup 2023 it never remembers where the custom bars were anchored.
                                      And I have to be locating them every time I open sketchup.
                                      Another thing that I notice is that the tools created from the menu no longer work and I know that they are installed.
                                      I use Sketchup 2023 and LordOfTheToolbars v2.4a
                                      In what you can help me, I appreciate it.
                                      Greetings.
                                        SoundDoc
                                        @panixia said:
                                        I have a workaround for this.
                                        Assign some weird shortcut to your menu item (I say "weird" because maybe you don't want to waste some available handy keyboard shortcut for this).
                                        Then create a ruby script button and type in the following....
                                        Thank you for that, greatly appreciated.
                                        I'm not sure if related to the other comments about depreciations in Ruby (I can't see win32ole being depreciated) but I did need to import it (at least for thefirst time use) in order to use your workaround.
                                        My enviroment is SU v23 Pro on Windows 10, its a fairly recent clean windows/sketchup install and most Fredo's other plugins & libraries have been loaded for a while.
                                        Simple one line modification to yours:
                                        require "win32ole"
                                        shell = WIN32OLE;;new("WScript.Shell")
                                        shell.SendKeys "InsertYourWeirdSendkeyShortcutHere"
                                        I added some notes/comments to my script as I've had a few friends ask how I was able to get my toolbar icons working again (specifically ones for thomthom's cleanup which has none by default).
                                        If it helps others just copy/paste the below into the ruby script button to replace the default there and adjust per panixia's instructions:
                                        # LOTT - Personal Command "Workaround" - all credits go to panixia at Sketchucation Forums;
                                        # https://sketchucation.com/forums/viewtopic.php?f=323&t=73776&start=270#p687744
                                        # 1. Assign a "weird" shortcut key (something you wouldn't want to use elsewhere) via
                                        #    "Preferences -> shortcuts" to the menu item desired. eg. Ctrl+Shift+Alt+F11
                                        # 2. Replace the text between the quotes "InsertYourWeirdSendkeyShortcutHere"
                                        #    in the code below with the shortcut key you assigned using Sendkeys syntax.
                                        # 3. (Optional) If you also want to use a "normal" shortcut key (eg Ctrl+Shift+C)
                                        #    assign it to this script using the "shortcut" field at the top of this window.
                                        # Some Common Syntax References below, the full syntax reference is available at;
                                        # https://learn.microsoft.com/en-us/office/vba/language/reference/user-interface-help/sendkeys-statement
                                        # Common SendKeys References;
                                        # Modifier Keys;  CTRL; ^ | SHIFT; + | ALT; %
                                        # Held Keys;      HELD(KEY1 KEY2)   eg; +(EC)     would hold shift while pressing E then C.
                                        # Repeat keys;    {KEY NUMBER}      eg; {LEFT 42} would press Left 42 times.
                                        # Function keys;  {KEY}             eg; {F11}     would press F11.
                                        # Script Modification Example;
                                        # 	To press "Ctrl+Shift+Alt+F11" (the weird shortcut you assigned to the menu item)
                                        # 	each time you hit the toolbar icon (or press a shortcut if assigned above)
                                        # 	change line 37 below as follows;
                                        # 		From; shell.SendKeys "InsertYourWeirdSendkeyShortcutHere"
                                        # 		to;   shell.SendKeys "^+%({F11})"
                                        # Troubleshooting;
                                        # - If you receive a ruby error regarding a uninitialized constant WIN32OLE
                                        #     uncommenting line 35 (delete the # at the beginning) may help.
                                        # - Some keys can be difficult to enter due to the editors autocorrect (eg."[")
                                        #     composing your command in another editor then copy/pasting to this window can help.
                                        #require "win32ole"    # uncomment if needed for a "uninitialized constant WIN32OLE error"
                                        Hopefully Trimbles SU developers will find a way to add/restore some methods into the new UI framework to allow developers like Fredo to fix/provide features like this. They greatly expand what Sketchup is capable of which imho makes it a much better tool for some things than many others out there.
                                        • fredo6F Offline
                                          NEW RELEASE: LordOfTheToolbars v2.5a - 26 Aug 23
                                          Requirements
                                          • LibFredo6: v14.2a or above
                                          LordOfTheToolbars 2.5a includes
                                          • Bug fixing
                                          • Future compatibility
                                          DO NOT FORGET TO UPGRADE TO LibFredo6 v14.2a or above
                                          Home Page of LordOfTheToolbars for information and Download.
                                          Main post of this LordOfTheToolbars thread.
                                            AISmebel
                                            "-Future compatibility" Encouraging))) πŸŽ‰
                                            • 11
                                            • 12
                                            • 24
                                            • 25
                                            • 10 / 25
