    Alphabet to sketch(up)
    204 Posts 7 Posters 13.3k Views 7 Watching
    • ntxdaveN Offline
      ntxdave
      Just looked at the pdf about your book again and I need to go off and play with all the letters some more. I have tried to be too precise which can put restrictions on the building designs. 👎
      I am still trying to lear both Krita (for laptop) and Sketchbook for iPad to do my sketching. Hope to be able to post something soon. 😄
      Press F1...thank me later
      • majidM Offline
        majid
        Good to know that Dave. Can't wait to see your progress. 👍
        • ntxdaveN Offline
          ntxdave
          In order not to corrupt this thread, here is a link to a “learning/practicing” thread on the Twilight Render forum Learning Thread.
          • ntxdaveN Offline
            ntxdave
            Here is my latest “sketch”. Yes, there are some some glitches.
            I am working on modeling this in SketchUp (having some challenges).
            Q Building sketch
            • majidM Offline
              majid
              It definitely is a big challenge, but your most recent sketch depicts a real progress IMO.
              • ntxdaveN Offline
                ntxdave
                Well, here is my latest work. The letter Q was the "inspiration" for this sketch and render.
                The windows did not turn out exactly as I had hoped. The reflection seem not to appear in all of them.
                • majidM Offline
                  majid
                  Nice result mate!!
                  Do you mind sharing more renders from different angels too?
                  • ntxdaveN Offline
                    ntxdave
                    @majid said:
                    Nice result mate!!
                    Do you mind sharing more renders from different angles too?
                    Thanks.
                    At some point, I will. However, some parts were only done for this view so I will have to finish the model. ☀
                    • ntxdaveN Offline
                      ntxdave
                      Another practice sketch. Several things wrong that I can to do better before taking building into SketchUp but again learning more about sketching (using Sketchbook on my iPad for my sketches.
                      “Practice” for letter S
                      Hope you can see which letter of the alphabet is my inspiration. 😄
                      • majidM Offline
                        majid
                        Another nice start.
                        Needless to declare that there is no obligation to stick to the initial form.
                        I also have shared samples. In fact as it is believed in "lateral thinking" those sketches are to make us think out of box.
                        • ntxdaveN Offline
                          ntxdave
                          @majid said:
                          Nice result mate!!
                          I did do some new/multiple renders which I posted on this Twilight Render forum thread Alphabet Inspired Sketches.
                          I am not happy with the results though. I tried to use the trial version of the Skatter plugin but still have a lot of things to learn so I can get tepee landscape and background better. When that happens I will post some new renders.
                          • majidM Offline
                            majid
                            I believe that there is a grass tutorial on Twilight forum (maybe by Fletch). It is viable in postpro. The result is realistic.
                            • ntxdaveN Offline
                              ntxdave
                              OK Finally some new images after spending a lot of time learning how to use the Skeatter plugin. Yjeu were rendered with Twilight Render V2
                              • ntxdaveN Offline
                                ntxdave
                                Scene 3
                                Sorry, I could not add this 3rd image to the previous post.
                                • ntxdaveN Offline
                                  ntxdave
                                  Scene 2 FIXED ❗
                                    • majidM Offline
                                      majid
                                      Very neat model and render!
                                      • ntxdaveN Offline
                                        ntxdave
                                        Thanks guys. 😄
                                        For some reason I made a lot of mistakes when learning how to use the Skatter plugin but I think it is a good plugin for putting vegetation in a SU model. It supports several render applications which allows you to put a number of instances of vegetation in a model without bringing SU to its knees when looking around in your model.
                                        • ntxdaveN Offline
                                          ntxdave
                                          Majid - just for you..............
                                          AIP-Majid
                                          • ntxdaveN Offline
                                            ntxdave
                                            Majid, this is just for you.............
                                            Alphabet Inspired Sketch - Majid
                                            • 11
                                            • 10 / 11
