    Alphabet to sketch(up)
    204 Posts 7 Posters 38.0k Views 7 Watching
      I am thinking about it but it's a way down the list at the moment, very busy with stuff.
      It does look very interesting, insightful.
      • majidM Offline
        majid
        It is worth reading IMO. I found it inspiring and influential.
        The good news is that the paperback version of my book is also available: https://lnkd.in/dGkuAFXW
        • ntxdaveN Offline
          ntxdave
          Just looked at the pdf about your book again and I need to go off and play with all the letters some more. I have tried to be too precise which can put restrictions on the building designs. 👎
          I am still trying to lear both Krita (for laptop) and Sketchbook for iPad to do my sketching. Hope to be able to post something soon. 😄
          Press F1...thank me later
          • majidM Offline
            majid
            Good to know that Dave. Can't wait to see your progress. 👍
            • ntxdaveN Offline
              ntxdave
              In order not to corrupt this thread, here is a link to a “learning/practicing” thread on the Twilight Render forum Learning Thread.
              • ntxdaveN Offline
                ntxdave
                Here is my latest “sketch”. Yes, there are some some glitches.
                I am working on modeling this in SketchUp (having some challenges).
                Q Building sketch
                • majidM Offline
                  majid
                  It definitely is a big challenge, but your most recent sketch depicts a real progress IMO.
                  • ntxdaveN Offline
                    ntxdave
                    Well, here is my latest work. The letter Q was the "inspiration" for this sketch and render.
                    The windows did not turn out exactly as I had hoped. The reflection seem not to appear in all of them.
                    • majidM Offline
                      majid
                      Nice result mate!!
                      Do you mind sharing more renders from different angels too?
                      • ntxdaveN Offline
                        ntxdave
                        @majid said:
                        Nice result mate!!
                        Do you mind sharing more renders from different angles too?
                        Thanks.
                        At some point, I will. However, some parts were only done for this view so I will have to finish the model. ☀
                        • ntxdaveN Offline
                          ntxdave
                          Another practice sketch. Several things wrong that I can to do better before taking building into SketchUp but again learning more about sketching (using Sketchbook on my iPad for my sketches.
                          “Practice” for letter S
                          Hope you can see which letter of the alphabet is my inspiration. 😄
                          • majidM Offline
                            majid
                            Another nice start.
                            Needless to declare that there is no obligation to stick to the initial form.
                            I also have shared samples. In fact as it is believed in "lateral thinking" those sketches are to make us think out of box.
                            • ntxdaveN Offline
                              ntxdave
                              @majid said:
                              Nice result mate!!
                              I did do some new/multiple renders which I posted on this Twilight Render forum thread Alphabet Inspired Sketches.
                              I am not happy with the results though. I tried to use the trial version of the Skatter plugin but still have a lot of things to learn so I can get tepee landscape and background better. When that happens I will post some new renders.
                              • majidM Offline
                                majid
                                I believe that there is a grass tutorial on Twilight forum (maybe by Fletch). It is viable in postpro. The result is realistic.
                                • ntxdaveN Offline
                                  ntxdave
                                  OK Finally some new images after spending a lot of time learning how to use the Skeatter plugin. Yjeu were rendered with Twilight Render V2
                                  • ntxdaveN Offline
                                    ntxdave
                                    Scene 3
                                    Sorry, I could not add this 3rd image to the previous post.
                                    • ntxdaveN Offline
                                      ntxdave
                                      Scene 2 FIXED ❗
                                        • majidM Offline
                                          majid
                                          Very neat model and render!
                                          • ntxdaveN Offline
                                            ntxdave
                                            Thanks guys. 😄
                                            For some reason I made a lot of mistakes when learning how to use the Skatter plugin but I think it is a good plugin for putting vegetation in a SU model. It supports several render applications which allows you to put a number of instances of vegetation in a model without bringing SU to its knees when looking around in your model.
                                            • 11
                                            • 6 / 11
