    Alphabet to sketch(up)
    212 Posts 7 Posters 62.3k Views 7 Watching
    • majidM
      majid
      It definitely is a big challenge, but your most recent sketch depicts a real progress IMO.
      • ntxdaveN
        ntxdave
        Well, here is my latest work. The letter Q was the "inspiration" for this sketch and render.
        The windows did not turn out exactly as I had hoped. The reflection seem not to appear in all of them.
        Press F1...thank me later
        • majidM
          majid
          Nice result mate!!
          Do you mind sharing more renders from different angels too?
          • ntxdaveN
            ntxdave
            @majid said:
            Nice result mate!!
            Do you mind sharing more renders from different angles too?
            Thanks.
            At some point, I will. However, some parts were only done for this view so I will have to finish the model. ☀
            • ntxdaveN
              ntxdave
              Another practice sketch. Several things wrong that I can to do better before taking building into SketchUp but again learning more about sketching (using Sketchbook on my iPad for my sketches.
              “Practice” for letter S
              Hope you can see which letter of the alphabet is my inspiration. 😄
              • majidM
                majid
                Another nice start.
                Needless to declare that there is no obligation to stick to the initial form.
                I also have shared samples. In fact as it is believed in "lateral thinking" those sketches are to make us think out of box.
                • ntxdaveN
                  ntxdave
                  @majid said:
                  Nice result mate!!
                  I did do some new/multiple renders which I posted on this Twilight Render forum thread Alphabet Inspired Sketches.
                  I am not happy with the results though. I tried to use the trial version of the Skatter plugin but still have a lot of things to learn so I can get tepee landscape and background better. When that happens I will post some new renders.
                  • majidM
                    majid
                    I believe that there is a grass tutorial on Twilight forum (maybe by Fletch). It is viable in postpro. The result is realistic.
                    • ntxdaveN
                      ntxdave
                      OK Finally some new images after spending a lot of time learning how to use the Skeatter plugin. Yjeu were rendered with Twilight Render V2
                      • ntxdaveN
                        ntxdave
                        Scene 3
                        Sorry, I could not add this 3rd image to the previous post.
                        • ntxdaveN
                          ntxdave
                          Scene 2 FIXED ❗
                            • majidM
                              majid
                              Very neat model and render!
                              • ntxdaveN
                                ntxdave
                                Thanks guys. 😄
                                For some reason I made a lot of mistakes when learning how to use the Skatter plugin but I think it is a good plugin for putting vegetation in a SU model. It supports several render applications which allows you to put a number of instances of vegetation in a model without bringing SU to its knees when looking around in your model.
                                • ntxdaveN
                                  ntxdave
                                  Majid - just for you..............
                                  AIP-Majid
                                  • ntxdaveN
                                    ntxdave
                                    Majid, this is just for you.............
                                    Alphabet Inspired Sketch - Majid
                                    • majidM
                                      majid
                                      WoW, I appreciate it... 👍
                                      • ntxdaveN
                                        ntxdave
                                        A little more progress in learning how to use the Skatter plugin. I added the SketchUp logo to the last model. 😄
                                        • majidM
                                          majid
                                          Wonderful!
                                          • majidM
                                            majid
                                            Just realized that I have dropped some of my initial sketches and so they are not included in the book. So I thought it would be nice to share them here.
                                            Letter B- Dropped
                                            • 11
                                            • 6 / 11
