    Spaceship time again!
    111 Posts 9 Posters 12.4k Views 9 Watching
      ^ Agreed mate. Nice progress, Bryan. πŸ‘
      • Bryan KB
        Thanks mike!
        Thanks tuna!
        Not really much to look at right now.
        I've been busy with other things and no real time to work in this.
        • L
          Nice work mate, I have a new job thanks to sketchup and am pretty busy so I am not very active here much. But I occasionally have a quick look into what's going on in sketchucation forums, but I always need to check out the progress of your work on this project. πŸ‘ πŸ‘
          • Bryan KB
            Thanks L i am. I'm anxious to move ahead with this, but I'm just too busy.
            • Bryan KB
              And congratulations on your new job! πŸ‘ πŸ‘
              • Bryan KB
                This is the framework I'll use. Just rough blocking right now. I intend to use the vectors of the hull to "smooth" it all together.
                Checking scale and rough postition right now. I'll probably do what I did with the Nadesico and rough it in, then start adding more lines as needed, moving vector points until it smooths out. Or Curviloft or Artisan, depending on situation. Or some combination of all.
                Had to shorten the back end some more. Horizontal scale front to back.
                Wanted to work on it a lot more tonight, but a bad storm is in the region. Can't chance a power flicker.
                  Moving on very nicely mate. πŸ‘
                  • ntxdaveN
                    ntxdave
                    Educate me. Where do you get the info to do models like this?
                    Press F1...thank me later
                    • Bryan KB
                      I'm having to think this one through because once I commit to the rear shapes, there is no going back. I will of course save this stage of the model and use a copy, but there will be so many steps to getting the shapes to flow together that it will not be salvageable and I'll have to revert back to this shape and start again.
                      And right now, I don't have time.
                      Usually I do have time and just bull on through until I get it. But right now I can't.
                      Which may be a fancy way of saying I'm procrastinating, but for reasons! πŸ˜†
                      • Bryan KB
                        I'm getting closer. But still have a long way to go. The lines are still off. I have no problem seeing it in my head, but getting SU to cooperate is a different story. πŸ˜†
                        • Bryan KB
                          I just google search images for random spaceships.
                          As for modeling, it's straight up trial and error and more years than I care to admit for not being any better than I am.
                          But mostly, just slinging lines and faces around until it works. Or doesn't.
                          I do use Curviloft and Soap bubble and Artisan and Tools on Surface, but more often it's just connecting lines and arcs and moving vector points by hand. Move tool, grab vector intersection, move.
                          If I was better with Artisan, I could cut my modeling time in half. I see what it can do, but I can't seem to grasp the number of triangles needed to produce the desired results. Yet I can do those triangles manually. Drives me crazy.
                          • Bryan KB
                            No way, no how was that going to work for the rear engines. I've deleted the block, re-skinned the hull and will hand draw the engines in place.
                            • Bryan KB
                              Taking a break. Between the weather (huge temp swings) and seasonal allergies, I'm not able to focus like I need to.
                                It's not going anywhere mate, time to be kind to one's self for a while. See you on the flip side.
                                • Bryan KB
                                  Alrighty! I'm getting a handle on this. This is not it either, but I now know what direction to go in. I am quite close. I'll have to rip all this out again, but the next one should be it. Or very damn close to it.
                                  • Bryan KB
                                    Just a bit more refinement and I'll have the upper shell of the rear engine pods.
                                    You can see the block sections I had to create to make this work. Lot and lots of arcs and then Curviloft to skin. I also had to shorten the rear section by a lot. Just selected all four rear sections and scaled along the red axis. Then built the engine pods sections.
                                    A little more refinement to the front hull as well by changing the white section.
                                    • Bryan KB
                                      Now we're gettin' somewhere!
                                      I do believe I can start the bottom hull now. I'll come back and detail the engine pods later. I need to get the whole thing roughed in first.
                                      • ntxdaveN
                                        ntxdave
                                        Always interesting to watch these progress. πŸ‘ πŸ‘
                                        • Bryan KB
                                          • Bryan KB
                                            So a bit more squashing here and there. I can already see this will not be one-for-one, but there is only one view to go by, so it will only be close.
                                            • 3 / 6
