    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 647.3k Views 113 Watching
      satemorej
      Hello
      @samuel_t said:
      Hello @satemorej,
      Can you, please, send me the files producing this error?
      Here is the link to the obj file that causes my error.
      https://www.artec3d.com/fr/3d-models/bearded-guy-hd
      Best regards
      Jerome
      • samuel_tS
        samuel_t
        Hello Jérôme,
        I inspected the ".obj" file mentioned in your last message. It contains an empty "mtllib" statement, on line 7. This causes the "copy_stream" error...
        While waiting for a fix in my plugin code, here is a workaround:
        • Open the file "Bearded guy.obj" with a simple text editor.
        • Delete line 7 (mtllib) then overwrite the file.
        • Import the file again with the plugin.
        • Didier BurD
          Didier Bur
          Hi Samuel,
          Thanks again for this cool plugin 😄
          I use UniversalImporter to import an OBJ file that is exported from MeshMolder.
          As you can see on the images, the 435488 triangles from MM are converted to a 86702 triangles mesh in SU. But when importing, UI does say "The file has 435488 faces. Do you want to reduce the number of faces ?". The triangles decimation occurs even if I answer "No" to this message.
          Do I miss something or is there a face count limit in UImporter ?
          MeshMolder
          SketchUp
          DB
          • samuel_tS
            samuel_t
            Hi Didier,
            No, I didn't put such a limit in the Universal Importer plugin.
            For information, polygon reduction is done thanks to MeshLab.
            If you target 200 000 faces when the plugin proposes a polygon reduction, what is the final result in SketchUp?
            • Didier BurD
              Didier Bur
              Hi Samuel,
              I'll try with a 200k faces mesh as time permits.
              I've tried with TIG's "OBJ Importer" plugin and it doesn't decimate the triangles. Cool 😎
              Regards,
              DB
              • Didier BurD
                Didier Bur
                Hi Samuel,
                Here are the results with a 200k triangles mesh:
                The triangles loss is far less than with a 400k mesh, but it is still there.
                Regards,
                DB
                • samuel_tS
                  samuel_t
                  Hi Didier,
                  I meant to say export the model to 435,488 faces from Meshmolder, then target 200,000 faces with Universal Importer to see how the plugin behaves... but never mind.
                  In your case, the polygon count goes down even if you don't ask Universal Importer for a reduction. This leads me to think that it is solely the conversion (done thanks to Assimp), which by an automatic optimization or correction, causes the loss of triangles.
                  Could you please send me the model you are trying to import?
                  Regards,
                  • Didier BurD
                    Didier Bur
                    Hello Samuel,
                    I've sent you the OBJ file via PM.
                    Regards,
                    DB
                    • B
                      bartektrebacz
                      Dear Samuel,
                      Thank You for making this plugin available to the public, I would really like to try to use it, unfortunately sketchup crashes on import. I tried with multiple formats of the same model with no success:/ I’m using sketchup 17 make version.
                      Best regards!
                      This is the file name
                      • samuel_tS
                        samuel_t
                        https://sketchucation.com/forums/download/file.php?id=168290&mode=view/rokbox.jpg
                        Hello Jérôme,
                        Upcoming plugin version fixes this error! 😉
                        • samuel_tS
                          samuel_t
                          @didier bur said:
                          I use Universal Importer to import an OBJ file that is exported from MeshMolder.
                          Hello Didier,
                          Thanks for providing this OBJ file. With upcoming version of Universal Importer, I ended up with 379808 faces in SU. Not perfect but better 😄
                          • samuel_tS
                            samuel_t
                            @bartektrebacz said:
                            Dear Samuel,
                            Thank you for making this plugin available to the public
                            Dear bartektrebacz,
                            It seemed natural and more "ethical" to release this plugin for free because it relies heavily on free public resources (such as Assimp and MeshLab) that are developed by other developers than me.
                            SketchUp crashes on import. I tried with multiple formats of the same model with no success 😕 I’m using SketchUp 17 Make version.
                            SketchUp 17 Make, OK. Can you please send me the file "uploads-files-955134-F22+ANUK.3ds" via Dropbox (or another file host) so I can inspect it?
                            • samuel_tS
                              samuel_t
                              @rich o brien said:
                              https://i.imgur.com/bHVy9Nk.png
                              This is on Blender 3.2.1 files. Even a simple cube fails
                              Hello Rich,
                              This error is fixed in upcoming Universal Importer version! In fact, even current Blender version (3.4.1) will be somewhat supported. More news on this topic very soon 😄
                              • samuel_tS
                                samuel_t
                                Hello, I am pleased to announce the availability of Universal Importer 1.2.0! 😄 Here are the changes brought by this new version:
                                Improvements
                                Imports are faster due to the fact that the plugin now uses (as much as possible) temporary hard links instead of classic temporary files. This also allows to monopolize less disk space during the import process.
                                I refactored some of the plugin code to make it cleaner, I hope so 😛
                                Bugfixes
                                Polygon reduction from the toolbar was not working anymore (or not for all models). The number of faces before and after reduction was about equal, very far from the target... It's fixed!
                                Thanks to the great work of the Assimp contributors, you should no longer get the error:
                                • "End of file or read limit was reached", when importing a .ter file (Terragen).
                                • "Constructing BlenderDNA Structure encountered an error", when importing a .blend file. By the way, the files created with Blender 3 are now importable provided you:
                                  1. Extract the textures embedded in the .blend file to the disk with Blender.
                                  2. Check the option "Claim Missing Textures" in Universal Importer.
                                The bug of imported materials with zero opacity is fixed. Thanks to JDD for reporting this bug.
                                It is now possible to load an .obj file that references an empty material library ("mtllib"). Thanks to Jérôme Tas for reporting this case.
                                A heavy model (e.g. more than 400 000 triangles) can lose triangles once imported into SketchUp with Universal Importer. This problem has not disappeared yet but seems less present... Thanks to Didier Bur for reporting this problem.
                                Translations
                                I took the liberty of including a Japanese translation of Universal Importer, found on the PC-Trace blog. If you are the administrator of this blog, I invite you to contact me to become the official Japanese translator of the plugin.
                                If Universal Importer is not available in your native language, feel free to contact me to become its official translator 😉
                                Download latest Universal Importer plugin from SketchUcation PluginStore.
                                  Brilliant update!
                                    Blend files seem to still be an issue. Will test more though....
                                    https://i.imgur.com/4clWQXe.png
                                    • samuel_tS
                                      samuel_t
                                      1.2.1 version handles the case when you import a model from a non-system disk partition such as "D:".
                                        Still getting errors even on simple cube mesh. No materials, no modifiers and no external files linked or appended to .blend
                                        https://i.imgur.com/aKHxGA6.png
                                        • samuel_tS
                                          samuel_t
                                          Hi Rich,
                                          Thanks for your quick bug reports.
                                          Does Universal Importer v1.21 allow you to import other formats than .blend?
                                          Can you please attach this very simple .blend file that refuses to be imported?
                                            Here's a simple cube saved in Blender 3.5 that fails to import...
                                            cube.zip
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 18 / 23
