    Spaceship time again!
    111 Posts 9 Posters 10.0k Views 9 Watching
    • Bryan KB Offline
      This one is going to take a while. The original picture is cool, but it's not really enough to go on.
      I still think I can do it, though.
      • Bryan KB Offline
        OK, and away we go.
        I increased the vertical scale of the top half (just ever so slightly) and then roughed in canopy/cockpit outline using Tools on Surface lines. (much fiddling with the lines)
        This is where I'll start and build off from here.
        I'll be carving and cutting and pushing vertexes until I get close enough. Hopefully, only a little as the overall shape looks good. The nose shape will be for starters. Needs for dolphin/orca whale shape along the vertical. Horizontal shape is good for now.
        I am using the component mirror method. One side is the reverse duplicate of the other. So make change on one side and it's automatically duplicated.
          I think you are closing on the shape, looking good already.
          • Bryan KB Offline
            It's getting there.
            So the nose and cockpit/cabin should be more like this, but it needs a little more refinement. I had to delete the middle profile curve on one side and redo the Curviloft skin. I'll have to do it again, but I'm very close so one more time should do it.
            • Bryan KB Offline
              OK, well five more times. I think this is it for the nose. Just need to refine the cockpit lines.
              • Bryan KB Offline
                More fiddling with proportions and looking for the cutoffs of the fuselage.
                I squished the frame a little in both vertical and horizontal.
                Subtle changes to the cockpit.
                • Bryan KB Offline
                  Got to think about this a few more days. Not feeling it.
                  • Bryan KB Offline
                    I've sliced the tail. I see a difference from the original right away, but I may just go with it. I'm noticing more and more impossible geometry of the original.
                    But that's OK. I may be doing more skin re-curving later.
                    I also changed the angle of the slice and then scaled (shortened) the vertical of the lower fuselage.
                    It appears I'll have to make initial slices, then build out the engine pods things, and THEN re-curve the skin to the added geometry.
                    • Bryan KB Offline
                      So a little bit of squashing and scaling and then slicing and I'd say I'm in the ballpark.
                      Fiddled with the cockpit some more and I think I've got it. Now on to the engines.
                      • tuna1957T Offline
                        tuna1957
                        Nice progress πŸ‘
                          ^ Agreed mate. Nice progress, Bryan. πŸ‘
                          • Bryan KB Offline
                            Thanks mike!
                            Thanks tuna!
                            Not really much to look at right now.
                            I've been busy with other things and no real time to work in this.
                              Nice work mate, I have a new job thanks to sketchup and am pretty busy so I am not very active here much. But I occasionally have a quick look into what's going on in sketchucation forums, but I always need to check out the progress of your work on this project. πŸ‘ πŸ‘
                              • Bryan KB Offline
                                Thanks L i am. I'm anxious to move ahead with this, but I'm just too busy.
                                • Bryan KB Offline
                                  And congratulations on your new job! πŸ‘ πŸ‘
                                  • Bryan KB Offline
                                    This is the framework I'll use. Just rough blocking right now. I intend to use the vectors of the hull to "smooth" it all together.
                                    Checking scale and rough postition right now. I'll probably do what I did with the Nadesico and rough it in, then start adding more lines as needed, moving vector points until it smooths out. Or Curviloft or Artisan, depending on situation. Or some combination of all.
                                    Had to shorten the back end some more. Horizontal scale front to back.
                                    Wanted to work on it a lot more tonight, but a bad storm is in the region. Can't chance a power flicker.
                                      Moving on very nicely mate. πŸ‘
                                      • ntxdaveN Offline
                                        ntxdave
                                        Educate me. Where do you get the info to do models like this?
                                        Press F1...thank me later
                                        • Bryan KB Offline
                                          I'm having to think this one through because once I commit to the rear shapes, there is no going back. I will of course save this stage of the model and use a copy, but there will be so many steps to getting the shapes to flow together that it will not be salvageable and I'll have to revert back to this shape and start again.
                                          And right now, I don't have time.
                                          Usually I do have time and just bull on through until I get it. But right now I can't.
                                          Which may be a fancy way of saying I'm procrastinating, but for reasons! πŸ˜†
                                          • Bryan KB Offline
                                            I'm getting closer. But still have a long way to go. The lines are still off. I have no problem seeing it in my head, but getting SU to cooperate is a different story. πŸ˜†
                                            • 2 / 6
