    Spaceship time again!
    111 Posts 9 Posters 6.6k Views 9 Watching
    • Bryan KB Offline
      Not much look at, but what I've done is create a back-up duplicate. The near right one will be the working model and the far left one, the back-up.
      This model is one I made years ago when I first installed Curviloft. It was a good shape so I've saved it for various projects. The "Field Trip" model came from this shape.
      • Bryan KB Offline
        Here's the original model. I just squash and stretch it using scaling until I get what I want.
        It's just one shape, duplicated 4 times and scaled.
        • Bryan KB Offline
          This one is going to take a while. The original picture is cool, but it's not really enough to go on.
          I still think I can do it, though.
          • Bryan KB Offline
            OK, and away we go.
            I increased the vertical scale of the top half (just ever so slightly) and then roughed in canopy/cockpit outline using Tools on Surface lines. (much fiddling with the lines)
            This is where I'll start and build off from here.
            I'll be carving and cutting and pushing vertexes until I get close enough. Hopefully, only a little as the overall shape looks good. The nose shape will be for starters. Needs for dolphin/orca whale shape along the vertical. Horizontal shape is good for now.
            I am using the component mirror method. One side is the reverse duplicate of the other. So make change on one side and it's automatically duplicated.
              I think you are closing on the shape, looking good already.
              • Bryan KB Offline
                It's getting there.
                So the nose and cockpit/cabin should be more like this, but it needs a little more refinement. I had to delete the middle profile curve on one side and redo the Curviloft skin. I'll have to do it again, but I'm very close so one more time should do it.
                • Bryan KB Offline
                  OK, well five more times. I think this is it for the nose. Just need to refine the cockpit lines.
                  • Bryan KB Offline
                    More fiddling with proportions and looking for the cutoffs of the fuselage.
                    I squished the frame a little in both vertical and horizontal.
                    Subtle changes to the cockpit.
                    • Bryan KB Offline
                      Got to think about this a few more days. Not feeling it.
                      • Bryan KB Offline
                        I've sliced the tail. I see a difference from the original right away, but I may just go with it. I'm noticing more and more impossible geometry of the original.
                        But that's OK. I may be doing more skin re-curving later.
                        I also changed the angle of the slice and then scaled (shortened) the vertical of the lower fuselage.
                        It appears I'll have to make initial slices, then build out the engine pods things, and THEN re-curve the skin to the added geometry.
                        • Bryan KB Offline
                          So a little bit of squashing and scaling and then slicing and I'd say I'm in the ballpark.
                          Fiddled with the cockpit some more and I think I've got it. Now on to the engines.
                          • tuna1957T Offline
                            tuna1957
                            Nice progress πŸ‘
                              ^ Agreed mate. Nice progress, Bryan. πŸ‘
                              • Bryan KB Offline
                                Thanks mike!
                                Thanks tuna!
                                Not really much to look at right now.
                                I've been busy with other things and no real time to work in this.
                                  Nice work mate, I have a new job thanks to sketchup and am pretty busy so I am not very active here much. But I occasionally have a quick look into what's going on in sketchucation forums, but I always need to check out the progress of your work on this project. πŸ‘ πŸ‘
                                  • Bryan KB Offline
                                    Thanks L i am. I'm anxious to move ahead with this, but I'm just too busy.
                                    • Bryan KB Offline
                                      And congratulations on your new job! πŸ‘ πŸ‘
                                      • Bryan KB Offline
                                        This is the framework I'll use. Just rough blocking right now. I intend to use the vectors of the hull to "smooth" it all together.
                                        Checking scale and rough postition right now. I'll probably do what I did with the Nadesico and rough it in, then start adding more lines as needed, moving vector points until it smooths out. Or Curviloft or Artisan, depending on situation. Or some combination of all.
                                        Had to shorten the back end some more. Horizontal scale front to back.
                                        Wanted to work on it a lot more tonight, but a bad storm is in the region. Can't chance a power flicker.
                                          Moving on very nicely mate. πŸ‘
                                          • ntxdaveN Offline
                                            ntxdave
                                            Educate me. Where do you get the info to do models like this?
                                            Press F1...thank me later
                                            • 2 / 6
