    Spaceship time again!
    111 Posts 9 Posters 12.4k Views 9 Watching
    • tuna1957T
      tuna1957
      Look forward to your progress. You always choose some very interesting stuff to model. πŸ‘
      • Bryan KB
        Thanks tuna!
        • L
          I mean this constructively, I fully understand and agree with starting the skeleton scaled to human ergonomics, just like the start point of designing a car. Howevever I think you should consider what happens when the person/persons sitting in the chair stand up?
          • Bryan KB
            Thanks L I am, but it's a small cockpit not meant to stand up in.
            Hmm, another one that's going to take some time. I can see the whole thing in my head, but where to start...
            • Bryan KB
              Kinda sorta this shape.
              • Bryan KB
                Still scaling and refining.
                • ntxdaveN
                  ntxdave
                  This is both interesting and educational. πŸ‘
                  Press F1...thank me later
                  • Bryan KB
                    It will definitely be educational. I have no idea how I'm going to connect all the different curved surface. πŸ˜†
                    My technique is to find that one element in the design to "hang" the rest of the model from. (build outward from that element) I have not found that thing yet.
                    • Bryan KB
                      O.K., I've decided to use the side red bubble thing as my starting point.
                      (you can skip this one, see next post)
                      • Bryan KB
                        Ho boy was I wrong about the scale. After framing the scene to sort of match the original, this is what I found.
                        Waaaay off on scale. Hmmmmm....
                        • Bryan KB
                          I'm using the horizon line and distance to ground shadows to approximate scale. I've also noticed the painting is not exactly straight on perspective, so I have to try and judge how "off" it is (i.e. tiled or twisted) and compensate.
                          I only have to get close, but scale is important.
                          Man, I sure know how to pick 'em. πŸ˜†
                          • Bryan KB
                            O.K, I'm going with the orange shape, so the final result may not look exactly like the picture, but that is due to the nature of the scale and weird perspective of the original.
                            • Bryan KB
                              Not much look at, but what I've done is create a back-up duplicate. The near right one will be the working model and the far left one, the back-up.
                              This model is one I made years ago when I first installed Curviloft. It was a good shape so I've saved it for various projects. The "Field Trip" model came from this shape.
                              • Bryan KB
                                Here's the original model. I just squash and stretch it using scaling until I get what I want.
                                It's just one shape, duplicated 4 times and scaled.
                                • Bryan KB
                                  This one is going to take a while. The original picture is cool, but it's not really enough to go on.
                                  I still think I can do it, though.
                                  • Bryan KB
                                    OK, and away we go.
                                    I increased the vertical scale of the top half (just ever so slightly) and then roughed in canopy/cockpit outline using Tools on Surface lines. (much fiddling with the lines)
                                    This is where I'll start and build off from here.
                                    I'll be carving and cutting and pushing vertexes until I get close enough. Hopefully, only a little as the overall shape looks good. The nose shape will be for starters. Needs for dolphin/orca whale shape along the vertical. Horizontal shape is good for now.
                                    I am using the component mirror method. One side is the reverse duplicate of the other. So make change on one side and it's automatically duplicated.
                                      I think you are closing on the shape, looking good already.
                                      • Bryan KB
                                        It's getting there.
                                        So the nose and cockpit/cabin should be more like this, but it needs a little more refinement. I had to delete the middle profile curve on one side and redo the Curviloft skin. I'll have to do it again, but I'm very close so one more time should do it.
                                        • Bryan KB
                                          OK, well five more times. I think this is it for the nose. Just need to refine the cockpit lines.
                                          • Bryan KB
                                            More fiddling with proportions and looking for the cutoffs of the fuselage.
                                            I squished the frame a little in both vertical and horizontal.
                                            Subtle changes to the cockpit.
                                            • 1 / 6
