    [Plugin] FredoSketch - v1.7a - 17 Dec 25
    35 Posts 9 Posters 11.2k Views 9 Watching
    • fredo6F Offline
      @panixia said:
      Nothing happens.
      Regular sketchup move tool is triggered both with double M key and double toolbar button press.
      The same happens with the rotate tool both in SU 2020/21.
      I discovered that the functionality can only be available in SU2021.1 and above. For prior versions, there is no notification when you call again the active tool.
      I will update the FredoSketch documentation to reflect this limitation.
      • OxerO Offline
        Oxer
        Hi Fredo, very useful plugin. πŸ‘
        Here is the Spanish Language file:
        FredoSketch_ES.lang.zip
          bsfranza
          super cool πŸ˜„
          if i could add one wish to it - make vertex selection possible for multiple groups/componnents ...
          maybe kind of like this
          preselect or not, set active or nested also, make rectangle selection, move vertices...
          why would this be usefull? when we want to stretch complicated elements whre there is no real good "section plane for the stretch"...
          thx - amazing work as always!!
          • fredo6F Offline
            @bsfranza said:
            sif i could add one wish to it - make vertex selection possible for multiple groups/componnents ...
            This would change the nature of the tools...
            As for the native tools, the selection works in the current context. When you click on anything that belongs to a group or component, you do select the group or component.
            If FredoSketch was selecting across the boundaries of groups / components, how would select a group or component?
            • fredo6F Offline
              NEW RELEASE: FredoSketch v1.2a - 01 Feb 23
              Requirement: LibFredo6 13.7b
              FredoSketch v1.2a is a maintenance release:
              • Updated help and menu for limitation of Quick Launch to SU2021.1 and above
              • fix for small issues
              Home Page of FredoSketch for information and Download.
              Main post of this FredoSketch thread.
                PedroE
                And why not unite everything in a single command and button, I mean, invoke a command that allows us to move, copy, rotate, align and then the auxiliary keys that allow us to choose. For a button to move, another to rotate, another to move to align, it is better to merge them all as we have now, for example, move and copy by pressing ctrl
                • fredo6F Offline
                  Could you describe how it would work with all tools in one. For instance, when you click and move the mouse, what does happen?
                    PedroE
                    even better, that hot boxes appear at the main points (vertices, midpoints, etc) that allow you to choose whether to move (default command), copy, rotate, scale, move and rotate. It could be something as fun as this, to manipulate only with the mouse.
                    • BoxB Offline
                      These are astoundingly good tools.
                      • fredo6F Offline
                        The Texture positioner is the worse method to manipulate objects.
                        One way to combine several transformations is to use a Gizmo, like in Blender, supporting:
                        • Move along an axis
                        • Move on Axis Plane
                        • Rotate and Spin by an axis
                        • Scale Uniform or along an axis plane
                        • Flip Along (Mirror in place)
                        However, the main restrictions are that
                        1. You transform only by reference to axes, which can however be the model axis or the component axes.
                        2. You cannot use inferences, because the click point is on the Gizmo, not on the object you move
                        3. You can however type distance, scaling factors, angle, etc... in the VCB
                        • panixiaP Offline
                          panixia
                          please, no.
                          • panixiaP Offline
                            panixia
                            Ditto. It's a freakin' toy.
                            Please yes! β˜€
                            I suggest to use the local axis origin point as default point to place it when a object is selected and the center of masses when multiple objects are selected (without having to reposition it every single time, that could be a context menu option or something). A toggle between origin and center could be very "industry standard" too.
                              PedroE
                              In principle, I do not mean that they are object handlers, but that those icons that appear allow once the input command is executed (by default to move) then they allow us to choose if we copy, scale, rotate, mirror, etc. In other words, an initial command derives in all the other movements that we can make to an object, without having to choose a command each time. The object manipulator points you already do with the most efficient way that you consider.
                                rv1974
                                Simple keyboard shortcuts are way faster than any icons upon objects you are dreaming of.
                                  PedroE
                                  It is about not losing the focus of attention on the object to be manipulated, not everyone likes keyboard shortcuts. In this way you optimize mouse movements, in addition to the fact that the future comes with touch screens, similar to what sketchup for ipad does.
                                  • fredo6F Offline
                                    Then, you can have a simple toolbar with at the top of your screen. Normally, FredoSketch selects the objects being moved or rotated when exiting. So you can probably chain with another tool.
                                    • E Offline
                                      Einstein
                                      Hi, Fredo,
                                      You probably have it on your to-do list already, but remembering and revoking lastly used soft-selection radius would be a great improvement. Now it jumps back to zero when the tool is activated again (and when it was used previously with larger radius). For comparison, Blender always remembers the last value for proportional editing.
                                      Great tool, though. I've been asking ThomThom for years to expand his Vertex Tools with more falloff options, and here we are with FredoSketch!
                                      • fredo6F Offline
                                        @einstein said:
                                        Hi, Fredo,
                                        This is possible. I probably save it at model level
                                        Vertex Tools does a lot more... and I think it has fall-off methods too.
                                          PedroE
                                          Example of manipulation by gizmos:
                                            PedroE
                                            This was what i meant:
                                            although it is still room for improvement. I encourage you to do it. All the best.
