    Shape bender doesn't really work
    Scheduled Pinned Locked Moved Organic Modelling
    35 Posts 13 Posters 44.9k Views 13 Watching
      @sondos said:
      ...why shape bend can't choose the line when it ask me to choose it
      The line AND the curve must NOT touch any other geometry, including each other.
      This first picked line must also be parallel to the X-axis [red].
      Tips:
      If you get Ruby Console errors relating to 'cursors' it suggests that you have not installed this tool correctly and its folder of cursor images etc is missing or it's incomplete.
      If you get other errors in the Ruby Console or the tool 'stalls' after starting, then also ensure that you have downloaded and installed the helper file 'progressbar.rb' from 'smustard.com', as instructed in this tool's download page notes... [mod=:12dkj2cy]EDIT: the v2014 compliant version no longer needs progressbar.rb ![/mod:12dkj2cy]
        1232sean
        I am having a problem with shapebender where I get it to work but it only gives me the frame of my shape and not the surfaces. Do you know what is going on?
        • cottyC
          cotty
          Do you have a picture?
          my SketchUp gallery
          • P
            Painreliever
            Hi guys,
            when I select the horizontal line drawn on red axes, it does not really be selected (I don't get the notification of start&end) so the bending does not occur??
            Moreover, in extension manager a warning is shown "Unsigned", may that be the problem?
            Thnx
              What version of SketchUp are you using - I suspect your profile is out of date ?
              The unsigned issue is a red-herring.
              It just means that it's an older tool and will run in Extension loading policy > Unrestricted - which you must have set, otherwise it wouldn't even appear in the menu !
              Run it with the Ruby Console open to see any error messages...
              Is the 'red' line really parallel to the model's red-axis or have you perhaps reset the axes to confuse things ?
              There was a version of v2019 that broke this tool, it was fixed by a latest MR - so do you have that later version ?
                muazzam5abbas
                hi!
                i am stuck with shape bender. i recently added shape bender plugin from sketchUcation in SU pro 2019.
                i am doing everything right as told in various tutorials. placing base line along red axis. but when i select base line after initiating shape bender , it selects the base line successfully and ask to select the curve for bend. but doesn't show start and end point as shown in tutorials. similarly when i select the curve, it neither shows the start and end points and does nothing. what should i do.
                i have already tried uninstalling and reinstalling shape bender tool.
                step 1 while choosing base line
                step 2 after selecting base line
                step 3 after selecting curve
                ruby console
                  The error you are getting was noticed as a 'reversion' in a SketchUp v2019 update - what's yours ?
                  It was fixed by a SketchUp update of that version...
                  It was caused by the tool's code using the selected line's vertex to place text, rather than the vertex.position - however, using a vertex OR a vertex.position should both work !
                  As I say this was fixed on the SketchUp side, so have you got the latest version of your particular SketchUp version installed ??
                  Please update your profile details accordingly...
                  You can get the current versions of all supported downloads here:
                  https://help.sketchup.com/en/downloading-older-versions
                  • B
                    betofg90
                    @muazzam5abbas said:
                    hi!
                    DID YOU FIX IT? I'm having the same problem
                      Have you got the latest version of v2019 and installed it ?
                        MarieEve Martel
                        In my case, shape bender doesn't work appropriately, the bending is... off and distorted.
                        I followed the correct steps (component, straight line, and curved line aligned with red axe - line same width as component), selected my component, clic on shape bender tool, select straight line, then the curved one, and then the green preview appears, but it's not following the curved blueprint on the ground, it's not right above it (as it should), it's distorted out of angle and has this weird geometry pulling on it on one end stretching.
                        I'm not sure exactly how to insert an image here, but I dragged and dropped it right in the text boxe (hope it works), and tried putting the [img] pictures code around it. If you can't see the image, can you tell me how to ad it in please ? I am not familiar with coding, if that's what this is. Sorry, it's my first time joining a conversation on this forum, on this platform.
                        [img]/Users/marie-evemartel/Desktop/Screenshot%20shape%20bender%20malfunction.png[/img]
                        • BoxB
                          Tap the up and down arrow keys until the green preview is what you want, then hit enter.
                          Look in the status bar at the bottom of your screen for modifiers for tools.
                          • 2 / 2
