    Fredo Plugin issues
    16 Posts 3 Posters 1.6k Views 3 Watching
    • david_hD
      david_h
      I don't see that option on my menu.
      hmmm.
        Therein lies the problem....
        Update Sketchucation Tools
        Sketchucation Tools | SketchUcation
        (sketchucation.com)
        Update Libfredo
        SketchUp Plugins | PluginStore | SketchUcation
        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
        (sketchucation.com)
        Use the ExtensionStore to update.
        • david_hD
          david_h
          checked and rechecked and reinstalled the updates. I had done so before I threw up my hands and cried out into the Sketchup Wilderness.
          Still no go. I just think the icons have loaded into a different folder than wehre the actual extension is. When I do the store update it gives me two folder options for auto update and I choosed them both cuz I don't know which one is the goodest.
          C:?USers/Name/Appdata/Roaming/sketchup.. . .etc
          Or C:/PRogramData/Sketchup etc.
          • david_hD
            david_h
            restarted SU> Got the menu you described. Pulled up the report here:
            Fredo6 Plugins Information on 2023-01-25 10:01:30 -0700
            • Platform: x64-mingw32 - Ruby: 2.5.5
            • Sketchup: 20.2.172
            • LibFredo6: v13.7b
            • Sketchucation ExtensionStore: 4.2.9
            • SCFLicense: v5.7a - 50
            • Fredo6 Plugins
              FredoScale v3.5a - licensed FULL
              FredoTools v4.3a
              Signature File: 2022-10-04 12:17:29 -0600
              FredoScale: 2022-10-04 12:17:47 -0600
              RoundCorner: 2023-01-18 14:25:54 -0700
            HOwever. . .ROund Corner etc. Is not longer there.
            • david_hD
              david_h
              Problem Solved! I'm just so so happy πŸ’š
                Sketchucation Tools 4.3.0 is the latest.
                Your install path should be...
                https://i.imgur.com/mw9rNun.png
                ...anything else I'd ignore unless your adept in the dark arts or a glutton for punishment
                • david_hD
                  david_h
                  Thank you Rich. I appreciate the tete a tete. I think I have got it working now. thanks for the help.
                  DH
                  BTW> . .I am. . .occasionally a glutton for punishment. . . πŸ’š
                  • david_hD
                    david_h
                    Well now. . .RoundCorner isn't even loading at all and when I try to reinstall. . .I get an error message.roundcorner.JPG
                    Here is the info from the window that was requested from this last go around. . .
                    I thought I had this solved. as this says .. .some of the tools loaded fine but not ROund Corner, and yet I have the licenses. licenses.JPG
                    Fredo6 Plugins Information on 2023-02-06 14:00:54 -0700
                    • LibFredo6: v13.7b
                    • Fredo6 Plugins
                      FredoTools v4.3a
                      VisuHole v1.4b
                    • fredo6F
                      Could you try with the Sketchucation ExtensionStore.
                      I don't understand why it fails with the SU Extension Manager.
                      • david_hD
                        david_h
                        trying now. . .but we'll see. Stand by.
                        Thank you,
                        D
                        • david_hD
                          david_h
                          ]I was able to download from the Extension store. I installed it first on the "AppData>roaming>sketchup...etc." place .
                          No go. I got a zip error.
                          Next tried to load it and install to the "C: ProgramFiles>Sketchup. . .etc) place
                          (Both options were offered)
                          Neither worked. Even after several starts and restarts. as you see . ..other tools are loading fine.[attachment=0]Capture.JPG[/attachment
                          • david_hD
                            david_h
                            any further thoughts on this? When I install to the AppData.. .etc. folder I get the 'cannot unzip" error message. If I install to a custom plugins folder Round Corner installs but the toolbar is missing on the icons, and with each start up I have to re-install anyway.
                            Very Frustrating.
                            thanks for the help in advance.
                              If you repair your SketchUp install by running the installer.exe via right click > Run as Admin.
                              See if that restores your permissions to write o the appdata..... folder
                              Never to this place. That's reserved for special cases.
                              • david_hD
                                david_h
                                Thanks R O'B. I'll give that the ol' college try.
                                D
