    Fredo Plugin issues
    16 Posts 3 Posters 514 Views 3 Watching
    • david_hD Offline
      david_h
      Capture.JPGI have the licensed bundle of Fredo Tools (specifically ROunded Corners etc) However when I activate it, I don't get the icons on the toolbar. IT just shows up blank. This is a new one on me, cuz it seemed to work before. Any thought?
        Can you run....
        https://i.imgur.com/BUQPbUZ.png
        ...and paste output here
        • david_hD Offline
          david_h
          I don't see that option on my menu.
          hmmm.
            Therein lies the problem....
            Update Sketchucation Tools
            Sketchucation Tools | SketchUcation
            (sketchucation.com)
            Update Libfredo
            SketchUp Plugins | PluginStore | SketchUcation
            SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
            (sketchucation.com)
            Use the ExtensionStore to update.
            • david_hD Offline
              david_h
              checked and rechecked and reinstalled the updates. I had done so before I threw up my hands and cried out into the Sketchup Wilderness.
              Still no go. I just think the icons have loaded into a different folder than wehre the actual extension is. When I do the store update it gives me two folder options for auto update and I choosed them both cuz I don't know which one is the goodest.
              C:?USers/Name/Appdata/Roaming/sketchup.. . .etc
              Or C:/PRogramData/Sketchup etc.
              • david_hD Offline
                david_h
                restarted SU> Got the menu you described. Pulled up the report here:
                Fredo6 Plugins Information on 2023-01-25 10:01:30 -0700
                • Platform: x64-mingw32 - Ruby: 2.5.5
                • Sketchup: 20.2.172
                • LibFredo6: v13.7b
                • Sketchucation ExtensionStore: 4.2.9
                • SCFLicense: v5.7a - 50
                • Fredo6 Plugins
                  FredoScale v3.5a - licensed FULL
                  FredoTools v4.3a
                  Signature File: 2022-10-04 12:17:29 -0600
                  FredoScale: 2022-10-04 12:17:47 -0600
                  RoundCorner: 2023-01-18 14:25:54 -0700
                HOwever. . .ROund Corner etc. Is not longer there.
                • david_hD Offline
                  david_h
                  Problem Solved! I'm just so so happy πŸ’š
                    Sketchucation Tools 4.3.0 is the latest.
                    Your install path should be...
                    https://i.imgur.com/mw9rNun.png
                    ...anything else I'd ignore unless your adept in the dark arts or a glutton for punishment
                    • david_hD Offline
                      david_h
                      Thank you Rich. I appreciate the tete a tete. I think I have got it working now. thanks for the help.
                      DH
                      BTW> . .I am. . .occasionally a glutton for punishment. . . πŸ’š
                      • david_hD Offline
                        david_h
                        Well now. . .RoundCorner isn't even loading at all and when I try to reinstall. . .I get an error message.roundcorner.JPG
                        Here is the info from the window that was requested from this last go around. . .
                        I thought I had this solved. as this says .. .some of the tools loaded fine but not ROund Corner, and yet I have the licenses. licenses.JPG
                        Fredo6 Plugins Information on 2023-02-06 14:00:54 -0700
                        • LibFredo6: v13.7b
                        • Fredo6 Plugins
                          FredoTools v4.3a
                          VisuHole v1.4b
                        • fredo6F Offline
                          Could you try with the Sketchucation ExtensionStore.
                          I don't understand why it fails with the SU Extension Manager.
                          • david_hD Offline
                            david_h
                            trying now. . .but we'll see. Stand by.
                            Thank you,
                            D
                            • david_hD Offline
                              david_h
                              ]I was able to download from the Extension store. I installed it first on the "AppData>roaming>sketchup...etc." place .
                              No go. I got a zip error.
                              Next tried to load it and install to the "C: ProgramFiles>Sketchup. . .etc) place
                              (Both options were offered)
                              Neither worked. Even after several starts and restarts. as you see . ..other tools are loading fine.[attachment=0]Capture.JPG[/attachment
                              • david_hD Offline
                                david_h
                                any further thoughts on this? When I install to the AppData.. .etc. folder I get the 'cannot unzip" error message. If I install to a custom plugins folder Round Corner installs but the toolbar is missing on the icons, and with each start up I have to re-install anyway.
                                Very Frustrating.
                                thanks for the help in advance.
                                  If you repair your SketchUp install by running the installer.exe via right click > Run as Admin.
                                  See if that restores your permissions to write o the appdata..... folder
                                  Never to this place. That's reserved for special cases.
                                  • david_hD Offline
                                    david_h
                                    Thanks R O'B. I'll give that the ol' college try.
                                    D
